Another Gen II Rebalancing Thread
Discussion in 'Gen 2 Prius Technical Discussion' started by mushatsu, Oct 15, 2013.
  1. mushatsu
    mushatsu New Member
    Oklahoma City, OK
    I've been lurking for a while. Mostly I joined the forum because I wanted to do some mods to my Prius. It's a 2005 with 210,000ish miles. Unfortunately I've only owned the car for about 10,000 miles and only 4 months before the HV battery went out (codes for two pair out of voltage). I have the full history of the car and know the previous owner, so I know the car has been maintained. I also knew going into buying the car that it was a gamble with an 8 year old battery.
    So far, I've removed and disassembled the battery. I've found quite a bit of corrosion (looking for suggestions to clean up the bus bars). The battery module terminals all looked good after removing the nuts, so I bought 4 DC6 Supermate Chargers and went to town.
    From a quick voltage check, I found 6 modules that were low, but decided to try rebalancing everything because of the corrosion. For rebalancing, I setup up the chargers for 7250 mah, 5 D/C cycles, and no safety timer. I left Delta V at default and charged at 5 amps and discharged at 0.7 amps (set on 1, but only did 0.7). Below are the results.
    Discharge Charge
    Column 1
    0 [tr][th] [th]#1 [th]#2 [th]#3 [th]#4 [th]#5 [th]#1 [th]#2 [th]#3 [th]#4 [th]#5
    1 [tr][td]1. [td]3321 [td]5771 [td]5928 [td]5846 [td]6198 [td]6751 [td]6750 [td]6751 [td]7250 [td]7250
    2 [tr][td]2. [td]3657 [td]5988 [td]6176 [td]6288 [td]6240 [td]7250 [td]7250 [td]7250 [td]7250 [td]7250
    3 [tr][td]3. [td]2334 [td]5085 [td]5406 [td]5920 [td]6044 [td]6936 [td]7160 [td]7251 [td]7250 [td]7250
    4 [tr][td]4. [td]3162 [td]5831 [td]6091 [td]6122 [td]6241 [td]7250 [td]7250 [td]7250 [td]7250 [td]7250
    5 [tr][td]5. [td]2812 [td]5547 [td]5824 [td]6064 [td]6070 [td]7251 [td]7251 [td]7250 [td]7250 [td]7251
    6 [tr][td]6. [td]2963 [td]5652 [td]5885 [td]6040 [td]6139 [td]7251 [td]7251 [td]7250 [td]7251 [td]7251
    7 [tr][td]7. [td]2331 [td]4840 [td]5260 [td]5393 [td]5579 [td]7250 [td]7250 [td]7250 [td]7250 [td]7251
    8 [tr][td]8. [td]2662 [td]5164 [td]5420 [td]5467 [td]5615 [td]7250 [td]7250 [td]7251 [td]7250 [td]7250
    9 [tr][td]9. [td]1383 [td]4593 [td]4393 [td]5034 [td]5191 [td]6189 [td]6816 [td]6910 [td]7055 [td]7175**
    10 [tr][td]10. [td]365 [td]1399 [td]1336 [td]1317 [td]1297 [td]3201 [td]3532 [td]3382 [td]3261 [td]3104*
    11 [tr][td]11. [td]1985 [td]4775 [td]5055 [td]5114 [td]5225 [td]7015 [td]7250 [td]7250 [td]7250 [td]7251
    12 [tr][td]12. [td]1 [td]1465 [td]1495 [td]1400 [td]1329 [td]3257 [td]3235 [td]3404 [td]3286 [td]3418*
    13 [tr][td]13. [td]1269 [td]4051 [td]4319 [td]4855 [td]5029 [td]5573 [td]6838 [td]7077 [td]7251 [td]7250
    14 [tr][td]14. [td]2 [td]1214 [td]1273 [td]1335 [td]1349 [td]2909 [td]3039 [td]3296 [td]3531 [td]3403*
    15 [tr][td]15. [td]11 [td]1276 [td]1122 [td]980 [td]878 [td]2738 [td]3059 [td]3069 [td]2834 [td]3074*
    16 [tr][td]16. [td]1848 [td]4661 [td]5208 [td]5290 [td]5511 [td]7050 [td]7251 [td]7250 [td]7250 [td]7250
    17 [tr][td]17. [td]1 [td]816 [td]734 [td]612 [td]563 [td]2500 [td]2436 [td]2205 [td]2196 [td]2040*
    18 [tr][td]18. [td]2106 [td]4720 [td]5066 [td]5462 [td]5586 [td]7069 [td]7250 [td]7250 [td]7250 [td]7250
    19 [tr][td]19. [td]2088 [td]4289 [td]4849 [td]5220 [td]5350 [td]7037 [td]7191 [td]7251 [td]7250 [td]7250
    20 [tr][td]20. [td]2984 [td]5326 [td]5625 [td]5486 [td]5823 [td]7250 [td]7250 [td]7250 [td]7250 [td]7251
    21 [tr][td]21. [td]1878 [td]4573 [td]5133 [td]5256 [td]5545 [td]6948 [td]7250 [td]7250 [td]7250 [td]7250
    22 [tr][td]22. [td]980 [td]4050 [td]4239 [td]4577 [td]4969 [td]5844 [td]6696 [td]6834 [td]6961 [td]7067**
    23 [tr][td]23. [td]1 [td]396 [td]336 [td]306 [td]263 [td]2620 [td]1869 [td]1752 [td]1744 [td]1751*
    24 [tr][td]24. [td]2309 [td]4806 [td]5207 [td]5079 [td]5479 [td]7250 [td]7251 [td]7250 [td]7250 [td]7250
    25 [tr][td]25. [td]2725 [td]5242 [td]5625 [td]5722 [td]5845 [td]7250 [td]7250 [td]7250 [td]7251 [td]7251
    26 [tr][td]26. [td]2093 [td]4510 [td]4645 [td]5133 [td]5495 [td]6564 [td]6655 [td]6905 [td]7251 [td]7250
    27 [tr][td]27. [td]3039 [td]5218 [td]5516 [td]5530 [td]5836 [td]7250 [td]7250 [td]7251 [td]7251 [td]7250
    28 [tr][td]28. [td]3067 [td]5495 [td]5728 [td]5564 [td]5893 [td]7250 [td]7250 [td]7250 [td]7250 [td]7250
    * These 6 are definitely bad (and were the ones that tested low voltage originally)
    ** I'd say these 2 might be bad (looking for second opinions)
    Could the rebalancing gurus chime in and give their recommendation? I'm under the impression that the modules are 6500 mah each, but none ever reached a 6500 mah discharge.
    How does one measure series resistance? What recommendation is there for pairing up modules?
    Currently, I'm a little short on funds, but should be purchasing used modules in the next couple weeks. I will rebalance those and post the results at that time.
    Thanks for the help!
    -Mushatsu
  2. mushatsu
    mushatsu New Member
    Oklahoma City, OK
  3. Britprius
    Britprius Senior Member
    5,194
    1,924
    Herefordshire England
    I would give modules 9 and 22 another cycle the see how the voltages hold compared with the other good modules before condemning them. I agree modules 10/12/ 14/15/17/23 do not look good.
    Pair up the modules to to get the voltages as even as you can for each module pair compared with the rest. It is a good idea to connect all the re balanced modules in parallel for a few hours to even out the voltages before assembling the battery.
    White vineger or phosphoric acid (alloy wheel cleaner) will clean the bus bars. Wash and dry after cleaning.
    Put the lower AH capacity modules at the ends of the pack, the best in the middle.
    Hope this helps.
    John (Britprius)
    marcs_carhole likes this.
  4. mushatsu
    mushatsu New Member
    Oklahoma City, OK
    Thanks John. I went ahead and ordered 6 replacement modules. I'm a bit tight on money, and I know that I have to replace those. I also wanted to get a jump on rebalancing them. At 2.5 days a module, I'll still need the majority of a week to balance. Once done, I'll repost numbers on all 8 modules; including the 2 with the 6th cycle.
  5. cgates30
    cgates30 Junior Member
    87
    mushatsu,
    Just trying to follow your post. In your table you have 1-5 listed twice for each module. Are those the 5 discharges followed by 5 charges in mAh?
  6. mushatsu
    mushatsu New Member
    Oklahoma City, OK
    Yes, that's 5 discharges followed by 5 charges. Undecided on 5 because I have a fairly old battery that didn't get much TLC. It seems that I made the right decision, as many of the modules balanced out after 3 cycles. Unfortunately, the formatting was lost when I posted.
  7. cgates30
    87
    I realize you probably haven't gotten your new cells yet, but any chance to cycle the other 2 modules?
  8. mushatsu
    mushatsu New Member
    Oklahoma City, OK
    Actually, I've had a chance to order and receive modules. I'm currently mobile, so I'll report the results later. Both of the original modules balanced out and 5 of the 6 new modules did. Now I'm waiting on another module to arrive to finish things up.
  9. mushatsu
    mushatsu New Member
    Oklahoma City, OK
    Since the formatting didn't work out last time... Let's try this way.
    Discharge #6
    9. 4201
    22. 3360
    Charge #6
    9. 7250
    22. 7250
    Here are the numbers for the 'new' modules
    Discharge #1-#5
    29. 3460 5313 5555 5562 5671
    30. 3656 5274 5585 5511 5694
    31. 3836 5077 5441 5426 5578
    32. 3969 5281 5554 5292 5562
    33. 3446 5194 5445 5454 5557
    34. 427 820 882 889 914
    Charge #1-#5
    29. 7251 7250 7250 7251 7250
    30. 7251 7251 7250 7251 7250
    31. 7250 7251 7251 7250 7250
    32. 7250 7250 7250 7250 7250
    33. 7251 7250 7251 7250 7250
    34. 2811 2565 2688 3005 3019
    Obviously, #34 is bad. I contacted the seller and he sent me a new one no questions asked. He didn't even want the old one back. It looks like I'll be in business as soon as I get the last one.
  10. cgates30
    87
    Looks pretty good. What did you decide about #9 and 22? Their discharge is still lower than all of the other modules (except 34). They've been cycled 6 times, so there's probably no benefit in continuing that process. I guess you could move them to the outer positions 1,28 to limit temperature effects. On the other hand they may be good enough...
  11. marcs_carhole
    marcs_carhole Junior Member
    44
    Durham, NC, USA
    Hello Mushatsu, I have been following your thread with great interest. I am about a month behind you in rejuvenating a battery pack from a 2004. I also bought 4 of the DC6 chargers and have only been through one 3-cycle batch thus far. From that limited sample set, my capacity results are similar to those of your good modules (5.4 to 6.2 AHr).
    You had a lot of bad modules in that pack ... do you live in the heat of Death Valley? In your original post, you said the codes showed 2 blocks with voltage out of range. Which blocks were listed as bad? Though 2 of your bad modules are adjacent, it looks as if all 6 were in different 'blocks.' (?) I am wondering why the ECU was not identifying more bad blocks. (Maybe there is a limit as to how many are flagged?)
    I would be curious as to the voltages you measured. Were you able to take voltage measurements with a load? Or just open circuit?
    I look forward to seeing your progress.
    Marc
  12. mushatsu
    mushatsu New Member
    Oklahoma City, OK
    (cgates30) I've decided to keep 9 and 22 and move them to positions 27 and 28. That way they will be the limiting pair in the set. Being on the outer edge should limit their thermal load and make them easy to replace in the future. There is also a temp sensor on the bottom of that pair, so I can easily watch their temp.
    (marcs_carhole) I am the second owner of this car. The first owner had it in Flordia for 3 years and Texas for 4. I've had the car for almost a year now (though it hasn't been driven much in 6 months). The car has been exposed to lots of moist environments due to the previous owners (an my) love of scuba diving. As for the original codes, they were for Block 6 and Block 7 (corresponding to modules 11 & 12 and modules 13 & 14). It could be that there is a max number of codes set, but I doubt that as it wouldn't make sense from a diagnostic point of view. It could be that the remaining blocks were on the limit or hadn't persisted long enough to trip the code. Also, when these codes were read, the computer had been reset a number of times due to disconnection of the 12V battery. So the code might not have tripped yet. Another thing is that the car had to be driven over the 6 month time frame a few times. This may have caused more modules to fail.
  13. mushatsu
    mushatsu New Member
    Oklahoma City, OK
    Time for another update!
    The latest module also looks kind of weak. I went 7 D/C cycles because of this. It seems to be about it's peak, so I'm just going to try it and match the pairs up as best as possible.
    Discharge 1-7
    35. 5037 5236 5210 5231 5218 5013 5262
    Charge 1-7
    35. 7010 7194 7150 7156 7178 7178 7151
    If I can't find my ammeter to check the resistance of the modules under load, I'm just going to discharge them to a voltage and wire them in parallel overnight. I plan on restacking the pack tomorrow and installing the pack Thursday (I'm not welcome in the kitchen while my wife is cooking anyway). I should be able to put a 100 mile test drive on it Friday. And the ultimate test will come at the end of December where I have a 2200 mile trip planned.
  14. mushatsu
    mushatsu New Member
    Oklahoma City, OK
    Success!!! The Prius lives!!!
    Restacked and voltage balanced the battery pack the night before last. Yesterday being Thanksgiving, all I did was hook everything back up that evening. This afternoon, I put the battery pack back in the car and bolted in all the supports, ducts, and the 12V battery. I left out the interior pieces just in case something happened.
    Started it up and it ran! I'm really excited that this worked! Plus, I averaged 50 mpg on the way home from where I was storing the car (about 30 miles).
    I'll post an update after about 500 miles (a week or so) and again just before and after my late December trip.
  15. Britprius
    5,194
    1,924
    Congratulations on a job well done, and the money saved.
    John (Britprius)
  16. cgates30
    87
    I know the goal is to get modules with balanced capacities, but I'm wondering what I should expect if I have 3 modules a 200-300 mAh below all the others. Should I go ahead and order more modules? These three discharge 5100-5200 and the other modules are 5500-6300. Should I expect the pack life to be quite a bit shorter because of this discrepancy? I made good progress on my pack before Thanksgiving, but then I've been on 2.5 weeks of business trips...
  17. mushatsu
    mushatsu New Member
    Oklahoma City, OK
    Sorry that I didn't post after 1000 miles. Things got a bit crazy before going on my trip. I've put about 3500 miles on the rebuilt pack without any problems. The interior has been put back and I had a pretty good trip. Overall, I averaged about 45 mpg going 70 mph. My best tank was 50 mpg at 70 mph and my worst was 35 mpg at 65 mph. I was driving into a 30+ mph head wind and up hill most of the tank. Overall a success.
    @cgates I wouldn't worry too much about a few hundred mah. My pack was built up with ones from 4900 to 6100. Just pair them up as best as possible. As for longevity, it will reduce the life, but I can't say by how much. The higher the mah, usually the longer the life. We'll see what happens in the next year or so.
