Another Prius RH Headlight Fire *PICS - 2012 Prius two
Discussion in 'Gen 3 Prius Main Forum' started by priusonfire, Jul 31, 2018.
  1. priusonfire
    priusonfire New Member
    MidWest
    I Did a quick search and managed to find a few gen3 burnt up prius, that looked to start from the passenger side headlight. Looks like it started from the turn signal or the headlight...
    This is mine with no mods, 70k miles, 2012.
    Fire started on right side spontaneous combusted, burned up fender and wire harness behind light, melted a coolant, washer, tanks and some trim pieces.
    Hopefully toyota wants to help fix this mess???
  2. GFO
    GFO Member
    67
    47
    Larkspur
    GTprii likes this.
  3. ChapmanF
    15,467
    Ehhh ... I was never anything but speculating as to whether the harness recall might have been a contributing factor.
    I confess I have just been staring at these photos trying to figure out whether the recall harness was present on this car. Doesn't look like it is, at least not routed the way the recall said to.
    Anyway, I wouldn't expect it to be, if the car is a 2012 ... I don't think the recall covered those.
    Maybe that's a bit of evidence against my earlier speculation.
    -Chap
    49,388
    2012? now you're making me nervous.:eek:
    wjtracy likes this.
  5. wjtracy
    wjtracy Senior Member
    11,321
    3,590
    Northern VA (NoVA)
    Yes I wanna say we had a few 2010's but 2012 is quite unexpected
  6. RRxing
    RRxing Senior Member
    2,519
    1,790
    NEPA
    The passenger side headlight on the Gen III is a tight fit for my hands, and the first time I replaced the lamp on my 2010 I seated it incorrectly (the socket was slightly cocked.) This could've/would've led to a melted headlamp assembly and/or possible fire, but I caught it right away and fixed it. Did you or anyone else replace the bulb recently? Not saying it wasn't the wire harness, but that may not have been the only cause.
  7. bisco
    49,388
    are there more than one kind of headlight on the 2012's? i replaced my bulbs a year or two ago when one burned out. didn't seem unusual to me.
  8. priusonfire
    MidWest
    Its a 02-2012 manufacture date if that means anything
  9. DustyPhoenix
    DustyPhoenix New Member
    US
    Moto G (5) Plus ?
