Another Coolant Question...
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Jeff S., Jun 13, 2016.
Tags:
  1. Jeff S.
    Jeff S. Junior Member
    17
    Michigan
    Dealer wants $299 to "flush" both engine coolants. It's a 2009 with 128K and the coolants have never been changed.
    I have read the forum backwards and forwards and am getting conflicting opinion.
    So, I will ask again.
    1) Should I pay the dealer to flush both coolants? Or just the inverter coolant?
    2) Should I rely on a dealer for this service or try and find a cheaper mechanic?
    Thank you to everyone that gave their input, even if was just a yes/no.
    Sincerely,
    Jeff
  2. Autoist
    Autoist Member
    119
    81
    Seattle Metro
    My Gen IV (you posted in the wrong forum) has a maintenance book with a schedule for checking these fluids. Check yours for recommendations.
    51,141
    i believe so. check your maint. manual, i think coolant changes around 100-120k.
  4. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
  5. JC91006
    16,672
    8,518
    This is just a drain and fill of the coolants. You would need no more than 3-4 gallons for both. If you DIY this job, it would cost about $100 or less.
  6. andrewclaus
    andrewclaus Active Member
    993
    326
    Golden, CO
    I just did both for a total cost of $60 for three gallons of coolant. I had already purchased the Mini VCI tool ($25), which is not required but makes the job easy. You do need specialized knowledge and tools for the engine and it's tricky to bleed correctly and completely. The inverter is much easier, but critical to get it right. There are Youtube videos for both.
    I would not trust a non-Prius mechanic to bleed the engine coolant correctly, and I've heard of dealer mechs getting it wrong, too.
    Don't let anyone sell you a flush job. Just drain and fill.
    The hardest part of the job for me was removing the splash guards from the left front for access to the drain. It took a couple of hours for both loops, including test driving and fiddling around with topping off after cooling down, etc.
    Next time I change the inverter coolant at 150K, I'll probably put in a new pump too--cheap insurance for a critical part.
  7. JC91006
    16,672
    8,518
    +1 on the inverter pump. They only work for about 100k miles and they go out at the worst times. Think of it as a 12v battery change every 5 years.
  8. hesty24
    hesty24 Junior Member
    San Antonio, Texas
    Man, I got ripped off. I paid $300 for each, plus $300 for ATF change (central texas). Dropped $200 on a 12V battery. I am not even sure they got the engine coolant right as I cannot see coolant under the radiator cap. Took it back and explained that I was not getting a warm fuzzy on that one, and they took it to the back to add more. What it looks like they did was just fill the overflow reservoir. Looked under the radiator cap tonight while doing an oil change, and no coolant under the radiator cap. I'm at a loss here guys. What do you suggest I do?
  9. edthefox5
    edthefox5 Senior Member
    10,096
    4,831
    Clearwater, Florida
    If your actually looking at the rad cap and the coolant keeps going down that could mean 2 things.
    1---They actually did flush the coolant out and like most dealers we see here were incapable of getting all the air out of the system and the coolant level is moving around. Be careful here because if it has a big airlock it can overheat the motor and warp the aluminum head. See many of those on this site. very difficult to get air out with a coolant change because the CHRS canister creates an airlock.
    Turn on the heat in the cabin and listen closely for gurgling under the dash That means you have an airlock.
    Or 2---You have a coolant leak. usually caused by a bad engine coolant pump. get flashlight look at front of engine which is on the passenger side of the car and look for any green flakes deep down by the pump and by the coolant pump belt. I would have that belt changed asap. Its way over due if it fails the engine will over heat and you'll never know till its too late.
  10. dolj
    dolj Senior Member
    8,209
    4,180
    Wellington, New Zealand
    If it is stock SLLC he'd be looking for pink residue.
    jerrymildred likes this.
