Angled Joint Spark Plug Socket
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Siward, Nov 4, 2018.
  1. Siward
    Siward Active Member
    296
    124
    Toronto
    I saw this angled join spark plug socket online and was thinking if this could bypass the need to remove the wiper blade assembly to replace spark plugs on the gen3 Prius.
    9/16 in. Universal Joint Magnetic Spark Plug Socket | Princess Auto
    Maybe? Maybe not. I guess it would depend how wide the spark plug hole is and how far you can bend the joint away from the cover.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,482
    Bay Area, California
    2019 Prius Prime
    The coils will not fit out;).
    But a good tool to have for other reasons(y).
    Mendel Leisk and m.wynn like this.
  3. ASRDogman
    ASRDogman Senior Member
    6,093
    3,273
    It's VERY easy to remove the Wiper assembly and housing(?) assembly. 10-20 job.
    Less than 30 if it's your first time. But very simple. Then you'll a lot of room with simple tools.
    NutzAboutBolts - YouTube
    m.wynn and Raytheeagle like this.
  4. Pluggo
    Pluggo Senior Member
    608
    532
    Folsom, Pennsylvania
    Angled adapters can be a life-saver for loosening things, but they make it harder to get a good feel when tightening anything slightly delicate like a spark plug, and a torque wrench is only accurate when it's lined up with the work.
  5. m.wynn
    m.wynn Senior Member
    684
    1,226
    Queensbury, NY
    Add me to the pile. Totally agree with every point made thus far. Plus, having the wiper tray out of the way makes it super easy (or at least a lot easier) to wipe up the mess from the notorious "timing chain cover leak":eek:.
    Raytheeagle likes this.
  6. Mendel Leisk
    38,733
    Yeah, they need to put some sorta flexible elbow in the friggin' coil. :cautious:
    This is the set I got btw, good deal, good quality:
    4 pc Swivel Spark Plug Socket Set | Princess Auto
    Great store btw. When I was a kid I used to love cruising the basement of Army and Navy, all the surplus, camping gear, what have you. I get the same feeling in Princess Auto.
  7. Eddy Connelly
    Eddy Connelly Member
    37
    27
    New York
    A leak!?
