Featured America's Tire
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by AzusaPrius, Mar 20, 2021.
  1. AzusaPrius
    AzusaPrius Senior Member
    2,253
    942
    Actually the tread pattern is very similar and they know what direction it goes.
    I had one Goodyear that started losing air and so I just bought a used one.
    That is the one that got a puncture and needed repair but they just gave me a Kumho for FREE because the repair could not be done they said it was in another repair location that is why.
    They said the Goodyear's that we had on from 2017 still had a lot of tread left and was surprising for the age.
    That is because I get them rotated and balanced by them every 5k miles for FREE.
    So I have three Goodyear's and one Kumho with similar tread pattern and in newer condition than the Goodyear's.
  2. AzusaPrius
    2,253
    942
    Here is an image of the Kumho Solus first image and second image is Goodyear Assurance 20240825_163454.jpeg 20240825_163645.jpeg
  3. mikefocke
    4,073
    1,858
    Sanford, NC
    So in an emergency, how well do you think your anti lock brakes will handle the mismatched treads? And you are really wanting to be running around on 8 year old tires?
    I replaced mine at 5+ years with 35k on them. I've seen too many accidents with fatalities caused by old tires.
  4. AzusaPrius
    2,253
    942
    The treads are pretty much the same and yes the Goodyears are old but honestly theu were trash a couple years in with the side walls warping.
    I will be getting a new set but not sure on the brand and will use the Kumho as the spare since it is in such good condition.
    The ABS will not have any issues, the tires are not bald and still have enough tread as Americas Tire would not even rotate or balance tires if they dont have enough tread.
  5. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    Third planet from the Sun
    How many miles have these tires done?
    What is the groove depth left?
    A small value is dangerous when driving at high speed on a section of road covered with water.
  6. mikefocke
    4,073
    1,858
    Sanford, NC
    Measure in 3 places across the width of the tire. The lowest depth is the one you use in comparing tread depth. You can find the original tread depth in the "specs" area for each tire at Tire Rack. Their site has videos showing how you can measure using a coin and what the recommended tread depths are and how they affect handling. Or you can buy a "professional" tread-depth gauge from most auto parts stores for around $3.
    You could read their tests or I'll cheat and just give you the results. The difference between a new tire and one worn down to 2/32 (legal limit in many states) in a test on a water soaked surface was an almost doubling of stopping distance! 4/32 deep tires took about 50% longer to stop than new tires.
    New - 195 feet
    4/32 - 290 feet
    2/32 - 378 feet
    Even more startling to me is that on a 2/32 tire, in stopping tests in the wet from 70MPH the new tire would have stopped the car where the worn tire would only have slowed the car to 55MPH!!!! 4/32 would only have slowed the car to 45!!!!
    They don't cite skidpad tests but the same issues that affect stopping distance would affect your staying on the road as you round the curve in the very wet. The tire needs the depth in order to evacuate the water beneath the tread and get the tire "rubber" into contact with the pavement. If it rides up on the water, it is like driving on ball bearings. I recall driving behind a car once and seeing it hit a puddle just as it came to a bridge and then going off like a pinball bouncing off the sides of the bridge. When I stopped, sure enough balding tires.
    Depth does matter in the wet.
    In the dry, depth is not nearly as important as long as the depth is consistent.
    Which is why I am overly .... about replacing tires.
  7. AzusaPrius
    2,253
    942
    I believe my Goodyear tires were in the yellow as they would not rotate or balance tires that are in the red. Screenshot_2024-08-27-19-16-23-1.jpeg
