Antarctic melting
Discussion in 'Environmental Discussion' started by tochatihu, Dec 10, 2016.
  1. Trollbait
    12,832
    It could simply be a factor of where the water has fallen and how it drains into the reservoirs.
  2. mojo
    mojo Senior Member
    4,519
    390
    San Francisco
    Replying to coast cruiser .Agreed CO2 has nothing to do with nonexistent California drought.
    How is the ice chunk caused by cO2?
    Lets here some fairy tails?
  3. bwilson4web
    16,547
  4. tochatihu
    tochatihu Senior Member
    9,994
    3,858
    Kunming Yunnan China
    2001 Prius
    "Reservoirs will be full after this week" @53
    That week having passed we can return to the cdec page. We can calculate these reservoirs that were at 58% of total capacity increased to 69%. Thus a good week for Calif. water storage. Yet is is not reservoirs that are 'full of it'.
  5. mojo
    mojo Senior Member
    4,519
    390
    San Francisco
    That's percentage of 100% is what's normal for the of year.Many res are above normal and are being drained In anticipation of the spring melt.Which will be huge this spring with a much higher than normal snowpack.
  6. tochatihu
    9,994
    3,858
    2001 Prius
    I certainly agree that reservoirs need unfilled capacity for March/April snowmelt. So, we both disagree with mojo@53 about "full this week". Who was that mysterious poster anyway?
    Current snowpack is 115% of long-term average. What force compels you to suggest that is "much above average"?
    fuzzy1 likes this.
  7. mojo
    mojo Senior Member
    4,519
    390
    San Francisco
    "Full" when referring to CA res means level is at the average for date.Reservoirs are never allowed at 100% capacity.
  8. tochatihu
    9,994
    3,858
    2001 Prius
    Only one Calif reservoir is full in the sense of 'really near capacity'. This is Oroville, which could not be lowered by normal practice through its main spillway. Because unconsolidated fill under concrete spillway had washed away and the concrete has a big hole.
    The alternate spillway is being used and that presents problems because it is an unlined channel and very susceptible to erosion. I just looked at current Orovile lake level and is is still rising. Approaching 'overtop'. Certainly hoping for a low-damage outcome here.
    BTW mojo and I should have apologized before for intruding on Antarctic matters here. Would have been better to ressurect the Calif drought thread.
    bwilson4web likes this.
  9. bwilson4web
    16,547
    Source: Oroville Dam energency spillway in use for first time in dam history | The Sacramento Bee
    Impressive water flows but my understanding is the dam itself is not at risk. That hasn't always been the case as some earth-filled dams have collapsed in the past. I'm thinking of the Baldwin Hills Dam.
  10. tochatihu
    9,994
    3,858
    2001 Prius
    This tallest US earthen dam will hold. Trouble is effort & expense to manage situation. Not that you-know-what has anything to do with meteorological extremes...
  11. tochatihu
    9,994
    3,858
    2001 Prius
  12. bwilson4web
    16,547
    Well in addition to setting more high temperature records, a new word "bombogenesis".
    Source: link
    Apparently it takes a polar air mass on land meeting a huge slug of tropical moisture. Hummm, where did all that moisture come from?
  13. bwilson4web
    16,547
    More weather, not climate, just ordinary weather news: Once-in-a-decade heatwave melting the Arctic ... for the third time this year. Why? - CSMonitor.com
    First, the facts. January sea ice area has never been so small. In November, the coverage fell short of average by an area the size of the eastern half of the United States. Northeast Greenland had its warmest February day ever (by almost four degrees). The current heat wave brought Friday’s temperatures near the North Pole to 50 degrees above average, which is like New York City having a January day in the mid-80s.
    This kind of unprecedented weather leaves even seasoned researchers scratching their heads.
    “We’re still trying to figure out what is happening here,” Mark Serreze, a senior research scientist with the Colorado-based Snow and Ice Data Center, told KUAC. “The sea ice is so low there in part because it’s just been so darn warm in the Arctic this winter.”
    Of course, there’s a huge difference between weather and climate. The Earth is a vast and chaotic system, and heat waves as well as cold snaps can happen anywhere. But how often they take place can give insight into general patterns.
    Hummm, curious and then there is this slug of arctic air headed to the NorthEast instead of the Arctic circle.
  14. wxman
    wxman Active Member
    636
    231
    Tennessee
    As of 7:00 AM AKST this morning (2/12/2017), the temp at Fairbanks, AK, airport was -38 F (-39 C). So it looks like there's pretty cold air there also.
    I've also been keeping occasional track of a buoy (Buoy 48282) well north of the Alaska north slope in the Arctic Sea that's consistently been around -30 F since I've been keeping track (few months now).
    Maybe there's a unusually amplified flow over the northern polar region this winter?
  15. bwilson4web
    16,547
    There was:
    Massive hurricane-force Atlantic storm to push abnormally mild air toward North Pole
    My understanding is this pumped a lot warm moist air towards the Arctic circle and may have helped reduce the sea ice freeze-up.
    #75 bwilson4web, Feb 12, 2017
    wxman likes this.
  16. wxman
    wxman Active Member
    636
    231
    Tennessee
  17. bwilson4web
    16,547
    Sorry, it seems this version of PriusChat 'eats' URLs. It was the Atlantic side, east of Greenland that had an impressive low pumping warm air up.
  18. wxman
    wxman Active Member
    636
    231
    Tennessee
    It looks like cold air is pooling on this side of the north pole. The apparent high amplitude upper flow is causing surface cold air mass to be displaced on this side of the pole.
  19. bwilson4web
    16,547
    Sounds like we may have a late hard freeze to kill the peaches.
  20. tochatihu
    9,994
    3,858
    2001 Prius
