Android head unit google maps is slow
Discussion in 'Gen 3 Prius Accessories and Modifications' started by 123omari123, Jun 10, 2023.
  1. Leadfoot J. McCoalroller
    8,295
    7,814
    Pennsylvania
    2018 Prius c
    Shouldn't make any difference unless you've applied certain tint films.
    If you install a higher gain antenna inside the car, I'd keep it on the dashboard near the defrost vents.
    Back when GPS systems weren't as good and many needed exterior antennas, the best location was glued to the cowl trim near the windshield wipers.
    123omari123 likes this.
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Yes. Get the right harness for your specific JBL head and your specific model of car.
    P.S. Some locations around the world do not have good "public" GPS signals.
  3. 123omari123
    123omari123 Junior Member
    30
    Georgia,Tbilisi
    Can you clarify more what to buy?
    GPS signals in Georgia is great.
  4. sam spade 2
    7,035
    2,804
    2017 Prius c
    Where did you get your head unit ?
    A car stereo shop likely can get you what you need.
    Which Georgia is that......the State in the US, the city in Russia .......
    or somewhere else.
  5. 123omari123
    30
    Georgia,Tbilisi
    I bought it in country Georgia, there is not any city called Georgia in Russia.
  6. Montgomery
    Montgomery Senior Member
    2,254
    2,244
    Orange County, CA
    Just north of Armenia. I just looked it up on the map. Pleasure to meet you! You are literally on the other side of the Earth!.
  7. Montgomery
    2,254
    2,244
    Orange County, CA
    The pictures of your country are quite beautiful!
  8. Montgomery
    2,254
    2,244
    Orange County, CA
    Pardon my ignorance. I now see you list your city Tbilisi in your description.
  9. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Round 2.
  10. 123omari123
    30
    Georgia,Tbilisi
    Thanks.
    :D
  11. 123omari123
    30
    Georgia,Tbilisi
    Thanks.
    :D
  12. 123omari123
    30
    Georgia,Tbilisi
    My JBL sound system (2010) has 6 speakers(as I found out) but some people told me that only under windshield speakers are for sound/voice and other 4 (at the doors) are only for bass, is it right? also, I listened front door speakers and there are little bass only but low. Is it like that what to be?
    Can anyone tell me what is good GPS antenna, I found this -
    - but it only has GPS support not GLONASS. As I learned it will be good if GPS antenna has both systems support.
    Waterproof GPS Active Antenna 28dB Gain, 3-5VDC, SMA
  13. unofficial
    unofficial New Member
    Bangkok
    2003 Prius
    I installed the exact same model 4gb ram/4core/32gb.
    Exact same problem.
    Everything works fine, not Google Maps.
    Google Maps is super slow, freeze, and not responding.
    After 4 months I wanted to smash the screen because I bought it so I can use navigation in the first place. So I decided to do factory reset so I can remove it and sell the head unit online.
    Then a miracle happened, Google Maps works fine with the factory reset version. I tried updating it, then the old issue returns. I disable app to factory version and Google Maps work again.
    So now I drive happy everyday to work and home with my budget head unit. I update all apps and software, “except Google Maps”. Navigation only seems to work well and smooth with old version, so “I don’t update Google Maps”.
    Anyways, hello from Bangkok. I don’t even own a Prius, I drive Toyota Vios 2003. I came across your post because I try to fix issue with the same head unit we got.
    I made this account just to reply you this, so don’t expect me to be active and reply. I really hope my solution will work for you if you have not solve the issue yet. Or at least I hope my answer will help someone who is facing the same issue.
    Good luck!!!
