Another head gasket or worse
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by tianmaire, Sep 12, 2025.
  1. tianmaire
    tianmaire Junior Member
    Chicago, IL
    TL: DR - my 2012 has 188k and the engine has been knocking occasionally upon start up. Dealer is saying either head gasket replace or worse case - engine replace ($6100). Also EGR valve for $750 (they just cleaned the ports recently and replace the intake gasket ($570) so why didn't they just do the whole job then!?)
    So I took my car back to dealer after the EGR port cleaning etc didn't fix the knocking. They found codes P0301 and P0302. Found low coolant level and excessive pressure in coolant tank. Performed "block test" which "failed", indicating need for a head gasket replace and cylinder head replace but won't know for sure until head is removed, of course. Then possible a full engine replacement. It also needs brakes ($700 per axle!?)
    They also mentioned 2 TSBs: T-SB-0169-16 (oil consumption) and T-SB-0027-16 (engine noise when starting after "cold soak".
    Do I give up on it, use Peddle and get maybe $1k? Do I drive it a little longer, knowing I can't fix or resell it and how dangerous is THAT?! Do I find a local shop and go forth with a 2nd opinion and possible new engine? The engines available in the area are all well over 100k miles on them and available from 1300-1900 (according one shop I've been talking with).
    I'm especially concerned after reading enough about 3rd gen issues to know the head gasket could fail again.
    I just hate giving up on a toyota without hitting the 300k mile mark ;)
    Both kind words and harsh reality checks welcome from y'all.
    Context - car was given to me by family member 2 yrs ago so besides about 1200-1550/yr in maintenance, I am not into the car too musch $$ wiser - I would not have chosen a 3rd gen but when someone hands it to you - you (I) take it!
  2. Tombukt2
    Tombukt2 Senior Member
    13,868
    2,520
    Durham NC
    Gotta milk The cow slowly geesh! Good sense helps in this realm of things . Think a lil bit read etc . That's things ain't knew . The methodology is a lil different today . I mean we as a people believe a lot of things today just 30 years ago not possible . So beware . Many those beliefs created for a narrative . A certain dialogue . Etc . So when you talk to people now you have to record right down make a note of everything said so you can look back over wen that person or around . Then you can pick apart the dialogue not in front of them . And usually see how off rails things mite be getting . Of course if you're like same . Kinda like blind leading the......
  3. Mendel Leisk
    42,361
    The knocking is the engine struggling to compress coolant in the combustion chamber(s).
    With long term neglect of the EGR system system carbon build-up prevents its proper function, engine overheats, unevenly, head gasket fails, coolant leaks, and here you are.
    At this juncture cleaning the EGR system, while a very good idea, is NOT going to somehow “heal” the leaking head gasket.
    Toyota is complicit in this mess: they rushed the system to production. Very evident in hindsight. And compounded the issue by not ‘fessing up.
    Who did the EGR cleaning, dealership? They’re typically not going to do it properly. Unless they just replace everything, which will set you back close to 2 grand USD.
    To clarify: by “another” head gasket, you’re meaning another head gasket case, chiming in, not that yours has had a previous head gasket replacement?
    The only way to avoid this nonsense is to thoroughly clean the full EGR system, that’s everything between the exhaust manifold and the intake ports, at least every 50k miles.
    (Apologies for Tom by the way, not sure what he’s on about lol. If you read his missives aloud it helps comprehension fwiw.)
    #3 Mendel Leisk, Sep 13, 2025
  4. Brian1954
    Brian1954 Senior Member
    2,693
    1,076
    South Central PA, USA
    The knocking is not caused by the engine struggling to compress coolant in the combustion chamber. If that were to happen, the piston rod would be bent, or it would break. The knocking in most cases is caused by misfiring in the cylinder. There are many things that can cause misfires. In the case of a bad head gasket, coolant seeps into the cylinder and causes the spark plug to misfire. This has been pointed out to you many times. Why do you keep spreading bad information about what causes the knocking?
  5. Mendel Leisk
    42,361
    Either way, it’s coolant in the cylinder? Would that be good information?
  6. Brian1954
    2,693
    1,076
    Yes, coolant in the cylinder is causing the spark plug to misfire, which causes the knocking.
  7. Mendel Leisk
    42,361
    And every day a little more coolant, until it crosses some threshold, and only then it’s impacting compression. Seems a fine point, and the outcome is always the same.
  8. BiomedO1
    BiomedO1 Senior Member
    4,633
    2,433
    Left Coast
    Welcome;
    Pull the O-ring on the engine coolant reservoir bottle cap. That'll lower the coolant system pressure and slow down the coolant leaking into the combustion system. This is JUST a stop-gap measure. DO NOT use those witch-doctor head gasket sealers products - they will clog-up your cooling system. This will allow you to drive the car a little longer, but keep an eye on coolant levels. It needs to be checked daily; until you get a handle on how fast it's going down.
    Option 1: Sell and/or replace the car - it's running so it's NOT worthless.
    Option 2: Replace with a rebuilt motor with all the updates that'll prevent this from happening again. I'm sure you know those gen3's are problematic and spending money on a used high mileage motor with known engineering defects is a poor bet. I consider it a waste of money that'll only enrich the mechanic doing the job. The specter of a used motor blowing-up again will always be there. This also doesn't take into account the other expensive assemblies that normally fail in a high mileage gen3.
    There you have it.
    As a side note: I had a friend buy a new late 90's early 2000 Honda that developed a transmission issue around 130K. Honda had transmission issues in those years. I told him to replace it with a rebuilt that has the OEM rebuilt kit with modifications that prevents it from imploding. Well he got cheap, ignored my warnings and replace it with a used junk yard transmission. To add insult to injury, that one blew-up 20K miles later. Of course, he's hard-headed and does the same thing again - expecting a different result.:( He eventually sold me the high mileage Honda; at a very good price ($200) with another blown transmission. My niece is currently driving it around with 300K+ miles on it. When I had the transmission rebuilt, properly, it's already exceeded the mileage of the original. Just the standard oil, spark plugs, and ATF changes associated with normal maintenance. My friend still thinks that Honda's are JUNK.......:cool:o_O:rolleyes:(n)
    #8 BiomedO1, Sep 13, 2025
  9. tianmaire
    Chicago, IL
    Thank you for the reply! My primary question is whether or not to seek a 2nd opinion, when it seems unlikely I'll get a more wallet friendly diagnosis and - doesn't a 2nd opinion require someone actually accessing the head gasket - isn't that pretty major?
    When I first got the car, it got waay down the rabbit hole about the EGR and I knew flushing the whole system was something I needed to be on top of and yet - I did not do it. If I were a DIY it would've been a no brainer. But that sure is expensive to pay someone else to do it.
  10. tianmaire
    Chicago, IL
    Thank you for the tip, I'll use that intel to get the car home and keep bopping around town a bit. Using Peddle's calculator - i've been offered 1100 but it doesn't ask the right questions for me to confess the recent issues. I don't know if the next step is a phonecall where they ask or what. Should I consier $1100 as good as I'll get and take it?
    Any other tips on getting some $$ out of this vehicle? I live in Vermont.
  11. Mendel Leisk
    42,361
    The usual is to run a borescope down the spark plug holes, looking for:
    exceptionally clean cylinder top(s) (due to coolant steaming off carbon deposits
    coolant tears running down the cylinder wall from the head gasket seam
    If you disassemble down to the head gasket, you'd be replacing it. Plus replacing all the other gaskets encountered on the way, and likely the head bolts.
    BiomedO1 likes this.
  12. BiomedO1
    4,633
    2,433
    Left Coast
    1.1K seems a bit low, considering what cars cost now-a-days. Go to KBB or Edmunds to get the true value. Parts is less than $300 for a shade-tree mechanic to flip. If the interior is in decent shape and the frame isn't rusting apart; I'd be looking for at least $2K. These are very popular cars out west - don't know about your neck of the woods.
    Hope this helps......
  13. tianmaire
    Chicago, IL
    Anyone else out there seeing this agree that I could potentially get closer to $2k?
  14. tianmaire
    Chicago, IL
    I have the solar panel+sunroof combo too
