Another benefit of Synthetic Oil
Discussion in 'Gen 2 Prius Main Forum' started by morpheusx, May 5, 2008.
  1. morpheusx
    morpheusx Professor Chaos
    1,555
    81
    Akron, OH
    I finally got around to mowing the grass this weekend. The grass had gotten a tad on the thick side as I have been too busy (lazy) to cut it. As I do every year I changed the oil to start the season with fresh oil. My mower just calls for 20 ounces of SAE 30 oil, so I decided to just dump in some left over 5w30 Castrol Syntec from my last oil change,. I have never used synthetic oil in a mower before because it just seems unnecessary. Anyway my yard is approximately 1/2 acre lot and the mower typically runs out of fuel as I'm finishing the yard and I have to add just a bit of gas to finish up. Today I finished the entire yard with out having to fill up and out of my curiosity I opened up the gas cap and looked inside, amazingly to my surprise there appears to be at least a quarter to half tank of gas left in the tank. I wasn't expecting any benefit at all so I was surprised.
  2. Sufferin' Prius Envy
    Sufferin' Prius Envy Platinum Member
    3,998
    And just imagine how many extra feet a Hummer would drive if you add synthetic oil. :pound:
  3. Prius 07
    Prius 07 Member
    715
    Toronto, Canada
    Small World - I did the same thing (even the same brand and type) with my lawnmower (first time) last weekend.
  4. Prius 07
    Prius 07 Member
    715
    Toronto, Canada
    duplicate -sorry
  5. bbald123
    bbald123 Thermodynamics Law Enforcement
    386
    271
    Harrisburg, PA
    I've had mowers that specifically warned against multi-viscosity oils of any kind.
    You might want to check your manual.
  6. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Most air cooled motors do recommend against multi-vis oils, unless very cold. A typical generator, water pump, lawnmower, etc will spec SAE 30
    Most small Honda motors "allow" SAE 30 but prefer 10W-30. I guess you go with what works best. If there was no smoky exhaust, keep using it
  7. dogfriend
    7,512
    1,188
    Carmichael, CA
    I wonder if this is because they are concerned about the effects of the Viscosity Improvers (polymers) added to create multi visocity oil out of plain old dino base oil? If so, it seems like synthetics would not have the same issue since they have little or no viscosity improvers.
    I just gave away my lawn mower with a B&S engine and they recommend SAE 30 unless operating below 40°F. No one in California would be mowing their lawn when it was below 40°. :pound:
  8. animalcontrol
    animalcontrol If my mouth moves, ignore me!
    68
    Greenwood, IN
    You must have a small yard....or are very lucky.
    Most (I'm giving the benefit of the doubt here) small 4 cycle motors REQUIRE a heavier oil, like 30W. Hence, 5W-30 is too thin and won't protect your motor.
    It would appear that synthetic is better than dino oil in this case also...I also tried this experiment in my younger days...replaced 30W oil with dino 10W-30. BOOM! Mower didn't finish the yard 1 time!
    Check your manual...you might need to drain and refill.
  9. Winston
    Winston Member
    614
    SF Bay Area, California
    There is no reason that the motor would be harmed with a 10W-30 or a 5W-30 oil. Multigrade oils are not thinner that an SAE 30 oil.
    Briggs and Stratton motors will run for hours without ANY oil in them. B&S did a test to show that because so many oil additive companies would treat the B&S engine, then drain the oil and say "See our additive is so good the engine does not need oil anymore!" It was not the additive that allowed the engine to run for hours, it was the durability of the engine.
  10. problemchild
    problemchild New Member
    429
    36
    HORRIBLE IDEA-------------WARNING!
    You will damage the engine mixing syn and non-syn oils. I did that by accident and had to rebuild my motorcycle engine when it messed up the cylinder and rings.
  11. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    Been using synthetic in 3 mowers over the last few years wih no problems.
    knettle3 likes this.
  12. OrlandoGuy
    OrlandoGuy Junior Member
    98
    Orlando, FL
    I have a generator with a B&S engine that does recommend both a multi grade oil - 5W-30 and using synthetic oil saying that using synthetic will help prevent oil loss during running.
  13. xsmatt81
    xsmatt81 non-AARP Member
    522
    Vegas
    very cool.
    I have an electric mower, for our 34x46 ft patch of grass heh
  14. jayman
    13,439
    641
    Winnipeg Manitoba
    I think a lot of the older engines were pretty ancient with respect to what they believed to be oil quality. Modern small motors, especially Honda (Lawn mower, generator, etc) specifically state to use a 10W-30, not a straight 30
    Toyota is guilty of this too. My FJ has some odd requirements for gear oil. Front axle is 75W-90, GL-5 (A current spec). Transfer case is 75W-90, GL-3, a spec that has been obsolete for almost 25 years. GL-5 works for this spec
    The rear axle is the puzzler. Toyota states to use a straight SAE 90 gear oil, unless below 0 F in which case an 80W-90 may be used. Well, first of all, where outside of the Mid East, India, Mexico, Australia, or desert African countries can one readily find a straight SAE 90 gear oil?
    I hope Toyota doesn't factory fill the FJ with SAE 90. It turns solid as a brick below +5 F. I drained and refilled with Mobil Delvac Synthetic 75W-90
    Second of all, even with an 80W-90, that is unsuitable below -18 F. Again, some odd specs out there
  15. dogfriend
    7,512
    1,188
    Carmichael, CA
    I used to work for a Class 8 truck manufacturer (name starts with a P) back in the 80's. I was on a visit to a dealer in Prince George, BC and they complained to me that the rear axle lube put in at the factory was completely unsuitable for their conditions. The first thing they did during PDI was to drain the axles and replace the lube with something that wouldn't turn into a solid at -20.
    Back to the Topic - I found this:
    http://www.briggsandstratton.com/maint_repair/parts_supplies/details.aspx?pid=100074
  16. jayman
    13,439
    641
    Winnipeg Manitoba
    Yep, at one time Dana, Rockwell, etc used to spec either a straight 90, or something like an 85W-140. Now pretty much every HD axle is factory filled with a synthetic 75W-90
    Interesting about B&S motors. I guess they've come a long way from those ancient valve-in-head things
  17. Earthling
    Earthling New Member
    441
    Somewhere, NY
    I don't know what kind of bike you have, but my BMW motorcycle owner's manual allows full synthetic or dino oil, as long as the viscosity is appropriate for conditions.
    I've run dino oil and full synthetic, switching back and forth and have never seen any problem. Read the label on Mobil 1, and it will tell you it's compatible with conventional motor oil.
    I also have run Mobil 1 in my lawn mower, with a Briggs & Stratton engine. While that may seem like overkill to some, the motor only holds 0.6 quarts, and it has no oil pump. To me, this type of motor needs synthetic oil more than any other engine. This lawn mower has lasted a very long time, with no signs of blue smoke.
    Harry
    PS: there might be an issue with wet-clutch motorcycles. My BMW bike has a dry clutch, so the gear oil stays separate from the motor oil.
  18. jayman
    13,439
    641
    Winnipeg Manitoba
    I missed this the first time around. That was certainly true enough, especially in the early to mid 1970's when multigrade oil was *real* crap
    We had just moved to Utah and my dad always ran a diesel rated SAE 30 in the Galaxy in summer, a 20 with a bit of kerosene in winter. That motor lasted a very long time
    But if even Briggs and Stratton now recommend a multi-vis, they've improved their motors and the oils are also good enough now to run a 5W-30 or 10W-30
  19. jayman
    13,439
    641
    Winnipeg Manitoba
    I don't know much about motorcycles, except that a lot of motorcycle oils have special additives for wet clutch use
    A lot of industrial and commerical heavy duty equipment uses wet clutch, wet brake, wet PTO clutch, etc. The oils are specially blended to prevent chatter/grabbing of the clutch, and to prevent clutch glazing
  20. racerbob
    racerbob Member
    138
    S Florida
    Mobil claims they do not use friction modifiers in their motorcycle oils. Makes sense, as they can cause the clutch to slip due to reduced friction.
