Amp install guide?
Discussion in 'Gen 3 Prius Audio and Electronics' started by thekenstar, Feb 1, 2016.
  1. thekenstar
    thekenstar Junior Member
    43
    I am going to be installing an amp to power an 8" subwoofer in my 2012 Plug-in Advanced. I can't seem to find a guide where it shows basic things like where the battery is located, a good place to tap into the speaker connections, and stuff like that. I am familiar with installing car audio systems but have never installed anything into a Prius. I would also like to know if anyone out there has a similar setup and how it has affected their electrical system. I am going to try to run it at 1-ohm but am not sure how the car and speaker will handle it, if it doesn't handle it well then ill end running it at 4-ohms. Im pretty excited about the stuff I'm installing, here is a list:
    - Sundown e-8 v.4 d2 -
    - Hifonics Brutus BRZ1200.1d -
    - AudioControl Epicenter -
    - AudioControl LC2i -
    - ASC Ported Enclosure -
  2. Sfcyclist
    Sfcyclist Senior Member
    1,621
    375
    SF, CA
    The 1ohm load depend on your amp not the car. The wattage is the load your car needs to handle.
    Battery is on right side in trunk.
    iPhone ?
  3. thekenstar
    43
    Thanks for the reply. I installed it and that 8" woofer is a monster! Can you tell me where the factory JBL amp is located? I have a 2012 PIP Advance.
    Nevermind! I just read somewhere that its under the drivers seat! Thanks anyway.
  4. Sfcyclist
    1,621
    375
    SF, CA
    As everyone has said, just search.
    iPhone ?
