Any Expected Issues with 07 GS450h?
Discussion in 'Lexus Hybrids and EVs' started by born2pdl, Jan 23, 2018.
  1. born2pdl
    born2pdl Junior Member
    62
    Utah
    There's a local 2007 Lexus GS450h for sale, 145k miles, $7500. Very clean, always garaged. What are the chances I would have 2 or 3 trouble free years with this car? Or is it nesting battery end of life? As background, I owned a 2005 prius a few years ago. Thanks.
  2. ericbecky
    ericbecky Hybrid Battery Hero
    4,452
    3,359
    Madison, Wisconsin
    Depends how long you want to keep it and number of miles driven.
    Somewhere between 150,000 and 225,000 you will likely have to deal with the pack.
    The battery is nearly a decade old as well, so it would not be unheard of it for it to die in the next few years either.
    Get a good deal on the car and set some money aside for a replacement pack.
    Or move on to a different vehicle.
    Although the 450h is a fun hybrid, that's for sure.
    Luxury, power, speed. Much different than the Prius.
  3. Britprius
    Britprius Senior Member
    5,194
    1,924
    Herefordshire England
    The most likely problems you will come across are leaking shock absorbers that in the UK are an expensive item at around £300 each plus fitting, and the rear exhaust "Y" section leaking. The rear exhaust from Lexus is £850 in the UK. Most people find it cheaper to buy a purpose made stainless steel system with a lifetime guarantee for around half that cost. There is no off the shelf aftermarket exhaust available in the UK.
    In the UK climate the battery does not pose much of an issue as perhaps it does in the warmer US states.
    John.
  4. philmcneal
    philmcneal Taxi!
    332
    Simcoe Ontario
    I wonder if any owners with gs450h in canada can chime in since we deal with a lot of salt :$ how's it is in the snow?
  5. EyesofThunder
    EyesofThunder New Member
    Rockford
    I
    I’m new to my GSh but I did pick up some Nokian snow/winter tires, it’s ok in snow, my 98 GS400 did better with Bridgestone WS70 tires. I also has Michelin X-I’ve too and the WS70’s seemed better at just pure grip
    The GSh has a better stability control with VDIM than my 2GS4, much faster to control it and smoother recovery.
