Any downside to removing the wheel covers on the LE except for MPG?
Discussion in 'Gen 5 Prius Main Forum' started by TgrXtrm, Mar 31, 2023.
  1. Mendel Leisk
    41,406
    Best bet would be the 19” a centre cap. I would try those, hopefully fits. It’s not just the whole diameter; there’s likely locking jaws that click into a groove inside the bore, down a specific distance. Eventually someone’ll clone the caps, but likely hasn’t happened yet.
    currently gonna be hard to even determine centre cap part number; see 2023 Prius is not yet showing on parts.Toyota.
    #21 Mendel Leisk, Apr 23, 2023
  2. TgrXtrm
    TgrXtrm New Member
    22
    Ohio
    2023 Prius
    I actually got OEM wheel caps for mine on Friday because I'm bad with money. I don't know what size they are but here's a link to Toyota parts
    4260342170 - Wheel Cap. ALU, Brakes, CND - Genuine Toyota Part
  3. Mendel Leisk
    41,406
    They fit ok?
    when you’re interfacing with parts.Toyota it wants to know what car you have, and then presents parts your car has. Since yours has wheel covers, it maybe won’t show centre caps. If you say you’ve got a 2023 with 19” (bare) rims, then it’ll show the centre caps.
    Probably compatible with 17”, but a bit of a gamble. They have changed the location of the groove for the caps jaws, over the gens.
    and overriding all the above: currently 2023 Prius is not showing in their parts database.
    TgrXtrm likes this.
  4. TgrXtrm
    TgrXtrm New Member
    22
    Ohio
    2023 Prius
    Yeah they snapped right on and seem like a perfect fit to me.
  5. Mendel Leisk
    41,406
    Ok good to know. When I clicked on your link it said they're for the BZ4X, so this is a gem for 2023 Prius owners to know, if they want to take the wheel covers off, and get centre caps. Might be same part no as 4th gen too, worth checking.
    Part no:
    4260342170
  6. dbat23
    dbat23 Member
    53
    37
    WI
    2020 Prius Prime
    Wondering if you did it on your vehicle. If you’ve got a pic you can post, I’d love to see it. I’ve got a Reservoir Blue Prime coming in late June.
    Pat Midgley likes this.
  7. Pat Midgley
    Pat Midgley New Member
    Carlisle Pennsylvania
    2023 Prius
    LE AWD-e
    Confirmed with my Toyota parts manager that this is the correct number (4260342170) for the 2023 Prius LE center wheel caps. I would love to see a pictures on the wheels on the car!
  8. Ragman777
    Ragman777 Junior Member
    22
    25
    San Antonio Texas
    2023 Prius
    LE AWD-e
    I ordered part 42603-06160… fit great
  9. Ragman777
    22
    25
    San Antonio Texas
    2023 Prius
    LE AWD-e
  10. hill
    8,802
    If you don't want to spray your wheels silver there is another route. Saw this vinyl wrap on Tesla Wheels
    Vinyl wrap comes in tons of colors including silver. The good thing about this is if you decide you hate it you can use a heat gun, peel it off, and choose another color.
  11. Avade
    Avade New Member
    california
    2024 Prius
    LE AWD-e
  12. keryst
    keryst New Member
    Pittsburgh, PA
    2024 Prius Prime
    SE
    Manual says to simply pry it off at the grooves:
  13. michael144
    michael144 New Member
    Alabama
    2024 Prius
    Hello. Some tests were done on a Tesla Model 3 and they found that the wheel covers improved the fuel efficiency of that vehicle by about 3.4% across three different speeds tested. For example, if your average fuel efficiency was 50 mpg, then removing the wheel covers might reduce it to ~48 mpg, assuming the wheel covers on the Prius have a similar fuel-saving effect as the Tesla.
    I am too new to post a link, but if you search for "Car and Driver Tesla Model 3s Aero Wheel Covers Efficiency Test", you should be able to find the article I am referencing.
