Another triangle of sadness, please help me?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by lucasanderson298999, Nov 8, 2023.
  1. lucasanderson298999
    lucasanderson298999 Junior Member
    27
    los angeles
    [​IMG] Cruising down the highway in my trusty 2008 Toyota Prius, the dashboard became a constellation of lights—particularly, the red triangle of sadness with its dramatic exclamation point and the car icon, mirrored on the screen that usually showcases radio stations. As I stepped on the gas, an unexpected hiccup occurred—the car got stuck, adamantly resisting further acceleration. It was like grappling with the sensation of an emergency brake engaged, the accelerator pedal stubbornly resisting full engagement.
    In the midst of this, I found myself confessing to a refueling faux pas—I closed the gas cap, but not with the satisfying click that assures proper closure. Realizing this error, I promptly corrected it, I read on this website this might be what caused it. The hope was that a proper gas cap closure, coupled with a 12V battery reset, would vanquish the menacing red triangle. Alas, the reset maneuver failed me. I got a sense of doom once I noticed the air conditioning, once a reliable purveyor of chilly relief, capriciously transitioned to blowing room temperature air during this commute. Ten minutes later, the dashboard turned into a carnival of lights.
    Now, the question lingers: Could the aging 12-volt battery, I got six years ago, be the elusive culprit? Adding to the automotive melodrama, both oil and brakes are overdue for a change (I know, I know). Consulting the collective wisdom of online forums, the suspects for the triangle of sadness's mischief range from a gas cap closure to the aging 12V battery, the inverter cooling pump or 3-way pump, a malfunctioning main hybrid battery, or even the hybrid battery fans.
    Oh, and let's not forget the recall episode in 2015—I got the three-way pump (or is it called the inverter pump?) replaced for free that year.
    Please help this old man??
  2. JC91006
    16,936
    8,647
    it could be a combination of many issues. But my guess would be hv battery failure and/or inverter cooling pump failure. If you haven't changed the oil in a while, the engine might also be starved of oil
    Has nothing to do with the gas cap and 12v battery
  3. lucasanderson298999
    27
    los angeles
    thanks so much for replying, I made a mistake, it was actually the 3 way coolant valve that was replaced under the recall. Would you mind helping me by answering some questions? 1) if it's the same 3 way coolant valve issue again would it be covered by the california 15 years or 150k warranty? (what is actual name of this warranty?)
    and 2) if it's the HV battery that's dead, is this covered with the california 15 years or 150k warranty? How would I go about using this warranty?
  4. JC91006
    16,936
    8,647
    Your 3 way coolant valve is not causing those lights, I mentioned it could be a combination of you HV battery failing and/or inverter pump failing.
    Your 2008 is out of warranty for emissions related parts and also out of warranty for hybrid battery. emissions warranty is 15 years/150k miles. hv battery warranty is 10 years/150k miles.
  5. rjparker
    rjparker Tu Humilde Sirviente
    11,045
    6,922
    Texas Hill Country
    If you are getting 35 mpg the hybrid battery is a suspect.
    Codes will tell the story. Being in LA you should take it to an independent for a quick diagnosis, perhaps Hybrid Pit.
  6. lucasanderson298999
    27
    los angeles
    I
    I'm so out of luck...1) Thanks for the info, would you recommend purchasing only original toyota HV battery? or aftermarket? if so any brands you recommend? 2) I noticed you're also in L.A. can you recommend a hybrid mechanic shop? I was looking into Electric Ave in Silverlake. 3) As for price range, is this correct? HV battery replaced around $1200 without labor, inverter pump 350 labor and part
  7. JC91006
    16,936
    8,647
    You should always check the codes to make sure of the problem before you do any repairs. What I replied with is just my experience from the symptoms you're experiencing.
    If you are in need of a hybrid battery, of course a new oem battery would be best. The cost for something like that is $2500 installed and will give you 10+ years of reliable service. There are cheaper options for "rebuilt" batteries. But the rebuilding quality can vary greatly and can potentially give you lots of headaches when the battery fails again.
    As for the inverter pump, the price a professional will charge is $500+. If you buy the part and do it yourself, an OEM part will be around $120.
    Both of these items are fairly easy to do on your own. Lots of information on this site to help guilde you with the repair.
  8. JC91006
    16,936
    8,647
    The shop I recommend would be the one I'm always at, a shop in Rosemead CA, Armstrong Auto Services. Everyone there drives a Prius so we've seen and repaired almost every issue with the car.
    #8 JC91006, Nov 9, 2023
  9. dolj
    dolj Senior Member
    8,635
    4,389
    Wellington, New Zealand
    That is a bit off the mark for the battery. Price is usually in the range of $1650-$2000. Labor is usually $400-$600.
    Buy only a new battery; there are very few new aftermarket options so be very careful looking at aftermarket.
    Do not buy any reconditioned/remanufactured/rebuilt batteries unless you would be happy with 6 months to two years life out of those solutions.
    The inverter pump price is good if they are using a new OEM pump. Aftermarket pumps can be cheaper but the statistics on reliability do not go in their favour.
  10. ChapmanF
    18,987
    ^^^ This.
    Always makes me sad to see a thread go on this long, with talk of hundreds of dollars for parts, and no trouble codes looked at yet.
  11. Mendel Leisk
    42,301
    Enter your age in your profile stats? It's always good to know; you get a sense of the mindset.
    #11 Mendel Leisk, Nov 9, 2023
  12. mr_guy_mann
    mr_guy_mann Senior Member
    4,111
    2,011
    NJ-USA
    Human nature. Most people understand "replacing parts". Very few want to learn how something works in order to test it properly.
    Try to educate those will listen. Otherwise grab a box of tissues, dry those teary eyes, and move on.
  13. Tombukt2
    Tombukt2 Senior Member
    13,836
    2,512
    Durham NC
    The inverter pump is a 30 minute job for the monkeys and the Amoco transmission commercial from the '70s very straightforward My recommendation would be removed the pump from the bracket leave the bracket in the car squeeze the hoses closed stick a cork in them whatever leave most of your coolant in the system change out the pump reattach the hoses Don't forget the electrical connector and no you don't have to remove the headlight unless you just like to do those sort of things You need a 10 mm short socket two 6-in extensions a pair of vent needle nose which are very inexpensive at any store you'll need them later too and that should pretty much get you ripping so if all that is worth 300 plus dollars to you sounds good The pump now should be able to be had for about $120 130. So the rest is your time or money for the 45 minutes I'll take my time any day.
  14. ChapmanF
    18,987
    Hey, I said sad. I didn't say that sad.
  15. lucasanderson298999
    27
    los angeles
    Hello sorry for the delay. To update you all, the code that came up was for the inverter pump, I got it replaced, but now the dashboard lights wouldn't want to turn on. I tried the cheat code I saw on youtube, where I press the ON button then press the CLIMATE button for three seconds, and that made the dashboard lights turn back on. I am now wondering if this inverter pump did something to the dashboard lights? AH!
  16. JC91006
    16,936
    8,647
    I'm not sure which dealership will charge only $400. That is very low in the Los Angeles area. That is more the price of a small garage or a side job for a mechanic.
    Hopefully that is all the codes point to, it just seems the warning lights might point to more than just that one issue, there are just too many warning lights on.
  17. lucasanderson298999
    27
    los angeles
    Hello, sorry I have another update, please see? To update you all, the code that came up was for the inverter pump, I got it replaced, but now the dashboard lights wouldn't want to turn on. I tried the cheat code I saw on youtube, where I press the ON button then press the CLIMATE button for three seconds, and that made the dashboard lights turn back on. I am now wondering if this inverter pump did something to the dashboard lights??
  18. JC91006
    16,936
    8,647
    You have a combination meter problem, the speedometer has a capacitor that needs to be replaced. It's a common problem for this generation car.
  19. Tombukt2
    13,836
    2,512
    Durham NC
    Circuit board on dash top that has beeper on back of it needs capacitors replaced. Is very common and on YouTube . But car still drives and maybe check engine light works on boot of car I drive with no display all time on two cars.
  20. ChapmanF
    18,987
    When you're posting about an issue on PriusChat, you can always get the best informed responses if you include the actual code(s) in your post, not just what somebody said the code was "for". If you say it was P0A93, for example, we all know what that code is, or can look it up. If you just say it's "for the inverter pump", we don't really know what code you had, or what you found that said that code's "for the inverter pump", and we're kind of groping backwards in the dark.
    As a first guess, was your code P0A93?
    This is another example where it helps a lot more if you get us straight to your source of information. "Cheat codes" are gamer things, not Prius things. There are a number of specific procedures that are shown (in the repair manual, not random youtubes) for doing specific things, though I'm not familiar with any like the one you describe here. You can find lots of youtubes, though, that say lots of things. If you include a link to the one that you found, that gives us a way to see what it's talking about, or whether it's just bogus (a lot of them are).
    As other posters have suggested, the dash problem sounds mostly like the bad capacitor issue. It's a known issue. It will behave pretty randomly for a while before it conks out completely. People prone to wishful thinking often try a bunch of random things while it's behaving randomly, which means some of those things will coincide with the dash lighting up again, and may then end up on youtube as "cheat codes".
