another victim of the "too tight oil filter cap"
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Maroon, Mar 18, 2013.
  1. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    The country of origin is not of concern to me if it is still a quality product. Those caps are being sold under the "BluePoint" name, which sells Snap-On's foreign-made products.
  2. Mike500
    Mike500 Senior Member
    2,593
    767
    The Toyota OTC one is made of steel, not aluminum. The center is welded fully around the steel "cup." Both have been case hardened. Most all others are aluminum, including the Snap-On. The Assemacher, also made of aluminum, is likely better than the Snap-On.
    If the cap was tightened by the Toyota dealer, it is most likely that they used the Toyota approved service wrench.
  3. The Critic
    3,193
    2,333
    CA
    I don't remember much about the Toyota one, but the Snap-On/blue-point cap has cut-outs that allow for better grip than most of the filter wrenches that I've seen.
  4. dbcassidy
    dbcassidy Toyota Hybrid Nation, 8 Million Strong
    1,581
    290
    Middlesex County, MA
    How about something hi-tech? Review the pictures on the oil filter cardboard carton. If the installer follows the picture, there will not be any future issues w/ oil filter removal. People need to take a minute and read the installation instructions. It can't get any simpler than that.
    DBCassidy
  5. El Dobro
    El Dobro A Member
    7,088
    3,270
    It also holds the little spring out of the way.
  6. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,698
    1,745
    Bay Area
    Here's the video to show you guys how to do your oil change on the Prius
  7. Mendel Leisk
    41,463
    FWIW, Honda's oil filters are identical, and there's a socket available through them.
    Crazedcommuter likes this.
  8. Crazedcommuter
    Crazedcommuter Junior Member
    22
    Eastern Panhandle, West Virginia
    I've been DIYing my own oil for 30 years and have a pretty good feel for torque without a torque wrench. I did my 1st oil change on my 2012 Prius yesterday and used the same cap wrench that I use on my 2005 XB and 2008 Solara. It was a tad loose on the Prius canister housing so I wrapped a thin piece of rubber around it (same rubber used for getting a grip on kitchen jars) and it worked fine with no issues. I'll be getting the right tool soon but this works fine in a pinch.
  9. Maroon
    Maroon Member
    159
    88
    Tupelo, MS
    The Assenmacher from Amazon came in and I finally had a dry weekend to change the oil. That tool plus a big 15/16" wrench made the job easy.
  10. alanwagen
    alanwagen Member
    122
    79
    FORT WORTH
    2018 Prius
    My 2010 is my first car that I take to the dealer for a oil change. I look for a coupon and have them do it. With only having to do it every 10k miles, I don't mind the extra expense. We also have a 09 Prius which I do change myself, again every 10k miles with synthetic oil. Even a 10k miles, the oil still looks good.
  11. plugged-in
    plugged-in Junior Member
    22
    irvine
    What model number is that Assenmacher, or can you post a link? Thanks.
  12. El Dobro
    El Dobro A Member
    7,088
    3,270
  13. corystal
    corystal Junior Member
    40
    Los Angeles
    I tried the jaws type on mine yesterday, it might have worked, but they are stripped out and move to the larger size when torqued. It would have been kinda tight even if they had worked.. about 10 degrees of movement. So I took the van to the toyota dealership and dropped $12 on the tool... worked like a charm. Moral: just go get the tool, if you plan to be doing the oil yourself. It's a lot better than the $120 or so I had to spend fot the tool to remove my VWs spark plugs :O
  14. SmellyTofu
    SmellyTofu Average punter
    251
    29
    Sydney
    I used a tool I bought for eBay for $20. The hardest part of the oil change job is pulling the underbody cover.
  15. NutzAboutBolts
    1,698
    1,745
    Bay Area
    Not really hard since there's only 3 clips to take off lol...
  16. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    Yeah, holding the front of the Prius up with one hand leaves only one hand free to flip the underbody cover.
  17. El Dobro
    El Dobro A Member
    7,088
    3,270
    I just flip the car over on it's side.
    Chris S and FL_Prius_Driver like this.
  18. NutzAboutBolts
    1,698
    1,745
    Bay Area
    I just tell my Prius to roll over so I can change the oil.
  19. Mendel Leisk
    41,463
    I think he's taking the whole cover off.
  20. NutzAboutBolts
    1,698
    1,745
    Bay Area
    yeah... But, its not required :)
