Another Tire Thread and TPMS Sensors
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by ThatOddMan, Nov 16, 2020.
  1. ThatOddMan
    ThatOddMan Junior Member
    64
    25
    Alhambra, CA
    2014 Prius Plug-in
    Currently on Michelin Defender on stock wheels.
    Priority:
    1. Quiet and Comfort
    2. MPG and Thread Life
    3. Price
    Driving Environment:
    • (Southern) California Weather but preferably All-Season but includes a rare driving on snow (Big Bear).
    I am currently checking the following.
    • Michelin CrossClimate Plus
    • Bridgeston Turanza QuietTrack
    Do all the TPMS sensors need to be replaced when tires are changed?
    Thank you.
    #1 ThatOddMan, Nov 16, 2020
    52,807
    no need to replace the sensors, but if a battery dies when you aren't replacing them, you either have to remove the tire again, or ignore the light.
    they are usually good for around 10 years.
    i have michelin energy savers a/s. 30k and hardly any wear, but i drive easy. they are quiet, smooth and great mpg's, but not cheap
  3. Mendel Leisk
    42,305
    Any complaints about the Defenders? They seem a decent "Goldilocks" choice.
  4. ThatOddMan
    64
    25
    Alhambra, CA
    It felt like a rougher ride.
    But I am comparing that rough ride to a 2005 Galant with Goodyear Comforted tires that I previously owned.
    My Prius does have the toyota oem rear sway bar. So I don't know if that is contributing to that rough ride.
    The Defender was installed last year if I am not mistaken before I bought the car.
  5. ThatOddMan
    64
    25
    Alhambra, CA
    I'll check those from the surrounding stores near me if those are available.
  6. Mendel Leisk
    42,305
    Tire pressures per the door decal (or close), or a lot higher?
  7. Yea Right
    Yea Right Active Member
    232
    115
    Seattle
    2014 Prius Plug-in
    “a 2005 Galant with Goodyear Comforted tires “
    is that even comparable
  8. ThatOddMan
    64
    25
    Alhambra, CA
    A 2005 Galant ES, a base model, is loud like no sound proofing material at all. Replacing the the tires with that Goodyear Comfortred made it a better car.
  9. ThatOddMan
    64
    25
    Alhambra, CA
    Toyota dealer set it to the recommended tire pressure.
  10. vvillovv
    vvillovv Senior Member
    4,336
    1,518
    NY
    I replaced out Primes OE toyo's with the "goldilocks" but no negative review here concerning the refit.
    I had harmony's for the last full set I purchased for the older car and two of them were still on the car after 100k.
  11. ThatOddMan
    64
    25
    Alhambra, CA
    I checked the service history.
    Defender got mounted and installed by a Toyota dealer 07/2017 at 100,037 miles.
    That Toyota dealer installed the tires but was incorrectly mounted the tires on the wheels/rims. I had to spend cash to have those corrected.
    Car mileage after last month's service was at 158,600 miles.
    According to last month's service report, the tread depth are "4/32 RF RR AND 5/32 LF LR".
    Maybe that is the reason why of the premature decrease in the expected miles on the Defender and the decrease in ride comfort? Defender has 80k miles right?
  12. Mendel Leisk
    42,305
    80k's at 2/32" remaining tread? You're not that far off:
    I'd guesstimate new depth is 10/32, and with min 2/32 gives a "useable" tread life of 8/32. Two of yours are at 4/32, have a remainder of 2/32. So, they've gone through 6/8th's of their "life". 6/8 times 80k is 60k. You're pretty close, at 58.6k~.
    That's more straightforward than I was expecting lol.
  13. Jacquelyn Bergert
    Jacquelyn Bergert New Member
    Gardner Ma.
    2002 Prius
    I have a 2002 first generation Prius I need help my triangle light and brake light came on at the same time and my car just stopped accelerating and wouldn't turn back over after I shut it off what do I do and what is wrong please help
  14. ThatOddMan
    64
    25
    Alhambra, CA
    Probably the 12-Volt battery... the small battery.
    Or worse the HV battery.
