Another Battery Degradation Thread
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by markabele, May 20, 2014.
  1. markabele
    5,084
    1,782
    Nebraska
    Only starting this new one because the search function seems to be completely unusable at the moment....so...
    My question is, since we are at or over the 2 year mark for quite a few owners on here we certainly have to be seeing some battery degradation, correct?
    What are the best metrics for measuring degradation (other than seeing how far you can go on a full charge)?
    Would love to get a good discussion going about this.
    Note, we are only talking about the PiP battery in this thread. Any posts regarding batteries of other cars would most likely be self serving.
  2. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    I have had my PIP since April 2012 and have noticed no apparent degradation
    SM-G900T ?
    Godzuki likes this.
  3. Tracksyde
    Tracksyde Member
    1,429
    762
    So Cal
    I always though the best way, given what I have at my disposal, would be to just check SoC using something like Torque when I've run out of EV range.. then full-charge it at a Chargepoint (or your 120V EVSE with a Kill-A-Watt) and then see how many kW it takes to fill it up.
    Sadly, I dont have any kW data.. and when I started using a Chargepoint at work, I wasnt using Torque. I guess I should do that soon, just to get a baseline 2+ years in.. better late than never
    Battery degradation is something I do think about from time to time.. especially on those days this past winter when I'd barely make it to work. But then, there are those days where I make it to work with over 3 miles EV left.. and now that the temps are more normal (70s-80s), I get to work with about 2 miles of EV left.. which is kind of what I remember it being last year.. or the year before.
    So assuming there is degradation (which I'm thinking there should be), I would say its not noticeable to me yet.
    Something else I considered was.. when the PiP's battery loses 10% of its useable capacity.. that'd take me down from about 12 miles average to about 10.8 miles average.. hardly noticeable, esp with traffic lights, stop signs, traffic, etc. In a car with a bigger battery, a 10% reduction would make me sad.. real sad
  4. markabele
    5,084
    1,782
    Nebraska
    This is what I'm thinking, too. I think there has been some degradation but people either don't notice it yet or people are looking at it only through rose colored glasses.
  5. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    :cool:
  6. Jeff N
    Jeff N The answer is 0042
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    Another aspect is that any EV range reduction from degradation may be small enough to be masked by improving LRR as the original tires wear down.
    NeillThomas likes this.
  7. bisco
    52,767
    i was just thinking about this today on my way to work. without rigid test comparisons, it is difficult to know. there are too many factors involved. but i agree, there must be some continual degradation. i used to be able to do my commute with a mile or so left when i got home. now that the weather is finally starting to cooperate, i will start watching more carefully.
  8. markabele
    5,084
    1,782
    Nebraska
    That's very true, Jeff. Honestly I wouldn't be surprised if the effect is pretty much a 1:1 ratio.
  9. kabin
    kabin Member
    167
    Scottsdale, AZ
    Probably more noticeable in hot climates if at all. Unfortunately, Toyota isn't encouraging sales in AZ.
  10. Jeff N
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    There's one obvious speculation why.... maybe it's the "LEAF effect". Valid or not, the fear of bad PR around the potential for battery heat problems may have scared them into effectively silently dropping Arizona from their PiP sales region list. Nobody seems to really know what's going on with PiP sales there.
  11. Phausto
    Phausto Junior Member
    75
    16
    Pacific NW
    No data other than anecdotal here either, but I’ve noticed no difference. The seasonal (cold/warm) is >10% for me. However, when I drive the same route and experiment a bit, I’ve been able to improve my trip mpg by 50-100% in cases. There will be a tipping point for battery capacity vs my expanding ability to wring out EV miles; I hope it is still quite some time away.
  12. evfinder
    evfinder Member
    293
    72
    My range bounces around the 10.1 to 10.3 range, down from around 12.5 miles 2 years ago. I think that has more to do with my current 1 mile commute in heavy traffic with lots of stop signs and lights. Chargepoint reports that I use 2.6 - 2.8 kwh when I charge with them but that's only about every other week.
  13. Astolat
    Astolat Member
    229
    73
    Guildford UK
    This would seem an appropriate thread to post a link to an official UK Toyota blog post answering questions submitted prior to the PiP launch here: Toyota Prius Plug-in: your questions answered « Toyota UK news, reviews, video and pictures
    About two thirds of the way down the article there is a q about the battery warranty, which is 8 yrs here. But underneath it there is a q about expected battery life that has the answer that the traction battery is expected to last the life of the car.
    Obviously we tend not to have extremes of climate, but that is a useful promise. I must take a screenshot of it, just in case...
  14. bisco
    52,767
    i can't even start testing yet. may 24th and the temps are still in the 50's. definitely not optimum weather. my range is up to 14.1, but the high last year was 16+.
  15. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    I'm looking forward to those optimum conditions. I carefully noted a route when I first got the plug-in 2 years ago. The expectation is to see the same results on year 3.
  16. bisco
    52,767
    i did the same thing on my commute. every turn, stop, street sign, etc., i have the ev guetimate reading. last year was about the same as the first year, so this will be a good test. unfortunately, these are not lab conditions, you just have to wait for the almost perfect day and try to drive similarly.
  17. retired4999
    2,652
    627
    Eau Claire, Wi.
    Your doing good. (y) I'm all they way up to 10.5.
    Temps starting Sunday Low 80's for the next week!
    Things will get better. :)
  18. bilbo04096
    bilbo04096 Member
    136
    26
    Yarmouth, Maine
    2013 Prius Plug-in
    Bisco, same weather here too, awfully raw right now. My EV range oddly enough has been 15.3-15.4 for about a month. Go figure...
  19. bisco
    52,767
    that is amazing! i drove 16 miles today at 22 mph average, but that doesn't mean much. temp was all the way up to 64 degrees, woo hoo!:cool:
    retired4999 likes this.
  20. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    I just did my commute to work and back. estimated + actual miles = 11.4 miles! whoo hoo!:D
    Of course I mean all EV travel. I only travelled 5.8 miles but had 5.6 EV left
