Any appreciable gain with 0w-20 oil?
Discussion in 'Gen 2 Prius Fuel Economy' started by PriusGuy32, Dec 13, 2012.
  1. Hi Burrito!
    Hi Burrito! Regenerative Farting
    68
    42
    Fremont, California
    Thanks to both uart and PriusGuy32 for the great answers. I'll go with the Mobil 1 0w-20 from Walmart. It is indeed a great deal, near the price of conventional oil without a coupon. I'll stick with the Toyota filter and 5,000 mile oil change interval. And I'll keep an eye out for oil consumption.
    Hi Burrito! is a play on the Japanese loan word for "hybrid", which is "haiburiddo". Plus, it sounds like it'd make a great name for a Mexican fast food restaurant in Japan. And who doesn't like burritos?
    PriusGuy32 likes this.
  2. PriusGuy32
    1,417
    514
    Harrison Township, Michigan
    Im craving one right now....
  3. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    That would be a perfect name for a restaurant that served Mexican/Japanese fusion (hybrid) cuisine.
    Sashimi Tacos
    Squid Burritos
    Rice Tortillas
    Salsa Wasabi
    Merkey and PriusGuy32 like this.
  4. Agent J
    Agent J Hypoliterian
    294
    111
    Sydney, Australia
    cool play on words there... :LOL:
    if i may chime in.. i think the best way to increase mpg without changing oil grades between oil changes? driving habit.
    I've been using 5W-30 on my gen2 since i purchased it and have always been contemplating on using 0W-20
    whenever it's due for service but ended up still using the more affordable 5w-30 every time. For some reason, the search for that extra mpg still lies on our foot and how it treats the gas pedal. Reading up on hypermiling techniques and applying what works for your driving environment/situation and honing that skill over time will reap more mpg rewards than the gains from changing to a more expensive oil grade. It's a fun thing to do anyway! Otherwise, if they cost about the same or even cheaper, then yeah, use the 0W-20. A lot of people here use it with no adverse effect.
    The only time I might try 0W-20 is probably when I've reached my hypermiling limit where I could easily
    tell the difference between a really good oil and a really really good oil.
    just my .01 mpgs :D
  5. Speedfink
    Speedfink Certified Bad@$$
    26
    SoCal
    Four Touring
    I beg to differ on the air filter restrictions. It can and will make a difference in fuel economy due to the fact that, a dirty or more restrictive air filter restricts the ability for your Naturally Aspirated ICE to get air to mix with the fuel that is injected. This doesnt mean that your engine is not going to get the air, but on the same token that a supercharger acts as a parasitic power drain to PUSH more air in, a clogged or restrictive air filter forces your engine to waste more energy PULLING the air that it needs in. Whether the difference is 10% as the VW service place suggests is relative to how dirty or restrictive said filter is, and what kind of engine are we talking about...
  6. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    A closed loop fuel injection system, such as the Prius has adjusts the fuel mixture to compensate for air filter restriction, so no difference in AF ratio. For a car that had a carburetor or an open loop fuel injections system, you would be correct.
    Until you are at full throttle, whether the throttle plate or air filter is causing the restriction has little to no effect on pumping losses. In any case, the end result would be a slight loss of power with little to no loss of fuel economy. The same result as not opening the throttle all the way.
    If you carry things to an extreme and run an air filter until it is causing such a serious restriction that the closed loop FI system can't keep the mixture right, then you would get some loss of economy but you would have lost a noticeable amount of power by then.
    Speedfink likes this.
  7. Speedfink
    26
    SoCal
    Four Touring
    I'll buy that for a dollar. I still feel that, even with closed loop, there may be some residual loss during the time that the system is compensating, and I'm sure that between the two of us, we could argue it down to the molecular level, but the gist of it is that any losses would be negligible I'm sure.
  8. Prius_Cub
    Prius_Cub Member
    152
    60
    Radford, VA
    What's your experience with the change over so far? I'm considering switching to the 0w/20 myself when I need to do my first oil change.
  9. PriusGuy32
    1,417
    514
    So far its been pretty unremarkable. I notice little/no difference than when I had 5w-30 in the engine. Then again, its the first winter Ive had the Prius (I just bought it Sept 2012) so I dont really even know if Im experiencing a mpg gain with the 0w-20 because I dont have last winter mpg data to compare to. Im averaging 43.5mpg right now (almost ALL city driving) and I live in cold wintry Michigan :X3: I do use a block heater, which helps a little with mpg's too by speeding up the warm-up process. In other words, what I am trying to say any mpg gain with the 0w-20 alone is a little more difficult to ascertain in my case.
    When I first put in the 0w-20, I did notice some upper end engine noise but it has subsided. Could've just been coincidental. Either way Ive decided I will run Mobil 1 AFE 0w-20 in the wintertime and Mobil 1 5-30 in the summertime.
    Britprius likes this.
  10. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    Other than possibly increased engine wear, nothing.
    iPhone ?
    ukiltmybrutha likes this.
  11. 2007blueprius
    2007blueprius Member
    466
    33
    someone please elaborate, I assume, 5w30 is the recomended fill, plain, mineral, every 5000 miles, ow20 say full syntetic is a thinner oil, I noticed most newer cars run it, aparently for efficiency gains, myself I am due for a change, and I was really contemplating an extended oilchange, like 15k, with filter in the middle, I've always run 5w30 / 3k in my other vehicles, on other forums I noticed a hype about mobil 1 15k, some used it in old style pushrod domestic engines where tolerances are larger than most modern engines.
    my reasoning for this is the same that I bought the prius for, I know there is a lot of debate over the cost of the prius justifyng the fuelconsumption, but as far as I am concerned I aim to reduce my contribution to oil "industry" as close to zero as posible particulary the imported kind, and with a bit of smart shopping the premium was not that bad.
    that beeing said the thought of all these gallons beeing hauled arround, recycled and so forth bothers me these days, so 15k oilchanges, compared to the 3k I always advocated in the past mean 5 x less footprint on my part
    I don't see why this would be unatainable, as the nature of the prius, not iddleing for example, implies less wear than a regular car, so in turn say for the sake of conversation, it will hold up to 15k better than my 2.2 pushrod chevy, also one thing I have in the works is converting to propane as it is mostly if not all domestic and plenty of if particulary since its unheard of arround here, for those of you who do not get my point, read up on it, its a better fuel, from many aspects cost/ emisions, thou in michigan not a concern, just personal, better on the motor, and oil for that matter,
    one concern I have, I read throu some posts, I am unclear as to why but supposedly its in the cars nature to dump some fuel in the oil, with propane this should be avoided as well.
    any thoughts please pitch in I'm close to 45k its time for a change and since the weather has been getting nice I am compeled to do it, since this would be the first one since I got the car I could use some feed back and please consider the reasoning behind my thought process, it is more important to me than the $2 id save buying cheap oil
  12. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    What you say sounds like a good experiment to try. I always advocate following the manual in order to maintain your warranty. The power train is warrantied for 5 years or 60k miles so I would wait until that point before experimenting with extended oil changes. If I had a Gen 2 Prius, I'd probably go with 0w20 synthetic and 10k OCI. It's basically the same engine as in the Prius C, so it should have no problem with that. If you really want 15k then you could do a UOA at 10k miles and see what you have left.
  13. 2007blueprius
    466
    33
    I am realy not too concerned with the waranty, I bought mine used/cash its allready 6 years old and I'm no stranger to wrenches, as for a uoa, I was planning on that too, however I have no Ideea as to where to send it I was never too concerned with it at 3k, any pointers?
  14. mmmodem
    2,732
    1,703
    Bay Area, CA
  15. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    You really won't be able to compare until you've wrapped around to the temperatures that you had before the oil change.
    Per my fuelly listing, I was getting 12% better mileage in September than I did last month and I chalk that all up to temperature (the driving profiles are about the same). I'd say by early to mid-May you'll have a better idea of what difference there's been with the oil.
  16. SteveLee
    SteveLee Active Member
    645
    180
    North Carolina
    I
    I'm with you on eliminating as much oil and gasoline use as is practical. My first oil change was to Mobil 1 0w20. I think the car was pretty well cared for before I got it with 96k miles on it. The 0w20 has resulted in a quart of use in about 7k with some mild lifter type tapping. That's not terrible but I'm guessing 0w30 will result in less oil consumption and noise. Of course, this is in the mid-atlantic states moderate weather. My mpg has been good at 50-55 mpg mostly, depending on how it's driven. Wife gets 45 around town and the son gets 60+ on country roads going mostly around 45 mph. Haven't decided if I will go 7,500 or 10,000 miles yet. With 7,000 it's getting a little dirty looking. I wouldn't go 15,000. I'm looking for longevity. I really do need to change the transaxle fluid though. It's probably never been done.
  17. frodoz737
    frodoz737 Top Wrench
    4,702
    2,500
    33
    For cold weather you can go 0w30 instead of 5w30, but I would not recommend going below 30 on the high end for two reasons. The engine presumably was not designed with the higher tolerances of the 1.8l engine in GEN IIIs and your engine has over 53k miles on conventional oil, so it is not as tight as new. The question whether the "new and improved oils" can go 15k between changes is still in debate, but even with a filter change mid way, remember not all contamination is particulate. There is gas blow by, fuel, water from humidity, ect....not to mention particles smaller than the filter can capture. My current opinion says no with your car in question. In fact I am a strongly feel that 5k oil/filter changes in your situation would be better. Your desire to not waste oil is admirable but rest assure it is recycled, resold and reused one way or another. Proper oil maintenance is the single most important and cheapest thing you can do for the health of you engine.
    Merkey likes this.
  18. Mendel Leisk
    41,514
    Toyota sanctions the use of 0W20 in second gen, assuming this is legit:
  19. frodoz737
    4,702
    2,500
    33
    Good info Mendel. However based on the previous 53k mile use of conventional oil and being a used car, I think 0w30 is the thinnest I would recommend. PriusGuy32 you were correct to do a flush with synthetic on this engine. About 200 miles max usually does the job of clean up before converting. Then again this is just my opinion, and what do I know? :notworthy:
  20. 2007blueprius
    466
    33
    how about brands, is the jury still out? I know m1 had a large campaign a few years back especialy on extended range fully syntetic, I never used it, for the longest time I used the valvoline syntetic blend, high mileage, long before the 70k, figured it wont hurt (not on the prius, just now due for my first), lately I've been getting the 50% recycled, can you see a trend here, also as for reliability, I plan on keeping this car till the whells fall off, put new ones on and go some more, I'm not into selling, I still got all my old cars, they're worth to me more than the resale
