Another clock spring problem
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by razza, Apr 25, 2019.
  1. razza
    razza New Member
    nottingmam
    Hi guys,
    I have a problem I'm hoping I can get help with.
    I have a camera on my front window, which is powered via the 12v socket.
    I got the camera cable wrapped between the gap between steering wheel and dash board when turning .
    None of the buttons work on the steering wheel so I think I have damaged something in that gap behind steering wheel.
    Looking at videos on YouTube, with the steering wheel off, it seems to me like I may have damaged the black plug that connects to clock spring.
    Between the steering wheel and dash, it only looks like the thing I could have damaged is the clock spring connector.
    im hoping somebody has experienced anything alike or could guide me in the right direction.
    I am happy to look into how to take the steering cap off to try and see if the spiral clock connector has broken if that's possible without taking wheel off .
    I know if so Il have to disconnect the battery in the boot.
    Edit.
    Btw, it doesn't make any weird noises at all when i turn the steering wheel.
    Thanyou
    #1 razza, Apr 25, 2019
  2. razza
    razza New Member
    nottingmam
    It looks here like the only thing I could have touched is the black spring connector ?
    What do you think please?
  3. ChapmanF
    15,663
    With the airbag removed, you'll probably see whatever happened easily enough.
    Be sure to follow all of the precautions in how to handle (and how to set down) the airbag.
  4. razza
    razza New Member
    nottingmam
    That would be great if I could actually diagnose the problem just by removing the airbag.
    I will make sure I disarm the airbag via the 12v battery.
    Thankyou for your reply..
