Any Gen 4 Owners Out There With Blown Head Gasket ??
Discussion in 'Gen 4 Prius Main Forum' started by AmazingFacts, Jan 14, 2022.
  1. jerrymildred
    jerrymildred Senior Member
    11,517
    14,150
    Tampa, FL
    I believe it was to keep the soot out of the EGR cooler and the intake ports. At least that was the result. But, as @bisco observed, the materials don't seem to be up to the job in the new super hot environment.
  2. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,462
    2,423
    Taylors, SC
    With metal parts that are stamped and assembled with welds, the leaks usually develop at stress points from improperly designed weak points and the welds themselves.
    The assemblies are subjected to a high range of rapid heating an cooling cycles and expansion and contraction.
    That is equivalent to bending a paper clip back and forth until it breaks.
    Seffy, Doug McC and jerrymildred like this.
  3. N khan
    N khan New Member
    London
    Hi does this mean my 2017 gen 4 prius head gasket is blown i am losing coolant and open water pump and is organish
  4. N khan
    N khan New Member
    London
    Hi
    I opened my water pump after many coolant loses and water pump looked orange whT does this mean
    When water pump is orangeish ?
  5. Doug McC
    Doug McC Senior Member
    1,079
    416
    Midwest
    2022 Prius
    That is good old fashioned rust, a clear indication that the coolant should have been changed a LONG, LONG TIME AGO.
  6. bisco
    51,896
    How many miles on her?
    Have you followed the maintenance schedule?
  7. AmazingFacts
    AmazingFacts Member
    112
    62
    San Jose
    Two Eco
    4th gen head gaskets are starting to show up in large numbers. Fourth generation Prius head gaskets are starting fail.  - YouTube
    I just picked up a 2016 Prius Eco project car with almost 300k miles with blown head gasket. Engine turns over and hoping that the piston rods aren't bent. HG failure symptom are there from milky oil, rattle upon startup, and using up coolant fairly quickly.
    Any threads here on a head gasket replacement for 4th gen?
    #167 AmazingFacts, Aug 7, 2023
    amos likes this.
  8. AmazingFacts
    AmazingFacts Member
    112
    62
    San Jose
    Two Eco
    Let me start a new thread for the above comment...
  9. Mendel Leisk
    41,402
    It’s virtually the same engine as 3rd gen.
    it could have an exhaust heat recovery leaking coolant.
    AmazingFacts likes this.
  10. bisco
    51,896
    i hope it's not the rings or egr
  11. AmazingFacts
    AmazingFacts Member
    112
    62
    San Jose
    Two Eco
    Yes thanks Mendel.
    And yes Bisco, I plan to check the EGR and curious to see if it will be fully clogged (at least couldn't see through it) like my gen 3 was at 250k miles. How would I check if rings are bad? Compression check?
  12. Mendel Leisk
    41,402
    [QUOTE="AmazingFacts, post: 3376307, member: 194746"]bad[/QUOTE]
    Runaway oil consumption would be my criteria.
    ^ Fixed quote above
    #172 Mendel Leisk, Aug 10, 2023
    V Sport Wagon and AmazingFacts like this.
  13. jerrymildred
    11,517
    14,150
    Tampa, FL
    Let us know what you find. I cleaned a 300k+ mile Gen 4 EGR cooler a while ago. It was almost pristine. But what a PITA to get out of there! Way harder than Gen 3. But since you will be pulling the head for tha gasket, that should make the EGR cooler a lot more accessible.
  14. AmazingFacts
    AmazingFacts Member
    112
    62
    San Jose
    Two Eco
    Thanks Mendel.
    And yes Jerry, will report back what I find.
    jerrymildred and Mendel Leisk like this.
  15. Mendel Leisk
    41,402
    Fixed quote in post #172
  16. Nico3d3
    Nico3d3 Junior Member
    37
    16
    Quebec
    That's bullshit, the exhaust gas heat exchanger is part of the emission system, so it's covered for 8 years / 100 000 miles. Call Toyota and file a complain. I got mine replaced freely this summer, I was losing coolant so they ran a diagnostics and they ordered a brand new heat exchanger. All paid by Toyota, no question asked.
    #176 Nico3d3, Sep 14, 2023
    V Sport Wagon likes this.
  17. bisco
    51,896
    better yet, call your atty generals office, or whoever is in charge of warranty laws
  18. Nico3d3
    37
    16
    Quebec
    When they do replace the heat exchanger under warranty, do you know if they use an updated part with better design? I got mine replaced in July at 70 000 miles / 112 000 km. I just hope I won't have to replace the same part later on. I'm planning to keep this car for a reallllyyy long time. At least, I got a coolant flush for free, they simply drop the old part, let all the coolant drain and they refill afterward.
    Edit: I do wonder if those gen4 with head gasket failure we see are all caused by bad heat exchanger. In my case, the reservoir was right at the low mark. if I hadn't noticed it while I was topping windshield washer fluid, it would've have been a catastrophic failure. Instead, it became a matter of buying a jug of Toyota coolant and checking it every few days until the part got replaced.
    #178 Nico3d3, Sep 15, 2023
    V Sport Wagon and bisco like this.
  19. bisco
    51,896
    there was an updated part at some point, but you'd have to try to find the changeover date
  20. sschmid
    sschmid Junior Member
    29
    NY
    What are the symptoms of that. Do you actually see a leak?
