Android Head unit and OEM Camera and IPA possible?
Discussion in 'Gen 3 Prius Audio and Electronics' started by dancingbalu, Jul 24, 2020.
  1. billkeratea
    billkeratea New Member
    GREECE
    I have prius 2008 with ipa and i managed to install an android radio 7 inches with steering wheel button learning function.
    The original car radio-cd have 3 wiring connectors.The two of them connects to the new android stereo i bought and the last one with 20 pin connector has the three wires for the steering wheel signal.So i cut these three wires from the 20 pin connector (audio R5 connector) and soldered to the three wires of the new android i installed so i managed to learn the android the steering wheel buttons except the microphone.
    The problem was that the ipa was not working because the ipa uses other wires from that R5 connector and the original audio unit to work.i did not used the 8 ohm resistor and did that:
    1) Dissasemble the original unit, and took the audio electronic board with the back mettalic headsrink.
    2) I put that board in the dashboard and connected the R5 harrness conector to it.
    3) I soldered the 2 pins that send power to the board with the ignition wire from the car so to take power when i start the engine and the ground to the car ground.
    4) Now connect the two audio wires with my new android , the antennas for radio and gps and
    now i have all the steering wheel buttons working and the ipa working too.
    THE TOTAL COST WAS 85 EUROS FOR CHINNESE ANDROID 10 AUDIO AND 10 EUROS
    FOR TOYOTA ISO HARNESS.
    #21 billkeratea, Mar 8, 2021
  2. dancingbalu
    dancingbalu Junior Member
    39
    31
    Germany
    Wow thanks. Sounds complicated, but managable :D
  3. Umerpk
    Umerpk Junior Member
    24
    Pakistan
    Are the steering wheel controls working for android or OEM head unit?
  4. frnco
    frnco New Member
    San diego
    Hey Evoking does your installer have a shop or how would could I contact him. Thanks for all your info!
  5. eleka
    eleka New Member
    Spain
    Luxury
    Hi And thank you so much for the solution.
    Maybe do u have a youtube video? looks hard without pictures.
    Again, thank you. Great job :)
  6. black_jmyntrn
    black_jmyntrn Senior Member
    1,729
    410
    2013 Prius Plug-in
    this thread is golden! hey OP, did you ask me on Facebook if the Tesla style would work with the parking assistant?
