Annoying Phone Data/Roaming warning? How to turn it off
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by priuskitty, Aug 26, 2012.
  1. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    I figured out how to turn off the annoying Data/Roaming cost message that appears when you start Pandora for example. Go to Setup (on PIP base model) then select phone, then paired device list, then you will see connect for internet, to the right of this message is a little wheel like tool icon, click on that and wala you will see check marks on Data warning and roaming warning, uncheck those and wala! no more warnings every time you access Pandora or Iheart Radio, etc, etc.
    genetiix likes this.
  2. Captain PIP
    Captain PIP Piloti di Hybridi
    17
    Planet 951
    Brilliant! I will go out and do that right now.
  3. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    always willing to help out fellow Priustees
  4. Captain PIP
    17
    Planet 951
    I was unable to stop the ridiculous messages with this procedure. I am sure it may work if you were using Bluetooth to access the internet while not using Entune. I use Entune on an Apple iPhone 4s that is connected to the system via USB. Toyota reps, I know your out there. Entune engineers I know your our there too! Please, please make the messages go away!
  5. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    ah.....usb....sorry:cry:
