Another Battery Degradation Thread
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by markabele, May 20, 2014.
  1. roflwaffle
    roflwaffle Member
    381
    77
    Orange County
    The only one I can think of is charging to full immediately after a drive with the windows rolled up on a 100+F day.
  2. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    The battery would be a comfortable temperature due to the A/C cooling the interior air.
    But since that doesn't follow the best-practice of allowing a "cold soak" and certainly isn't necessary, why would you do that?
    Waiting until the evening is also better from a grid & expense approach.
    Since EV don't have that flexibility, they are in a very different situation than Prius with an extremely efficient engine to use after depletion.
  3. roflwaffle
    roflwaffle Member
    381
    77
    Orange County
    The PIP cycles the AC when it's charging? Neat.
    I've had a few situations where I've charged immediately after a drive b/c I'm heading out again in a couple hours, but I generally crack the windows.
    My wife otoh, generally leaves the windows up.
  4. john1701a
    12,840
    5,312
    58
    No, that hasn't been necessary. But the option for cooling to be part of the process is available. It's just software update to make it automatic. Of course, that would be twisted into a recall. You can't win.
  5. Troy Heagy
    Troy Heagy Member
    1,218
    People charge at work.
  6. john1701a
    12,840
    5,312
    58
    That allows plenty of time for a cold soak. What is your point?
  7. john1701a
    12,840
    5,312
    58
    I plugged in this afternoon at work. The Prius was already warm from having taken it for lunch, with the windows open to enjoy the fresh air. It sat windows shut in the parking lot as the surface-temperature climbed to 90°F while recharging. That was quite a bit warmer than my previous data collecting. I was excited about the opportunity that presented. The air-temperature was 86°F, just at the tolerable limit for driving without the A/C use. I lowered all the windows and headed home.
    The temperature of the battery-pack stayed within the comfort-zone, despite being warmer outside. It peaked for EV at 100.2°F, which was right as the plug-supplied capacity ran out. While warming up in HV, the Prius was required to climb a hill at 55 mph. That pushed it to 101.5°F before dropping back down and staying down.
    I'd consider that a worthwhile sample for warm-weather driving. Any hotter and most of us would simply turn on the A/C instead, which drops the temperature of the intake-air quite a bit.
    Attached is the data in CSV format.
  8. bisco
    52,767
    57 degrees here yesterday.
  9. retired4999
    2,652
    627
    Eau Claire, Wi.
    Nice! :whistle:
  10. bilbo04096
    bilbo04096 Member
    136
    26
    Yarmouth, Maine
    2013 Prius Plug-in
    But near 80 today - go out and warm up that battery!
  11. bisco
    52,767
    i'm hearing 85! i might have to try my commute, even though it's saturday.
  12. bilbo04096
    bilbo04096 Member
    136
    26
    Yarmouth, Maine
    2013 Prius Plug-in
    Fantasy weekend, go for it!:whistle:
  13. Astolat
    Astolat Member
    229
    73
    Guildford UK
    So we've got Bisco commuting to work even though it's not a work day, and john1701a excited about being able to drive off in a sweltering hot car. Does anyone think we might need help....?:eek:
    -Rozi- and markabele like this.
  14. john1701a
    12,840
    5,312
    58
    54°F and rainy this morning. Sweltering heat and dry would be much better.
    The Prius has been yearning to go on a kayak trip, to show off its practical side...
    #94 john1701a, Jun 7, 2014
  15. bisco
    52,767
    this maybe the year of weather extremes.
  16. bisco
    52,767
    duly noted.:p
  17. Jeff N
    Jeff N The answer is 0042
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    So, you're going to slip the green kayak under the driver-side wheels and the red one under the passenger wheels and then sit on the roof with a long paddle and drift lazily down the river?
    That really is an example of something I can't do with my Volt.
    Good luck! ;)
    -Rozi-, rxlawdude and markabele like this.
  18. retired4999
    2,652
    627
    Eau Claire, Wi.
    I'm fine! I'll stay home today. :D
  19. bisco
    52,767
    what, no coffee, now that it's above zero?:cool:
  20. retired4999
    2,652
    627
    Eau Claire, Wi.
    Of course coffee!
    Things have changed a little bit though. I am not taking my daughter to work any more, the wife is!
    I count coffee as being at home!:p
