Antenna Upgrade?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by jenzfc, Jan 20, 2013.
  1. jenzfc
    jenzfc Junior Member
    San Francisco Bay Area
    I love my Prius 2012 package IV, the HD radio in the JBL sound system sounds amazing, the problem is the antenna i believe, sucks...
    I've read in some other websites that if you install a Shark antenna, the signal is better... is it true? if it is, which antenna do you recommend? at eBay they sell them for $7.99, aren't they way too cheap? is it hard to install?
  2. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    Lol, read the description closely. Those cheap sharkfin antennas are purely cosmetic.
  3. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
    If you have the solar roof make sure the shark antenna does not overlap. You need to get the smaller version.The install is tricky you need to glue it to the car also.
    I'm ok with the OEM antenna. Just unscrew it before you go through the carwash.
    jenzfc likes this.
  4. Blu-ray
    Blu-ray Blizzard Brigade #215
    471
    198
    TampaBay, FL
    I would recommend not going cheap on it. I plan on getting a shark fin in a month from the Prius Chat store. They will match your car color.
  5. jenzfc
    Yeah, I have the solar roof.
    So guys, you recommend the antenna from the PCStore? Is it small enough? You know, considering I have the Prius with the solar package + sunroof
    JMD likes this.
  6. Blu-ray
    471
    198
    TampaBay, FL
    When ordering it asks you if you have the solar package or not.
    PriusChat Shop : Toyota Prius Shark Fin Antenna - $82.00$78.00
  7. RaZa
    RaZa Member
    480
    93
    got my fin the other day. Installed very easy and it looks nice. I never really liked shark fins, but I like this better than the antenna. Especially now that I don't have to worry about it when running my car through a car wash. I always had to remember to remove the old antenna as I didn't want it to get bent too far.
  8. JMD
    3,779
    1,282
    So Jen did you get it or delayed?
  9. skwcrj
    skwcrj Member
    278
    68
    Gig Harbor, WA
    Re: Signal Strength
    I have a Shark Fin antenna from the Prius Shop. Before making the final install, I connected the Shark Fin antenna and picked a weak distant radio station as a test. There was no change in reception with either the OEM or SharkFin. Basically, the Shark Fin antenna won't worsen or improve your signal strength. It should remain the same.
