Anemic performance in the mountains
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by srivenkat, Jan 6, 2021.
  1. srivenkat
    srivenkat Active Member
    596
    93
    IL
    Hi All,
    I picked up my new 2021 Prime XLE in Catonsville, MD and while driving it home to Illinois, I noticed the car was struggling to climb in the mountains around Cumberland, MD thru Morganstown, WV. With the accelerator pedal pressed down to be just before entering PWR range, the best it could do was 34MPH in the 55MPH zone. I was quite surprised by this. I did momentarily go into the PWR range but it didn't help matters much. Even trucks were crossing me at 55MPH. Anyone else noticed this kind of (lack of) performance in the mountains?
    I did add Shell gasoline towards the end of the 700 mile trip home but although I ran out of the mountains by that time, the performance on the interstate still seemed to be generally lacking.
    I am almost thinking about taking it into the dealer.
    Thanks in advance for your thoughts on what could be wrong.
    #1 srivenkat, Jan 6, 2021
  2. JimboPalmer
    12,470
    6,870
    Greenwood MS USA
    Use the entire pedal travel, that is why it is there: for hills.
    #2 JimboPalmer, Jan 6, 2021
  3. john1701a
    john1701a Prius Guru
    12,760
    5,246
    57
    Being apprehensive with the pedal is a common newbie behavior... hence the recommendation: Just Drive It.
    My experience is going 80 mph in the rolling climbs through Wyoming and 70 mph through the Black Hills of South Dakota. Neither was an issue.
  4. srivenkat
    596
    93
    IL
    Thanks. I would have persisted with PWR and probably would have done the entire pedal travel, but for Toyota's brake-in recommendations for the first 600 miles. In retrospect I probably should have looked for a non-mountainous route. But I am still surprised by the meagre performance to the point I am wondering if what I saw is normal.
  5. srivenkat
    596
    93
    IL
    No doubt I was trying to be extra cautious during the brake-in phase, but I have been driving the Prius since 2011 and a Prime since 2020 although on flat Illinois lands.
  6. ChapmanF
    15,865
    1.If you don't ask for full power, you don't get full power.
    2. Even if you do ask for full power, you get 121 HP. It is a Prius....
  7. Leadfoot J. McCoalroller
    7,239
    6,784
    Pennsylvania
    2018 Prius c
    The first rule of brute force is that if it doesn't work, you aren't using enough.
    Mash that pedal flat.
    Prius Maximus and jerrymildred like this.
  8. JimboPalmer
    12,470
    6,870
    Greenwood MS USA
    I have an odd perspective as my Prius is the second most powerful car I have ever owned. (least powerful was 59 HP in 1977)
    My Subaru Forester had 45 more HP but the AWD added quite a bit of friction that made it seem less powerful.
    srivenkat likes this.
  9. srivenkat
    596
    93
    IL
    IIRC, I was seeing about 2400RPM on the SGII at the time it was doing 34MPH on the 55MPH zone.
  10. srivenkat
    596
    93
    IL
    Thanks. Do you recall doing a lot of pedal-to-the-metal in those drives?
  11. ChapmanF
    15,865
    Have to get to 5200 to be at full power.
    Aaron Vitolins and srivenkat like this.
  12. dbstoo
    dbstoo Senior Member
    1,358
    725
    Near Silicon Valley
    2024 Prius Prime
    XSE Premium
    What you saw is normal. If you take a mustang and only give it 1/2 gas pedal it will bog down on an up hill climb too. You TOLD the car that you only wanted to go 35 MPH.
    I tell newbies that the hybrid gas pedal is NOT connected to the engine. It does not make the engine go faster or slower It is not an accelerator. It's a 'speed pedal' that tells the car that you want to go faster or slower. The car then decides how much power it needs and where to get it.
    The one thing that took me the longest to get used to on my first hybrid was that I could not judge my speed by the sound of the engine.
    Dan
    pghyndman likes this.
  13. john1701a
    12,760
    5,246
    57
    Yes, when passing trucks at +90 mph.
  14. bisco
    49,695
    were you in power mode?
    i feel like my pip is less powerful with mostly engine vs my gen 2, i wonder if that legacy continues?
  15. dbstoo
    1,358
    725
    Near Silicon Valley
    2024 Prius Prime
    XSE Premium
    For the record... I've taken my prime through hill and dale as well as over mountain ranges and up looooong inclines. No Anemic performance. ***
    Dan
    *** Well, the first day, I expected the acceleration would be the same on the freeway on-ramp as it was on at a traffic light. I had it in eco mode so it accelerated slowly ans smoothly. I still got up to speed well ahead of the end of the on-ramp, but was expecting it to feel as fast as it looked. :)
  16. srivenkat
    596
    93
    IL
    Yes, I was in Power mode in hopes that would cause more of the approximately 3% of the remaining charge in the traction battery to be used.
  17. Leadfoot J. McCoalroller
    7,239
    6,784
    Pennsylvania
    2018 Prius c
    I don't know that power mode does any specific apportionment of power in a prime. In the regular models, it just remaps the accelerator pedal somewhat, so you don't have to push it quite as far to achieve high demand. The hybrid computer splits the duty however it normally does while responding to the extra demand.
    0% is still 0% and 100% is still 100% but it's got a curve to it- now 50% pedal gives 80% result.
    Looking back to the bigger picture: I'll be blunt- there's just no way that car will climb a hill like that, at speed, with a low traction battery, without that engine joyously singing the song of its people at 5000+rpm.
    And that's fine, even during break-in, at least for short periods.
    If anything, it's of great benefit to cycle between high rpm and low rpm during break-in.
    The car was built with just enough power to handle these mountain highways, but only if you use the entire powerplant- even the loud parts.
    #17 Leadfoot J. McCoalroller, Jan 7, 2021
    fuzzy1 and srivenkat like this.
  18. srivenkat
    596
    93
    IL
    I had heard about the modes simply remapping the pedal response with some AC economy in the Eco mode, but I always had the seat-of-the-pants feeling of instant battery torque when driving in Power mode in my 2010 Prius. I found last evening that what you mentioned about 5000+ RPM is true; I took my "older" 2020 Prime out on the interstate and did the pedal-to-the-metal (that I had done once or twice in my life in my Camry in emergencies) thing, maxing out at 5184 RPM and the car did go from 65 to 90 quickly.
    @2k1Toaster assures in the below relevant post that it's impossible to redline the Prius.
    #6
  19. jerrymildred
    jerrymildred Senior Member
    11,518
    14,124
    Tampa, FL
    WOT is WOT, no matter what the mode you have selected. I love ECO mode because, at low speeds in EV, I can accurately modulate the "go pedal" to keep the instantaneous m/kWh bar close to where I want it. PWR mode is way too twitchy at low speeds for that kind of fine control. And if I punch it, the result is the same in all modes.
    Tideland Prius and srivenkat like this.
  20. Leadfoot J. McCoalroller
    7,239
    6,784
    Pennsylvania
    2018 Prius c
    This is an important point.
    The system is well managed and has years of debugging done by now. If that car is in READY mode & D gear, nothing you do to the skinny pedal will over-rev the engine.
    Feel confident.
    srivenkat and jerrymildred like this.
