Ant invasion
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by tarantoga, Sep 4, 2013.
  1. tarantoga
    tarantoga Junior Member
    52
    Alameda, CA
    This is a problem unique to plug-ins: I found a trail of argentine ants climbing up the charging cable, and some on the inside dash. After half an hour following ants I found them nibbling on a dead fly in the engine compartment...
    So, given that every car probably has dead bugs stuck somewhere in the cooler ribs - any good ideas to keep ants out?
    I sprinkled some "kills ants on contact" pulver on the cable going up, but that's not a permanent solution.
  2. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    It's not really unique to plugins. Your tires touch the ground like everyone else's tires and that provides a trail anywhere in the car.
    Personally I like RAID to kill the buggers, but it is not very eco-friendly and spraying it on a cord you will handle with your hands is probably not a good idea.
    I would tackle to problem a different way. Instead of trying to get the ants to not climb the charger cable, get rid of the ants around the car. If this happens in your garage or on your property then some good traps and/or sprays might get rid of the problem entirely.
  3. chesleyn
    chesleyn Active Member
    596
    158
    Los Angeles
    I have spiders that like to sleep in the plug compartment.
    iPad ? HD
  4. hill
    8,992
    Call vector control. Many so Cal cities have programs to eliminate (what we here call) red ants.
  5. Astolat
    Astolat Member
    229
    73
    Guildford UK
    I have a moth doing the same, attracted by the light...
  6. 3PriusMike
    3,101
    2,421
    Silicon Valley
    You need to charge more often...OTOH, finding them next to the gas cap...could take m emonths sometimes to notice this. :)
    Mike
  7. 3PriusMike
    3,101
    2,421
    Silicon Valley
    This could be part of a "how green is the Prius?" ad. Even the bugs like it.
    Mike
  8. SAronian
    SAronian Active Member
    334
    144
    Oakland, CA
    For trees we use Tanglefoot. But probably too messy for a cable you want to pack up and store.
