Another Solar Panel/Ventilation Question
Discussion in 'Gen 3 Prius Main Forum' started by bpollard, Jul 5, 2009.
  1. bpollard
    bpollard Junior Member
    58
    Austin, Texas
    So I test drove the Prius this weekend with a guy who clearly was not very familiar with the Prius. He made statements like "The solar panel has enough power to run your house" and "you can hook up your ipod to the stereo"
    any ways, so I don't trust much of what he has to say.
    Two questions:
    1) How to activate the solar panel/ventillation system - is it really just a button down near my left knee (to the lower left of the steering wheel)? After pushing the button, no lights came on, nothing to indicate that it was engaged....
    2) The prius we drove did not have the navigation DVD in it. Does this version of Navigation offer the "3D" view versus the "2D" (looking straight down on the car/streets as if you were a bird)? How much are DVD updates?
    Thanks a bunch for your help.
    Brad
  2. mjrauma
    mjrauma Junior Member
    35
    Houston, Texas
    2018 Prius
    The answers are yes and yes. The button is the only thing for the solar vent portion and the nav goes to 3D when close to turns. I do'nt know how much updates are.
    Mike
  3. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    Nav is not 3D.
  4. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    The NAV dvd should be included - if it was missing, it was either missed @ Port or the dealer swiped it for another car.
    Solar - the button should be depressed to be active. I'm a bit disappointed there's no other indication, however most other indications would require power. Perhaps a mechanical window that would be green or red to show active vs. disabled should be included.
  5. Tideland Prius
    16,609
    The button is the toggle but it's not to turn it on or off but rather to let the system know that it's allowed to activate or not. The reason I say that is because the fans don't come on when you press the button. The system (if the button is depressed) will come on 10 mins after you lock the car. So if you leave the button depressed, then it's basically automatic.
    Unfortunately, the nav is not 3D (only those with the HDD option are and HDD isn't available in NA) and the disc upgrade will cost you (~$200). You usually don't need to update every year (I'm still running on jan 2007 maps on my TomTom)
