Anti lockout feature
Discussion in 'Gen 2 Prius Main Forum' started by mass_cheapo, Apr 29, 2018.
  1. mass_cheapo
    mass_cheapo Junior Member
    SE MASS
    I read that there is a switch at the base of the steering wheel to control the anti lockout feature. I only have 3 delete covers there, no switches behind them. Was this an option?
    Only recently did the car icon with the key inside start flashing, after 8 years of ownership!
  2. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
  3. mass_cheapo
    SE MASS
    thanks, so i don't have it. any ideas on why the icon just starting showing up?
  4. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Does the 'car icon with the key inside' (hybrid vehicle immobilizer / theft deterrent system) only appear when the vehicle is off and with the doors locked?
    Have you ever changed the fob battery? (always a good place to start)
    Here is the owners manual, read up on the keys and doors section 2-1 (page 17), hopefully that will bring some clarity to the potential problem.
    https://www.toyota.com/t3Portal/document/om-s/OM47482U/pdf/OM47482U.pdf
    Raytheeagle likes this.
  5. bisco
    52,849
    what is the 'anti lockout' feature?
  6. RRxing
    RRxing Senior Member
    2,563
    1,842
    NEPA
    I will assume it prevents the doors from being locked from the outside if a fob is detected inside. Why you would want to turn that feature off is beyond me...
    srellim234 likes this.
  7. bisco
    52,849
    i had package 6, and had no idea there was a switch for that.(n)
  8. dolj
    dolj Senior Member
    8,645
    4,395
    Wellington, New Zealand
    It is a feature only on cars with SKS.
    I wish it was clever enough to figure out that one key is in the car and one key is out the car (like right next to the driver's door!), so go ahead and allow the car to lock. Such a nuisance to have to make SWMBO get her purse/handbag out the car all the time.
  9. Tideland Prius
    16,680
    It's the SKS-Off button
  10. bisco
    52,849
    ah, never heard it called anti lockout. how does it prevent you from being locked out? i thought it just stopped transmitting so you have to use the fob buttons instead of touching the door handle.
    i really thought of it as a battery saver.
  11. Tideland Prius
    16,680
    The key lockout feature is a separate thing that doesn't have a button. So really I'm just guessing based on the location.
  12. bisco
    52,849
    ah, i guess i'm back to square one. o/p seems satisfied though, probably smarter than me.:oops:
