Any Gen 4 Owners Out There With Blown Head Gasket ??
Discussion in 'Gen 4 Prius Main Forum' started by AmazingFacts, Jan 14, 2022.
  1. ColoradoBoo
    ColoradoBoo Senior Member
    1,240
    827
    Monument, Colorado USA
    Yep, coolant becomes acidic over time which is one reason to drain and fill every 5-years (or 100,000 miles) whichever comes soonest. The acid will start eating up the head gasket. (But Toyota has improved the quality of their head gaskets which was a much bigger issue in earlier models.) Excessive heat and acid will ruin any head gasket.
    Last year, my wife's 2017 was due even though it only had 28,681 miles and took less then 2 Gallons of Toyota coolant for both the cooling system and traction battery coolant.
    amos, Georgina Rudkus and Doug McC like this.
  2. Doug McC
    Doug McC Senior Member
    1,079
    416
    Midwest
    2022 Prius
    Yep! A very important reason to read the foot notes in the maintenance schedule and insure the coolant is being tested as required.
    ColoradoBoo likes this.
  3. CATuk
    CATuk New Member
    UK
    Business Edition
    My local Toyota garage contacted toyota GB to ask for the car to be fixed under warranty. They refused saying it is part of the exhaust and is not under warranty. They are having a look at my car tomorrow and will try and bypass the problem part, as others seem to have done.
  4. Mendel Leisk
    41,402
    Keep that in mind next time you're car shopping.
    The heat exchanger is a common fail point on 4th gen, they know, and still shirk their responsibility. Penny wise and pound foolish.
    Prius2016excel likes this.
  5. Prius2016excel
    46
    36
    England
    Excel
    You personally need to take it up by email with Toyota UK in Surrey otherwise you won’t get anywhere. You’ll need to put together a case and there’s lots of supporting information on this forum. At the moment your local garage has likely made a quick enquiry and been told “it’s not covered” without any further investigation.
    amos likes this.
  6. Mendel Leisk
    41,402
    Sounds like dealing with the Wizard of Oz...
  7. Harters
    Harters Active Member
    335
    427
    UK
    Excel
    Maybe you should contact @The Professor as he is in the UK and is getting his replaced under warranty, but is still having to pay for labour and ancillary items I believe.
    They have done the bypass whilst they wait for the part to come into stock.
  8. Mendel Leisk
    41,402
    That’s at least more pragmatic than North American dealships who refuse, citing “pollution control compromises”.
  9. MUFDVR1
    MUFDVR1 New Member
    San Antonio
    I think I might be having this issue my 2016 popped a P0117 and started to over heat and I lost all the coolant thinking it’s the heater exchange ? Could I be right ? Can you really bypass this ?
    My 2016! Is having this issue
    #149 MUFDVR1, Jun 20, 2023
    douglasjre likes this.
  10. ColoradoBoo
    1,240
    827
    Yep and one of the many reasons it's important for us to KNOW our cars...regularly pop that hood and check all fluid levels and keep an eye underneath the car for anything leaking. While it's normal to get water underneath the car from the air conditioning, take a look at it to make sure you don't see any pink/reddish color, which is coolant. Nothing will fry the head gasket faster than an overheating car which is why I've told my girls to pull over and shut the car off if they ever get the coolant light. (Yes, it might just mean the reservoir is low but it's not worth the risk.)
    In the Prius', when doing oil changes, I'll shine the line down the muffler and see if there's anything leaking or anything pink/reddish around that heat exchanger....so far, we've been good.
  11. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,462
    2,423
    Taylors, SC
    That's why there is no longer an exhaust preheater on the Gen 5 Prius. Gen5-converter.jpg
    sc91, amos and Mendel Leisk like this.
  12. bisco
    51,896
    And subsequent reduction in mpg’s?
    amos likes this.
  13. Georgina Rudkus
    3,462
    2,423
    Taylors, SC
    Also, less headaches and less wallet lightning cost to the owners and costs of replacements for Toyota.
    amos likes this.
  14. bisco
    51,896
    One of the few things that worked fine on the gen 3 :whistle:
  15. Mendel Leisk
    41,402
    Yeah either 4th gen design revision messed something up, or they had a manufacturer who did something poorly.
  16. bisco
    51,896
    We’ve had quite a few complaints here, but many have had no trouble. Makes me think defect
  17. bisco
    51,896
    Maybe a production batch, supplier change, or an American worker on the line :p
    Doug McC likes this.
  18. jerrymildred
    jerrymildred Senior Member
    11,517
    14,150
    Tampa, FL
    Well, think about it. The gen 4 exchanger is after the cat. The gasses are WAY hotter there then in the gen 3 location. Burn through isn't a big surprise to me.
    douglasjre and amos like this.
  19. bisco
    51,896
    Just need better materials?
    Doug McC and jerrymildred like this.
  20. Mendel Leisk
    41,402
    Maybe that was to keep the (downstream of the Cat) EGR connection from getting even longer.
