Another Scangauge Thread - Daisy Chain
Discussion in 'Gen 3 Prius Accessories and Modifications' started by cproaudio, Oct 21, 2014.
  1. gliderman
    gliderman Active Member
    751
    225
    The original post and topic of this thread is about Scangauge daisy chain. I havent seen any of "
    the (numerous) reports of the strange things that sometimes happen when you leave a scanner plugged in too long" as claimed by the messenger.
    The messenger has delighted himself with others claims of strange things happening with tools other than the Scangauge. Perhaps messenger should start a new post on all the strange things that happen to all the other tools that people claim cause strange things? And not hijack the OP's informative post of success with daisy chaining Scangauges.
  2. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    258
    Ocala, FL
    Maybe we should discuss watching the road instead of looking at all of those gauges. :p
    And it would not have BEEN a hijack if my simple comment had been just left to die a natural death.
  3. cproaudio
    cproaudio Speedlock Overrider
    2,401
    762
    CA
    Do you really want to start this discussion?
  4. Easy Rider 2
    1,584
    258
    Ocala, FL
    Not in this thread. Maybe elsewhere.
  5. cproaudio
    2,401
    762
    CA
    Wanna report some observations so far. Fuel level only measures from 0.7 to 11.4 Even if you top off to the brim still shows 11.4 gallons. When you run out of gas, it still shows 0.7 gallons left. The 12V battery only goes to 14+ volts if I have the head lights on. Otherwise, it only goes up to low to mid 13V. When stopped, the car is pulling 1.5 amps from the HV battery. Turning on the headlight raises the draw to 2.5 amps. The speedo on scangauge is pretty accurate to GPS satellite speed. I have not check with radar as I haven't came across with one yet. The inverter coolant temp is barely a few degrees above ambient temperature. MG1 spins backwards often when not accelerating. friction brake doesn't activate until you slow down to 5-7 mph. That's it for now. Will report back when I find something new.
  6. gliderman
    751
    225
    My experience after last recall for inverter software changes. Fuel gauge is known. My 12v gauge reads all voltages with lights on or off. Speedo on gauge shows same as auto display. Inverter coolant temp is considerably higher than ambient temp here in Texas right now. Friction brake can activate any time, mostly when battery full.
    And my MPG is way off calculated MPG. As much as 4-8 mpg higher than calculated. I dont trust the fuel consumption gauge anymore.
    YMMV
  7. john1701a
    john1701a Prius Guru
    12,818
    5,303
    58
    Don't trust the pump gauge either. There's no way of truly knowing that you are filling to the same level each time. MPG can only be accurately measured over the course of several consecutive refills.
  8. gliderman
    751
    225
    I have a good handle on my mpg and I do trust the only gauge that is calibrated on a regular basis, the pump. I fill up two to three times a week at the same gas station and same pump if it isnt to busy. The Toyota computer is off big time since the inverter software update. And those are the facts I have experienced.
  9. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    I understand your point, and my ultimate MPG is based on gallons pumped and miles driven (cumulative), although it is interesting to compare the results from ChuggyPig's computer and each of the SC-IIs (…ah, boyz & their toyz! :rolleyes:) - Wil
    PS: I noticed at the beginning of the summer, my MPG dropped to about 37 mpg, but on doing some research (here on PriusChat) and changing my habits re. exactly when to use the A/C (see other threads), I was able to bring it back up to ~50-60 mpg
  10. gliderman
    751
    225
    I haven't checked my SGII against my Toyota MPG. I will do that next fillup.
    My GPS is the closest to my manual calculations based on miles driven and gallons pumped over time. GPS is usually within 1 or 2 miles.
  11. Tiger-Heli
    Tiger-Heli Junior Member
    Georgia
