Another Radio Problem
Discussion in 'Gen 3 Prius Audio and Electronics' started by rak5555, May 25, 2015.
  1. rak5555
    rak5555 New Member
    Missouri
    Radio worked OK for past several years and now suddenly very poor reception. Most obvious cause would be disconnected antenna from back of radio.I read on this forum that I can reach the back of the radio by removing glove box and AC vent. Are there other connections I should check between radio and antenna? I have read that the antenna is powered. Are there fuses and if so where are they?
