Another low milage thread
Discussion in 'Gen 2 Prius Technical Discussion' started by dpower, Mar 19, 2019.
  1. dpower
    dpower Member
    97
    48
    Katy Tx
    For almost the last year my 2005 Prius has been getting low 30 mpg.
    I went through the usual list of tires, filters, binding breaks the usual. It was logging some misfires caused by a leaking manifold old gasket, but not a lot. No codes logged. I went ahead and replaced the injectors and after cleaning the MAF I replaced it. Hand a compression test dome,138 psi well above the 99 min Toyota specs. Took the step and replaced the traction batter. Car was now running like a dream. But still 33 mpg. Pondering the system I finely replaced the fuel/sensor that read good but did have 179,000 miles on it and it’s a bitch to get to, I had heard that these get lasy over time.
    That took care of it back to 45-48 mpg. I think this should be added to the lists as it doesn’t code.
    SFO, Skibob and bisco like this.
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,812
    Clearwater, Florida
    I would think that if that sensor was bad it would throw a code. Emissions are highly monitored.
  3. padroo
    padroo Senior Member
    2,763
    2,251
    What fuel/sensor do you mean?
    edthefox5 and maddog2020 like this.
  4. Skibob
    Skibob Senior Member
    2,912
    1,497
    Northern California
    Probably what a lot of people think of as the upstream O2 sensor.
    edthefox5 and padroo like this.
  5. padroo
    2,763
    2,251
    Some problems can't be solved without scan data.
  6. gptoyz
    gptoyz Junior Member
    79
    16
    los altos
    iPhone ?
