Another Battery Degradation Thread
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by markabele, May 20, 2014.
  1. markabele
    5,084
    1,782
    Nebraska
    That's the assumption. But no one will obviously know for sure for quite a few years yet.
  2. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    Under the same conditions? How do you do that? Even in a Lab, the same conditions are not always attained. So most of our assumptions, thoughts are really just guesses about what we think is so.
  3. Andyprius1
    2,327
    859
    Cool CA
    But, glad to hear you're getting 14 miles again. :)
  4. pwp1943
    pwp1943 PHEV Afficionado
    51
    Boston
    2013 Prius Plug-in
    Here are my observations. It is not at all scientific, only what I've seen. I bought my PIP last summer and the EV miles gauge always showed over 14 miles after a full charge. As the cold weather moved in the gauge slowly fell until Jan/Feb/Mar 2014 when it was about 11 EV miles after a charge. As the temperatures have started to go up here in New England my gauge has risen to between 13.8 and 14.1 after a full charge. When we actually get to summer, I speculate that I will be always above 14 EV miles. As a point of reference, I have an enclosed garage with level 2 charging. The outside temperature on the Prius LED display never went below 25F even during the days we were at 0F overnight. If this thread is still alive in July, I will post my observations again but I expect to see 14+ EV miles for Jun/Jul/Aug.
  5. fortytwok
    fortytwok Active Member
    467
    139
    Hopkinton MA
    2013 Prius Plug-in
    Finally - warming up nicely here and looking at 12 mo old Chargepoint reports plus my actual EV miles on my standard everyday drives I'm seeing no difference at all.
    To answer that earlier post - if the degradation is this small each year I don't care at all. I get 15-16 actual in good weather so if that drops even 10% total over 7-10 yrs I'm good. I don't use gas now and I wouldn't then given my routine.
    but If I was trying to make back that premium over say the Prius3 - and my commute was more like a 50-50...
    Sounds like no one is seeing a measurable drop though so lets worry about something else
  6. bisco
    52,871
    the red sox dropped a tough one last nite...
  7. bilbo04096
    bilbo04096 Member
    136
    26
    Yarmouth, Maine
    2013 Prius Plug-in
    battery degradation...
    bisco and priuskitty like this.
  8. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    The attached text files are CSV format.
    They contain the raw data I captured for detail about battery-temperature.
    34.7 miles round trip (24 EV, 10 HV). 2 full charges. 186 MPG overall.
  9. markabele
    5,084
    1,782
    Nebraska
    Really appreciate you getting the data. Now if I could make sense out of all those values, haha.
  10. john1701a
    12,840
    5,312
    58
    I'll have a chance at some point to generate some graphs from the data. It should go a long way toward ending the FUD being spread due to lack of real-world data and such a wide variety of chemistry types available. In the meantime, I'll keep gathering.
    The other day on the drive home, it was 76°F out. I did hill climbing and a bit of 55 mph along the way, staying in EV for the entire capacity. The battery-pack temperature stayed just below the 100°F mark. I believe that is the normal operating expectation for continuous discharge of the type in Prius.
    We'll see what happens when it gets hotter out. But since most people simply use their A/C and the engine is there to protect the battery-pack, it's hardly a concern the rhetoric would lead us to believe.
    markabele likes this.
  11. bisco
    52,871
    the best i did on my commute when i first got the car was about 2 miles left when i got home. yesterday, at 70 degrees, i had 1.6 miles. this is far from controlled testing, but it's all we have. i will keep monitoring.
  12. john1701a
    12,840
    5,312
    58
    It's quickly becoming obvious that the claims of liquid-cooling is necessary for battery longevity were acts of desperation to undermine.
    Today it was 79°F on the drive home. The 12 consecutive miles of EV driving I did never pushed battery temperature above 100°F, without anything but open windows to provide cooling.
    The electric A/C is available and will be used when it gets hotter out while driving. That will make the air available for cooling even cooler. So, there's nothing they can argue. The A/C could even run as part of the recharging process. Toyota didn't find that necessary though. The chemistry chosen is proving worthy without the need for liquid.
    By the way, I can turn it on remotely from my phone now using Entune. It does a very nice job of cooling the interior. 10 minutes of running consumes roughly 0.2 kWh of electricity.
  13. ny_rob
    ny_rob Senior Member
    1,968
    814
    L.I.- NY
    Dates, prunes and figs will help with that... and they're all natural :D
    rxlawdude and bisco like this.
  14. markabele
    5,084
    1,782
    Nebraska
    I'm sure that number can vary wildly considering multiple variables.
  15. Troy Heagy
    Troy Heagy Member
    1,218
    According to Nissan, who regularly communicates with owners of the Leaf, they consider it "normal" for the battery to lose 30% of its capacity in 2-3 years, and then hold steady for the rest of its life. Perhaps the same is true of the Lithium battery in the Prius plugin
  16. john1701a
    12,840
    5,312
    58
    What would the variables be?
    My observation was from turning the A/C remotely with the vehicle not being driven or even the hybrid system on.
  17. john1701a
    12,840
    5,312
    58
    Nope. Prius is not an EV. It is not depending exclusively on the battery-pack for power.
    So far, 2 years and 3 months later, I have seen 0% capacity loss. I'm still reaching the same conditions under the same circumstances as I did when the car was branch new.
  18. john1701a
    12,840
    5,312
    58
    Getting back on the liquid cooling rhetoric... another reality hit me. The electric-drive in Prius is more efficient than Volt. As a result, less waste heat will be generated... hence less of a need for cooling.
  19. markabele
    5,084
    1,782
    Nebraska
    Temp outside, temp desired inside, whether you are parked in sunlight or not
  20. john1701a
    12,840
    5,312
    58
    My comment was only about consumption-rate, generic operation, not a specific goal.
    Today's drive home provided a nice subject-matter example. It was hot & humid. So, I used the A/C the whole time. The air-temperature measured for battery-intake was lower than it would have been with the windows open. The temperature of the battery itself was too.
    If we know that the battery is just fine under normal conditions and running the A/C for extra cooling in the hot, where's the supposed problem?
