Any carista users on gen 4?
Discussion in 'Gen 4 Prius Accessories and Modifications' started by 4thgen1st, Mar 14, 2016.
  1. Danny Troy
    Danny Troy Member
    111
    55
    Brookfield, CT
    2024 Prius
    XLE AWD-e
    I found the menu option to open all door buried in one of the vehicle settings. I believe you need to be in Park to access it. It was a little obscure, because you needed to change another setting to be able to change that one, as far as I remember. I would imagine it would work the same way with the remote. That was high on my list of settings to change.
  2. narf
    narf Active Member
    611
    45
    Colorado
    Four Touring
    Hey Carista users,
    I got the Carista OBD2 plug 3 days ago and I think I got a defective plug. I have the paid version of Carista, and it takes over 10 minutes to scan for faults on my 2016 4 Touring. During the scan it keeps switching from downloading to "connecting to bluetooth device" In order to modify any functions I have to keep unplugging and replugging the OBD2 plug to force it to reconnect to the phone. This is with a Samsung Note 4. Is this even close to normal behavior for this device?
    I sent a message to Carista but it's 3 days now without anything but the autoresponder reply. Thinking I should return the plug and either get a different brand or a second Carista unit. Andy recommendations.
    Thanks.
  3. krmcg
    2,592
    2,393
    Whittier, CA
    My unit/app works great. I would ask for a replacement unit. And I would delete and reload the app.
  4. Danny Troy
    Danny Troy Member
    111
    55
    Brookfield, CT
    2024 Prius
    XLE AWD-e
    I just downloaded Carista today and used it tonight with my Note 4. It took a while to download the data, but it did work fine. Once I saw it worked with my OBD2 unit, I paid the 20.00 for the full version. Everything works as it should. If you need it, I can probably find the exact OBD2 unit and provide a link.
  5. narf
    narf Active Member
    611
    45
    Colorado
    Four Touring
    Well, I'm going to return the OBD2-Bluetooth plug to Amazon. I've ordered a $10.00 generic adapter , I'll see if that works better than the one I'm returning. At least it's $30. cheaper.
    "IDEAPRO Car Scanner Super Mini ELM327 Bluetooth OBD2 II ELM 327 Wireless Scan Tool Scanner - Use for Android"
    EDIT: OK, Don't buy the one listed above. Apparently it doesn't support one of the Canbus protocols needed to access the customization functions.
    #45 narf, May 20, 2016
    Frederickdawg likes this.
  6. Danny Troy
    Danny Troy Member
    111
    55
    Brookfield, CT
    2024 Prius
    XLE AWD-e
    Yes, that's probably the one I got. I do remember it being super inexpensive.
  7. narf
    narf Active Member
    611
    45
    Colorado
    Four Touring
    OK, the one I listed two posts above doesn't work with customization in Carista, probably doesn't support the right Canbus protocols. Guess I'll try to get a replacement Carista brand adapter unless someone can recommend a better/cheaper adapter that supports all the protocols.
  8. Frederickdawg
    Frederickdawg Active Member
    596
    337
    Florida Unfortunately
    Although I've already bought and used the Carista. Its nice of you to share this information .
    LG-H901 ?
  9. Kasper
    Kasper New Member
    Buffalo, NY
    Yes, can you please find the exact unit you used a provide a link?
    Also, anyone have units that work, please post!
  10. Danny Troy
    Danny Troy Member
    111
    55
    Brookfield, CT
    2024 Prius
    XLE AWD-e
    I searched and found I had gotten it off eBay. The seller was tomtop.com
    The exact wording of the eBay ad is: Mini Bluetooth V1.5 ELM327 OBDII OBD-II OBD2 Car Diagnostic Scanner Tool
    Here's a link to similar units. I can't say for sure any of these units are the exact copy of the one I bought, back in 2014.
    Mini Bluetooth V1.5 ELM327 OBDII OBD-II OBD2 Car Diagnostic Scanner Tool | eBay
  11. narf
    narf Active Member
    611
    45
    Colorado
    Four Touring
    I just received a BAFX OBDII unit through Amazon, and it works really well with Carista. I would have stuck with a Carista unit but the one they sent me was defective and I'm still waiting for an email reply from their customer service after 7 days, so I've returned it. Tha BAFX unit claims to fully support CANBUS protocols. I haven't tried it with the beta version of Carista but I was able to customize functions using the BAFX unit and Carista.
    I tried to post a link but for some reason it keeps getting deleted. You can find the product by searching on Amazon for:
    BAFX Products 34t5 Bluetooth OBDII Scan Tool for Android Devices.
    As it says it only works for Android devices and only via bluetooth.
  12. PriUncut
    PriUncut Active Member
    268
    266
    Southern California
    Four Touring
    CARISTA Rocks!
    Mine came today and it works flawlessly. Easy peezy as could be. No more beep beep back-ups... and no more driver side seat belt beeps. Ahhh, silence. After all, that's part of the reason I bought this car.
    There's allot more customization possible (than I originally thought). Any other popular (common) setting changes you guys like?
  13. Autoist
    Autoist Member
    119
    81
    Seattle Metro
    Turn signal, from 3 auto blinks to 4.
    PriUncut likes this.
  14. PriUncut
    268
    266
    Southern California
    Four Touring
    Strange thing... it say's I've disabled the driver seat belt warning ding. But it's still there. I went ahead disabled the front passenger and it's still there. The dings go away with the belt connecting... but it's like there is no effect. Could I be hearing something different as I press Start?
    Here's the settings... anyone else have an issue with this?
    Seat belt warning ding (driver)
    ENABLED / *DISABLED*
    Seat belt warning ding (front passenger)
  15. PriUncut
    268
    266
    Southern California
    Four Touring
    What exactly is this? Turn signal auto blinks?
    Lane-change turn signal auto-flasher count
    OFF / 3 FLASHES / *4 FLASHES* / 5 FLASHES / 6 FLASHES / 7 FLASHES
    Regarding Seat Belt Warning: I re-enabled (to default). Turned off the car, app and locked the doors. Then went back in and DISABLED it again. Same result... but maybe it's something else I am hearing. Is the Start Up ding only one beep or is it a series of 3 or 4 beeps (dings)?
    I am still hearing about 3-4 dings that seem to go away when if I connect the seat belt.
    OR is this meant to just stop the "warning ding" IF you are in drive or reverse (without the belt connected)?
    Maybe I'm misunderstanding what the function is.
  16. krmcg
    2,592
    2,393
    Whittier, CA
    If you push down slightly on the turn lever (not fully engaged) the blinker will blink a certain number of times and stop. I set mine to 7.
  17. PriUncut
    268
    266
    Southern California
    Four Touring
    Thank you! I did not know that. Very useful. I can see the value in setting it much higher. Good deal (y)
  18. 'LectroFuel
    'LectroFuel Senior Member
    880
    673
    San Juan Capistrano, CA
    Is there a way to close the windows and sunroof with a long press from the key? I can only get it to open...
  19. krmcg
    2,592
    2,393
    Whittier, CA
    I don't think so.
    'LectroFuel likes this.
  20. Tideland Prius
    16,677
    No. You have to use the key-in-door method.
