Featured An EV1 Goes Private
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by El Dobro, Nov 7, 2025.
  1. DavidA
    2,349
    1,825
    Chicago western burbs
    In fact, GM has decided to support their effort for restoration. This is a story that continues.
    hill and Prodigyplace like this.
  2. El Dobro
    El Dobro A Member
    7,102
    3,282
    They did a complete 180 on the EV1.
  3. El Dobro
    El Dobro A Member
    7,102
    3,282
    Here we go, Part 2.
  4. bwilson4web
    16,523
    After 25 years, battery and power switching technology has moved way forward. It would make more sense to get a salvage, recent EV or EV kit. Then they can add a J1772, CSS-1, or even NACS.
    keep the shell but make it practical again.
  5. hill
    9,023
    Other than a couple of Uber low production concept cars - or a model S equipped with an aero kit - EV1 is pretty much the crown for low drag CD (0.19). So yea - keep that body config!
  6. DavidA
    2,349
    1,825
    I can't think that they will end up using the old battery tech in the rebuild. I guess we will find out soon.
  7. bwilson4web
    16,523
    My understanding is they were planning to use NiMH chemistry cells when the EV1 project was aborted. Projections were double the range and faster performance. Thank you Bob Lutz and Rick Wagner.
    There are rumors killing the EV1 helped start Tesla.
    #27 bwilson4web, Mar 17, 2026
  8. hill
    9,023
    Of course they won't. Gen 1 ev1 and S10 pickups used lead acid. Gen 2 / both vehicles used nickel metal hydride, a rather expensive technology and not near as efficient as modern chemistries.
  9. El Dobro
    El Dobro A Member
    7,102
    3,282
  10. El Dobro
    El Dobro A Member
    7,102
    3,282
    Part 3
    DavidA likes this.
  11. El Dobro
    El Dobro A Member
    7,102
    3,282
    Another EV1 restoration video.
  12. DavidA
    2,349
    1,825
    I am beginning to think they will actually use the original battery tech. Every effort seen so far is to use original parts of as close to original as possible. Their S10 pickup was seen in the latest two videos with lead acid batteries only. I think that might be a test for the EV1.
    Prodigyplace likes this.
  13. El Dobro
    El Dobro A Member
    7,102
    3,282
    The next chapter.
  14. austingreen
    austingreen Senior Member
    13,713
    4,231
    Austin, TX, USA
    CdA is the key factor. ev-1 was 0.37 m2, while current Tesla model 3 is 0.49 m2, you can of course fit a much larger battery in a model 3. I would think the only reason to get an ev-1 vs a used model 3 is for nostalgia and uniqueness value. That may be hurt if you change much, but I would think a modern lfp battery could extend range and reduce weight while costing less than an original type battery. It would be a good swat to do that and change the bms and iverter to modern electronics.
  15. hill
    9,023
    All those original nickel metal hydride modules would have long since passed away. It would be one thing to remain all original, but who would care if they switched over to maybe lithium iron to increase range - even though it would require a whole different BMS & charging architecture.
  16. El Dobro
    El Dobro A Member
    7,102
    3,282
    The saga continues.
