Another P1072 thread
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by SauceToyota, Jan 20, 2021.
Tags:
  1. SauceToyota
    SauceToyota New Member
    Jersey City, NJ
    Hey, all! First time poster looking for some reassurance here.
    Changed out the spark plugs and fuel injectors on my 2013 Gen 3 several weeks ago with no problems. The parts were decent OEM parts. Now I'm getting a P0172!! Can I keep driving this for work? I drive up to 100 miles a day and am hoping it'll last another week.
    After that week, I will go in and check the MAF sensor, the air intake manifold, and maybe replace the air filter. The air filter was filthy. If none of those work, I'll give a good look at the fuel injectors.
    Included is a screenshot of the OBD readings. I admit I don't know anything about the numbers, so I'm curious for your thoughts.
    Thanks, all!
    52,885
    i think you'll be fine. how many miles on her?
  3. SauceToyota
    Jersey City, NJ
    A little over 95K. Talked around and it seems to be really common to run rich, but i wouldn't want to neglect my Gaben like that!
  4. SauceToyota
    Jersey City, NJ
    An update on this!
    It got worse: The check engine light never went away, and I started getting Cylinder 1 and 2 misfires.
    I took it to the Toyota service center, where they noticed the fuel injectors I installed (UltraPower FJ1287) has LESS holes than the stock Prius fuel injectors. UltraPower's injectors have 4 holes, the stock Prius has 12 holes. This may have led to a less misty spray into the chambers, and too much fuel being used. They replaced it with the stock parts, and now it's all fixed!
    In the end, I used the right spark plugs, but the wrong fuel injectors. Oops!
    Side note, keeping the UltraPower injectors also led to the engine knocking because of cylinders 1 and 2 misfires. The knocking has gone away since the right injectors were installed.
    BrianStranded and JimCar295632 like this.
  5. BrianStranded
    BrianStranded Member
    118
    84
    New Orleans, LA
    I’m having this same issue after a headgasket install, Code P0302 and P0172. I replaced the injectors and coils too, Im thinking my Amazon sourced injectors are the culprit
