Another "fog light" question: How do I modify af harness to remove the switch?
Discussion in 'Gen 4 Prius Accessories and Modifications' started by jareza, Sep 11, 2020.
  1. jareza
    jareza Junior Member
    16
    Laredo
    Two Eco
    Hi Everyone!
    So I finally jumped the wagon on the cheap chinese fog lights: when they were all the hype they were around 300 usd shipped. Now I found them for 120 shipped so I pulled the trigger:
    I will hook them up simple: connect the harness to the battery and the trigger lead to the fuse box so that they stay always on: however it comes with a switch that I want to remove from the harness:
    I want to "Bridge" the connections so that it stays always on: the question is: which wires do I join together? the switch comes with 4 wires and I got confused.
    Could anyone help me out on this?
    thanks!
    heres a link of the photo
    https://photos.app.goo.gl/cfBjidH42yzDLv6b6
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,784
    2017 Prius c
    Just turn the switch to ON and "hide" it behind the dash.......or somewhere else out of the elements.
    At some point in the future, you might want an easy way to turn them OFF.
    krmcg likes this.
  3. jareza
    16
    Laredo
    Two Eco
    That was actually my first thought but I dont want to deal with routing it behind the dash I was going to hide it on the engine compartment but I fear that at some point it might melt or get wet.... Im planning on installing them tomorrow so if I dont get a definitive answer by then I will find a place to stash it
    thanks!!!
  4. sam spade 2
    7,035
    2,784
    2017 Prius c
    Put it in a small plastic bag or plastic box and zip tie it to something high up in the engine compartment.
    If water gets through that, the fog lights will be the LEAST of your worries.
  5. jareza
    16
    Laredo
    Two Eco
    did not think of using a plastic bag!
    great idea! thanks!
    ill post a follow up once I finish the install!
  6. NewHybridOwner
    NewHybridOwner Active Member
    607
    279
    W. Michigan
    I assume that the black-insulated wires are both ground and, of the other wires, one is for the light that illuminates the switch itself and the other is to activate the fog lights themselves. Are you sure you want them always ON? -- even if you mean "always" only when your high beams are OFF. I don't think I would want that.
    alanclarkeau likes this.
  7. jareza
    16
    Laredo
    Two Eco
    Well, its how most members are installing them, Its also a way to get rid of those fugly black covers and I already tested them... they are not bright enough to disturb anyone.
    they come with a small adjustment knob and I will point them down as much as I can.
  8. alanclarkeau
    alanclarkeau Senior Member
    7,042
    7,580
    near Brisbane, Australia
    The problem is that, though they're not "bright enough", they are unfocused - meaning they scatter the light indiscriminately causing glare. They're really a terrible design - I'd at least have them on a separate switch.
  9. sam spade 2
    7,035
    2,784
    2017 Prius c
    Are we talking about FOG lights here ?
    If so, they are unfocused and "scattered" on purpose IF they are proper fog lights.
    The ones that are bright and sharply focused are NOT good fog lights.
