Another newb
Discussion in 'Newbie Forum' started by Spaded, Jan 26, 2015.
  1. Spaded
    Spaded New Member
    Hello, I work at a dealership and I picked up a 2007 Prius with over 200k miles on it. Was a trade in and I bought it from my work. Now I'm trying to get it back to running right.
    Love this forum, I've read a lot of good info and advice
  2. ETC(SS)
    7,379
    Greetings and welcome aboard!
    That wasn't me that said all those mean things about stealerships.....that was another ETC(SS). ;)
    200K?
    You'll get at least another 50-100k out of it.
    Good Luck!!
    52,448
    all the best!(y)
  4. Bob-blehead
    Bob-blehead Junior Member
    52
    Central Michigan
    2014 Prius v wagon
    Congratulations! If you don't mind me asking, what needs fixing? Just curious about what project(s) you'll be working on.
  5. kingnba6
    kingnba6 Active Member
    1,018
    242
    NY
    Seems pretty high mileage to me. Best of luck!
  6. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    Welcome and congrats. Keep us posted on your progress !
  7. Spaded
    Spaded New Member
    Yup 205k and the previous owner never did any maintenance on it other than tires, brakes and oil changes.... this be the spark plugs I pulled out
    Well for starters the windshield was cracked (replaced windshield), right front headlight did not work (had to replace bulb and ballast), multiple check engine codes, A/C does not blow cold, and it was a pig sty inside (leather seats! easy to clean!).
    I am a mechanic and assistant service manager to I get parts at cost plus 10% so repairs are really cheap when I do them myself. Although I still have a p0420 code (catalytic) and I am in california, my cost for the cat alone is still $1500. (ouch)
  8. Bob-blehead
    52
    Central Michigan
    2014 Prius v wagon
    Not too bad, other than your catalytic. Best of luck, and enjoy your "new" car.
  9. Prius2007xyz
    Prius2007xyz Junior Member
    Massachusetts
    I
    Yikes about the cat cost! My 12v battery needed replacing $195.00 & replaced it myself.
    Have you had to solve any TPSM issues? If so can you give a brief summary use of the "SET" button procedure, under steering wheel...?
  10. Spaded
    Spaded New Member
    Tire pressure sensors are a headache for all vehicles. I haven't had an issue with mine yet. But the "set" button procedure is in your owners manual, of course I keep my PSI much higher than the guideline in the door for fuel efficiency. If you have run thru the "set" procedure already tho it could be that one of your sensors has died, I've replaced quite a few of them on all sorts of cars.
    Tire p
