Antenna/Amp Failure??
Discussion in 'Gen 3 Prius Audio and Electronics' started by ChazB, Jul 23, 2026 at 4:53 AM.
  1. ChazB
    ChazB Junior Member
    Sacramento, CA
    FM radio, simple standard gray screen, suddenly lost reception and nearly all channels are now static noise. I can get two channels with a strong signal, but they have static noise too. Do I need a new antenna base and amplifier assembly? Has anyone replaced it? I think I’ll probably have to pop the liner off the roof inside with pry tools and then connect to the plug to the existing wire harness. Any input is appreciated. Thanks
    Toyota 86300-47120 Amplifier Antenna Assembly
    2011-2015 Toyota Prius 8630047120
    Customer Questions & Expert Answers (2)[​IMG]
  2. ChapmanF
    18,977
    Is there any history of replacing headlights in the car with LEDs? They can have that effect. Easy test in that case is whether your reception comes back when you turn the headlights off.
  3. rjparker
    rjparker Tu Humilde Sirviente
    11,038
    6,920
    Texas Hill Country
    I replaced my v's antenna amplifier about ten years ago. It required removal of the right side hatch panel in my case in order to pull the headliner down at all. There are three versions depending on the car options. A hatchback probably uses different part numbers due to cable length.
    Now Toyota has a tool to test the system.
