Ambient temperature reading
Discussion in 'Prime Main Forum (2017-2022)' started by MikeDee, Sep 6, 2022.
  1. MikeDee
    MikeDee Senior Member
    1,572
    596
    San Francisco Bay Area
    It was over 100 F yesterday, but my temperature reading was only 88. It's always been off by a few degrees but this seems too much. Should I have the dealer take care of this (out of warranty), or is this just a matter of replacing the sensor which I could do myself? Does the vehicle depend this temperature reading or is it just for driver convenience?
  2. Trollbait
    12,346
    Has the sensor reported over 100 temperatures without problem before?
    Pulse07 likes this.
  3. lech auto air conditionin
    830
    601
    261
    san francisco
    It is a simple easy sensor to replace it’s just plugged into the end of a wiring harness behind your bumper grill area it’s a simple disconnect and reconnect the new one if needed
    MikeDee likes this.
  4. MikeDee
    1,572
    596
    Hmmm.. I don't know.
    Just went into garage and started the car. Temp in the garage was 85° and that's what the car showed. Maybe a momentary glitch or the sensor measures wrong at high temperatures?
    #4 MikeDee, Sep 6, 2022
  5. Mendel Leisk
    40,576
    Maybe the 100 degrees was off?
  6. bisco
    51,142
    mine has always taken an hour or so to reach the reported temp outside
  7. Trollbait
    12,346
    That's what I was thinking.
  8. fuzzy1
    10,335
    Mine is quite slow to change and settle, but not anywhere near that long.
    And I don't go by internet or news reports of temperature, because large differences is very short distances are quite normal. A 5 degree difference between my front porch and back yard is not at all unusual.
    #8 fuzzy1, Sep 6, 2022
  9. bisco
    51,142
    we have 2 thermometers. they are always within a degree or two, and usually the same.
    the car readout is usually the same as those two. but if i leave the semi conditioned garage on a hot day, 30-45 minutes later, it can still read 10 degrees below the other two.
  10. MikeDee
    1,572
    596
    My Gen 3 says 94F as I'm writing this when it's 108 according to the internet.
    iPhone ? Pro
    #10 MikeDee, Sep 6, 2022
  11. fuzzy1
    10,335
    I always have to wonder: how far away is that 'internet' thermometer? Feet, or miles? How different is that microclimate or microcell today compared to my location?
    Also, what is its elevation difference from me? With a dry air adiabatic lapse rate of 5.4°F/1000 feet (less for wet air), elevation changes can quickly add significant differences too.
    Doug McC and Trollbait like this.
  12. MikeDee
    1,572
    596
    I have compared it to thermometers I have at the house, and they are within a couple of degrees.
  13. ChapmanF
    17,332
    The sensor is shaded behind the front bumper. Have you tried sticking one of the thermometers from the house in there next to the sensor, letting them sit for a while, then comparing the readings?
  14. fuzzy1
    10,335
    Nearly always? Or just sometimes?
    My home thermometers can match the several different 'internet' thermometers near here too, 2 to 20+ miles away. But they can also be very different. Numerous weather cells have smaller dimensions than those distances, sometimes much smaller.
  15. MikeDee
    1,572
    596
    Right now the temps match, 74°. The internet sensor must be close. I'm using Apple weather. Guess it depends on where you live. It doesn't rain here for 6 months from about May to October.
  16. fuzzy1
    10,335
    From just a very few data points, I hope that you are not suggesting that the former implies the later.
  17. MikeDee
    1,572
    596
    Saw 91° before I got home, 91° on the home thermometer soon after. I think the sensor gets inaccurate at temps over 100°.
  18. Doug McC
    Doug McC Senior Member
    1,044
    396
    Midwest
    2022 Prius
    Or this is one more Prius Chat “the sky is falling” RUN FOR YOUR LIVES!!!!!!!!!! :). :). :)
  19. Trollbait
    12,346
    In my general experience on a hot day, the sensor reads higher on start up. Sitting over hot pavement, the space where the sensor is tucked away gets hotter. Once moving, the display comes down as the hot air is flushed away.
    So your sensor could have been hotter that the reported temperature, which pushed it over its high limit. High temps could have also loosened a connection.
  20. MikeDee
    1,572
    596
    Well, I've got two Priuses behaving the same way; i.e., temps over 100° give significantly lower readings on the car, as documented above.
