Another Tire Thread - Mixing Tires
Discussion in 'Generation 1 Prius Discussion' started by Oc.dreamer, Jul 19, 2014.
  1. Oc.dreamer
    Oc.dreamer Junior Member
    32
    2002 Prius
    I
    sorry.. I know there are many tire threads and for the last couple hours I've searching through them with no luck.
    I have Dunlop SP10's on my ride but today I am replacing my two rear tires with Michelin Defenders which are rated at 82T vs the SP10's 84S.
    Usually, I keep my tires inflated to 42 front, 40 rear. Now that the tires have changed, can anyone help me with what my PSI should be front and rear?
  2. bwilson4web
    16,512
    OWCH!
    In a perfect world, get a pair of the largest diameter tires that will fit in the wheel well and put them on the front. But for now, you've joined the experimental group. So let me propose two experiments:
    1) max sidewall pressure in all tires - to establish a baseline and then drop the pressure 5 psi to the door jam pressure over a series of test segments: 10 miles each direction and cruise control maintained speed. This will let you evaluate the efficiency and handling.
    2) max sidewall pressure all tires - swap the front and back over the same route. Look for straight-line stability. Measure the indicated and actual distance traveled.
    My experience has been handling improves with the larger diameter, heavier tires on the front drive wheels. But mine are 6% larger diameter.
    Oc.dreamer likes this.
  3. Oc.dreamer
    32
    2002 Prius
    I
    Thanks bob! I'll try it out and report back in a few days
  4. Okinawa
    Okinawa Senior Member
    1,333
    320
    Just what Toyota recommends. There is a sticker inside the drivers side door jamb.
