Annoying wire problem solved.
Discussion in 'Gen 3 Prius Accessories and Modifications' started by alfa737, Nov 22, 2011.
  1. alfa737
    alfa737 Member
    126
    27
    Hi guys.
    Is it me or is this is an annoying design flaw.... to hook up a regular MP3 player (NOT THE IPOD, ITOUCH ETC) the AUX jack and the 12V chargeing socket are located inside the center console... with no access to it if the lid is closed.. so how are you supposed to change the tracks etc... now if you keep the MP3 player outside the center console then the wires wont let you close the lid completly...:eek:
    HELLO!!!
    So here is what i did...
    I made two holes, passed the wires thru. Now the lid closes and i can get to my MP3 player...
    anyone else think toyota overlooked this issue.
    I am not talking about IPOD adapter cable, this is for 2011 prius II.
  2. roypaik
    roypaik Member
    161
    39
    Orange County
    2020 Prius Prime
    good idea!
  3. tomtomsf
    tomtomsf Junior Member
    36
    Half Moon Bay
    Yes, it is a poor design.
    And the placement of the connectors at the back edge of the center console box is also inconvenient. I don't see what they were thinking with that design.
    Tom G.
  4. teiresias
    teiresias Junior Member
    61
    Hampton, VA
    I imagine it was designed that way with mainly the iPod USB connection in mind, and the usability when the USB turns into a plain old Aux input wasn't really thought through. Unfortunately, people assume no one is going to use anything but Apple products nowadays (at least when it comes to MP3 players).
    When I get a new headunit that will have USB I'm actually going to run the USB into the top glove box - that seems a better place for it (assuming the USB powers/charges the device/iPod of course).
  5. alfa737
    alfa737 Member
    126
    27
    I am thinking of placing an aux Jack in that tray area. where they have the heated seats button (if you have heated seats). but I dont know how to split the aux input at the back of the head unit...
    can i just hook up a splitter?
    anyone done that?
  6. frodoz737
    frodoz737 Top Wrench
    4,763
    2,539
    33
    " When I get a new headunit that will have USB I'm actually going to run the USB into the top glove box - that seems a better place for it (assuming the USB powers/charges the device/iPod of course). "
    Just a heads up opinion as I did run mine to the upper glove box (see gallery). If done again, I would run then to the panel under the bridge with the cigarette lighter. I would also plug my Apple adapter harness directly into the HU so only two USBs are visible. My stealth install is less practical because of the reach from the drivers side. Determine your primarily use of the port/s before deciding, as it may be different than mine. Console port is deactivated.
  7. frodoz737
    4,763
    2,539
    33
    Don't use a spliter because you loose gain/signal.
  8. alfa737
    alfa737 Member
    126
    27
    I saw your audio MODs... that is awsome work.. thanks for sharing...
    so how do i take the aux from the back of the HU to the tray area next to the charging port?.. i dont want to cut into the cars harness..
  9. frodoz737
    4,763
    2,539
    33
    My runs are dedicated from the new HU. The AUX is just not used.
    You can "move" the existing AUX cable where ever you like if using stock HU. It's a simple relocate. There are links here for access. Have to go load the car for our Thanksgiving trip. Will chime in later.
