Any fix for rough ride in a 2011 Prius Three
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by surfer7382, Jun 5, 2013.
  1. surfer7382
    surfer7382 Junior Member
    We had a 2005 prius and LOVED it. But, we decided to move on and get a new one.
    How different could it be? Ha!
    I hate the new one. It is extremely uncomfortable for me in the passenger seat. Less so in the driver's seat, which is height adjustable, but still a problem for me due to physical issues.
    EVERY bump and wrinkle in the road reverberates through the car - and through me.
    The people at our dealership say there's nothing that can be done.
    Is this true?
    Thanks for any help.
  2. BZzap!
    BZzap! Senior Member
    1,607
    878
    First thing to do is check the tire pressure and air them down to the factor recommendations that are on the sticker on the lower driver door sill area. If it rides THAT bad, the tires may be overinflated. Other than that, oh well.
    ForestBeekeeper and 2010PriusIII like this.
  3. Image Group
    Image Group Bounding Overwatch to Grandmothers house we go!
    73
    San Diego CA
    Come on by and we can swap suspensions. Mine is too soft.
    xs650 likes this.
  4. 2010PriusIII
    2010PriusIII Member
    69
    24
    Boston, MA
    2018 Prius Prime
  5. ForestBeekeeper
    ForestBeekeeper Active Member
    780
    310
    Maine
    My first thought is tire pressure.
    I find it interesting that within the Prius line, the suspension varies so much from vehicle to vehicle.
    Our Prius III is great. However to follow this forum, I see that we were lucky.
    Would the answer be to test drive each model on the dealer's lot? To somehow make a judgement of which one has the best tuned ride?
  6. surfer7382
    Thanks for the responses and suggestions!
    We have tried lowering the pressure in the tires and it has a small effect, but not much. I think the suspension is overly stiff.
    We ordered our car, which we did not see as an issue at the time, since we had to order (and wait for months) for the first one. Plus, I did not believe that there would be much difference inthe cars. We had test driven one before we ordered and it was fine.
    I have tried SOME cushions, but it seems to make the back and neck issues worse, and not make a GOOD difference in the overall jarring to my body. Sometimes it was worse! The ergonomic ones are especially uncomfortable for me overall.
    I haven't given up on that approach, yet as I just got two different kinds of seat cushions (full coverage type). We'll see.
    I hesitate to take the Prius anywher but the dealer, but....
    Thanks again!
    ForestBeekeeper likes this.
  7. FriarNurgle
    FriarNurgle Member
    138
    53
    It's a 2011? Maybe the previous owner put on some aftermarket items to stiffen up the suspension. The dealer could have overlooked something.
  8. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    If you are sure that you have Prius Three, take a pic of your rims and tires.
    It could be non-OEM rim and tire size.
  9. BZzap!
    1,607
    878
    I think that if you ordered your Prius with the 17" rims and low profile tires, that could be the answer. The low profile tires would make a significant difference from the 15" wheel and tire combination, as far as ride quality is concerned.
  10. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,756
    1,784
    Bay Area
    Sounds like a suspension issue if you feel every bumps through the vehicle. You might want to get that checked out.
  11. surfer7382
    service dept says nothing can be done ;(
    definitely III, 15 in tires; ordered it brand new
    Looks like I won'; be a prius owner much longer
  12. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    What are the tires? The wrong tire can really make or break the ride quality.
    Jon Hagen likes this.
  13. surfer7382
    original tires: yokohama avid s33 p195/65 R15 about 5500 miles onthe car/tires
    we had about 7-8000 miles a year ont he older prius, but as the newer one causes problems for me, the miles are a lot less
  14. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    It's time to change tires. I suggest Michelin Defenders or Goodyear Comfortreds (?) or perhaps F8L can recommend a soft riding tire.
  15. surfer7382
    I'd be willing to change tires if it would make a SUBSTANTIAL difference.
    I still have trouble believing that there is NOTHING that can be done to the suspension itself, such as adjusting it.
    I do recall the SAME conversation about our old Taurus with multiple service providers and it turned out that the shocks were extremely worn and then failed on me - after THAT was fixed the ride was good.
    But the service dept says "nothing can be done"
    I suspect this might be because it might be charged to the dealership if it was considered warranty work.
  16. rrg
    rrg Active Member
    458
    120
    East coast - NJ
    Test drive another Prius and compare.
    If it's different show the dealer.
  17. xpcman
    1,302
    295
    LRR tires can make a large difference. With them you feel every crack in the road.
    A Prius is probably not the car you want or need. Perhaps a Camry or Lexus hybrid would be a better car for your needs.
  18. surfer7382
    I think that if LRR tires alone were the issue, the old car would have had a rough ride, which was not the case, and we stuck with LRR on that one
    However, theses ARE different tires, and it's still an option to switch the tires and that is on the list IF we can get a suspension adjustment/fix.
    I also like the idea of test-driving another Prius, perhaps even a used one of the same year/model.
    We did test drive a Camry (hybrid, of course) and it's not very smooth, either, despite the salesman's claims. It WAS cushier inside, though.
    A Lexus is a little pricey for us new and used seems to not to be an option for me due to allergy issues.
    I found a local service place that specializes in Toyotas. It's got goof d reviews on Angies List, so I will give them a call.
    Thanks for all the input!
  19. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    How is it that your ordered it (and waited for it) new yet it's a 2011 model year? Have you had it for two years?
  20. surfer7382
    huh? is the length of time I've had it relevant to any info you have that might help me?
    the ride is rough. I'm asking for possible solutions.
