And the first unanticipated failure IS...
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by galaxee, Jun 28, 2008.
  1. Sheepdog
    Sheepdog C'Mere Sheepie!
    1,125
    Sanford FLorida
    :p
    wow. That picture on a billboard could change the Prii's status overnight!
  2. PA Prius
    PA Prius Active Member
    762
    251
    SE Pennsylvania
    I think this thread started something. We just had our first failure-- spring assist in the upper glove compartment lid-- anyone had and fixed this? '04 with 93,100 miles. That Platinum Warranty was a scam. They knew from the beginning I would never need it. Grrrrrr. ;)
    PA P
  3. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    hmmm. since i have nothing to do tonight, i might go rent that one.
    then i'll know what you're talking about...
    you over there! don't say anything else!
    :D
    we had our 05 done under basic warranty, so i'm not sure about the extended warranty. we saw that one coming, fortunately, so we got it in before the basic ended.
  4. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    302
    Northwest VT
    2018 Prius Prime
    Geez, 2 light bulbs in 1 month? And without puncture proof tires? Next you'll tell us you have to replace the GAS in it every 5 or 6 hundred miles too! Galaxee, no one would buy such an unreliable hunk of steel (and aluminum, and plastic). You are DREAMIN!!
    I am a bit concerned about the "DH moved away today" comment though. Seems a more serious than the tail light.
  5. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    remember... bad things come in threes... next it will be that rubber cover on the gas pedal...OH THE HUMANITY!!
  6. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    no worries, i had the turn off switch for glove box light break after less than 100 miles!!
  7. galaxee
    9,810
    471
    MD
    he's in school a couple hundred miles away until march. don't worry, we still see each other every couple of weeks.
    d'oh... DH already did that and glued it back on. :p wait, that was the parking brake pedal...
  8. Godiva
    Godiva AmeriKan Citizen
    10,339
    My parking break rubber pedal cover is already off, gone, lost. Not even going to replace it. If it turns up, I'll try to glue it on. But I'm not buying a replacement.
  9. Sheepdog
    1,125
    Sanford FLorida
    I could probably send you mine Godiva! I've never used it!
  10. Godiva
    10,339
    Deal!
  11. subarutoo
    subarutoo New Member
    1,213
    23
    Chatsworth, CA
    You guys think you have problems? Just 66,000 miles, and the little cover for the 12V socket under the dash broke and fell off!!! Oh, the humanity! I will try to limp along without the socket covered. It is the first problem in 2 1/2 years. Is this the start of something bigger? I hope not.
  12. AOV
    AOV New Member
    302
    Poughkeepsie, NY
    Thank you all! I am going shopping today....
    Let's see....what do I need....
    Headlight, the left side right?, taillights - both sides, cover for 12V socket, upper glove compartment spring, rubber cover on gas pedal, drive side door rubber....is my list complete? This way it will be the anticipated failures! :)
  13. galaxee
    9,810
    471
    MD
    always replace headlights in pairs.
    that's gonna add a big chunk to your total at the cash register. ;)
  14. Sufferin' Prius Envy
    Sufferin' Prius Envy Platinum Member
    3,998
    Unlike a halogen headlight which would be readily apparent when it burns out, there is no warning system built into the Prius (at least 2005 and earlier) to warn you when a tail light or side marker goes out.
    After 40,000+ miles, I felt totally let down by Toyota when it took having a brother call to inform me that I just drove off into the darkness with half my taillights out. Upon further inspection I found a front side marker burnt too. :rant:
    What the heck is Toyota trying to do? Kill us off with their lack of concern for our welfare, or are they trying to get us into accidents whereby we total the car and then go back to the dealer to purchase a replacement Prius? :suspicious:
  15. Sufferin' Prius Envy
    3,998
    Is that due to some electrical anomaly with the power supply, or if one halogen goes out, the other is not far behind?
    Orrrrrrr, is it that your DH is still not deprogrammed from Toyota's brainwashing of employees with the slimy tactic of upselling unsuspecting customers with that needless preventative maintenance ploy of replacing totally good parts with overpriced replacement parts and labor???? :suspicious: j/k
  16. galaxee
    9,810
    471
    MD
    if one goes, the other is likely about to follow suit. also, then the beams match in terms of brightness. they usually are available in 2-packs for a little cheaper than buying 2 bulbs individually... i think they cost $22 at advance auto down the road from us. just took DH a few minutes to pop them in. i also replaced both tail light bulbs when the one went. cost under $5 and it takes about a minute to replace them both.
    i know you were joking, but DH has made plenty of sacrifices to maintain his integrity. he quit the best paying/most physically optimal job he ever had several years ago over ethical considerations. also, he had several years of experience as a mechanic before he got into the toyota game so he has his own opinions about maintenance.
  17. Bill Lumbergh
    Bill Lumbergh USAF Aircraft Maintainer
    537
    NorCal
    That cover broke on mine the very first day. :(
  18. Sheepdog
    1,125
    Sanford FLorida
    speaking of the 12v outlet under the dash, my first issue is that it came out of the dash when I removed my gps power plug. it appears to be tightly hanging on to the plug. is the plug too tight or the gps plug too tight?
    not sure how to fix it.
  19. thecoook
    thecoook Junior Member
    38
    Sanford, FL
    Wow, the Prius reduces Light Pollution too.
  20. dogfriend
    7,512
    1,191
    Carmichael, CA
    Oh, noes.....this is obviously a problem for deaf people who cross the street at night. They won't be able to see the Prius coming at them if the headlights burn out. I had better write a letter to my representatives so they can introduce legislation to solve this potentially horrible problem. If they made the car glow in the dark, that would prevent a catastrophy. :madgrin:
