Any guesses welcomed
Discussion in 'Generation 1 Prius Discussion' started by ronlewis, Jul 2, 2022.
  1. ChapmanF
    19,019
    Jakob likes this.
  2. dolj
    dolj Senior Member
    8,645
    4,395
    Wellington, New Zealand
    There are enough 'interesting' people on this site without adding one more. If this is your opinion, just ignore the thread and move on. You are not obliged to comment. People have had their accounts closed for far less.
  3. ronlewis
    ronlewis Active Member
    1,059
    205
    texas
    2001 Prius
    OK, if everyone is through watching my beef jiggle, back to the topic...
    UPDATE: I got the car in Denver back home - beautiful. It's #735 and in amazing shape. In Denver, I was able to bolt the new cheapo cat onto the exhaust manifold. It's not easy to get the second spring bolt started - really gotta exert some push to compress that spring enough to catch a thread. Then, I just shoved a universal bullet muffler on the end of it, and dang if it wasn't the wrong size - 2" OD vs 1 7/8" - but a found some pieces of sheet metal on the ground that I formed into a shim and got it together with a U-clamp.
    It wasn't that quiet, but I drove it back to Houston just fine, with the CEL for the ox sensor and vacuum line. Fixed those two items and got a muffler shop to weld the exhaust up using the bullet muffler as my new resonator, cutting off the flange of the rear exhaust section, bending a new pipe from the rear of the bullet over to that last section, and welding everything up. Now, I won't be able to remove the exhaust without cutting it apart again. It's one solid pipe from the manifold to the rear tailpipe.
    But it's quiet! And runs great. I'm amazed how clean the interior is - 200k miles and none of the chrome worn off the dash buttons, the steering wheel looks new, the seats are perfect. Drives real tight - shocks and struts great. AC cold. However, twice since I got it fixed, first start of the day triggered an orange triangle and exclamation car. Both times, I cleared the codes by pulling the battery fuse, and it never came back over days/hundreds of miles driving.
    First time, I checked the battery - I still have a second battery in the trunk and jumper cables from it to the original that's still connected - one of the jumper cables was off. Connected it back, plugged in the fuse, and didn't come back for days. Next time, cables still connected, but after clearing codes, never has come back now. But...
    So, I gave that one to my son and picked up the one from ATL that I'd left at his house. He replaced the ox sensor and did the vacuum hack. It runs great now - no CELs, no seeming injector issues/rattling at low RPM. Except, it still throws the triangle and exclamation car whenever you re-start it after previous driving. Same scenario as car one - unplug the battery, clear the codes, and it drives fine. Except with this car, it comes back whenever you turn the car off and restart, except when you clear the codes right before restarting.
    If I start the car without clearing the codes, and just let it idle, it doesn't seem to throw the code (may need to wait longer than 5mins). But, when I put it in gear to drive, the code immediately triggers.
    So, it sounds similar to the other car, and both appear to have had the same original problem - stolen cats - as what kept them from driving (i.e., probably driving fine until cat stolen, but you never know with auction cars). And both sat in an auction yard for a few months.
    No, I haven't pulled codes yet - in the middle of all this I've been repairing my dad's house in this heat and am beat right now. It still feels like a 12v battery issue. I'm wondering whether the original batteries that are still in the cars and wouldn't start the cars at the auction, are soooo dead that they're triggering the triangle even though I have the good batteries jumper to them.
    As y'all know, getting batteries that fit this car is pricey - special terminals, strange mounting locations, non-vapor. I've been using Walmart lawnmower batteries for a while with good price/value luck. But, to install them correctly is a pain; they have different terminal types. But, I've been able to distort the cars terminal connector to fit; just gotta spend the time to do that now that I'm home and eliminate it as the issue.
    One other thing though - the ATL car started triggering the Brake and ABS dash lights sometimes when I come to a stop. It goes out after maybe 5-10 seconds, but not seemingly from anything I'm doing in jiggling (tribute to beefieboy) the parking brake, shift lever, pumping the pedal, etc. The brakes seem to work fine though, and my son said it had plenty of fluid, but I'll check again. Anyone ever have that issue?
  4. rjparker
    rjparker Tu Humilde Sirviente
    11,097
    6,963
    Texas Hill Country
    The curious thing about this thread is the reader gets no clue what year and model vehicles are being discussed. We know one came from Atlanta and after some gay bashing there is another car from Denver. We know the son lives in Austin and the OP lives in Houston, probably near the OP's dad.
    We learn someone has actually had their account blocked by Priuschat! That piece of information actually floored me.
    So I am going to be the first to do what the Op asked. I am guessing the 12v battery is not being charged on the Atlanta car. I will further guess the Denver car is a gen3 with a blown head gasket. Plus the brake booster is going out.
  5. ronlewis
    1,059
    205
    texas
    2001 Prius
    Thanks for trying, RJ. This is the Gen1 forum, so I assumed everyone would understand that I'm talking about Gen1s. Honestly, Gen1s are all I'm interested in - I don't like the body styles of any of the other Gens - so yeah, all the dozen or so Prii I've owned have been Gen1s.
    Not sure why it matters where everyone lives, except that we're all far enough apart that I can't walk outside and see the car to answer questions here or provide data if it's in another city. I'm in Houston with 4 of the Prii; my son has one in Jarrell, just north of Austin, I have another in storage in Dallas, and my dad is in Corpus Christi, but none of the cars are, although I drove the CO there last week and then to Aus to swap with my son.
    The ATL car, now here in Houston with me, doesn't seem to have drained the 12v lawnmower battery (LMB) I placed in the trunk and jumpered to the original, dead battery (OB) still installed in the car. Not sure that means the car is charging it though, through the OB and across the jumper cables to that LMB. But, it keeps driving fine (after resetting the codes each restart) for over a thousand miles now (ATL to Aus to Hou).
    The car doesn't start without the LMB attached (trunk light very dim). Soon as I attach the jumper cables (after plugging battery fuse back in), the trunk light brightens to normal and the car starts and runs normal. I haven't checked either battery's voltage, but as long as the LMB is attached, the trunk light stays bright and the car starts and drives normal after resetting codes...so far.
    So, is the OB not good enough to start, but once started with a boost from the LMB, it's able to run everything just fine? IDK, I've not disconnected the LMB after starting to see. If so, would that allow the LMB to not use its charge, such that even though it's not being recharged (as you propose), it's still able to boost the OB each time to start (albeit it will eventually run out of charge)?
    It seems unlikely, but IDK how the charging system works, so I'll check that. I'm assuming that since the LMB seems to be retaining its charge (again, IDK, but over a thousand miles driven suggests so), that the car must be sending voltage back to it all the way through the jumper cables. SYK, I've had this same set up in the Prius I've been driving the last year (that allows me to not mangle the car's cables permanently to adapt to the LMBs), and that LMB has never run dead. Surprisingly, during all this I inadvertently left that car's LMB disconnected at one point as I borrowed the jumper cables, and now the old battery seems to run it again - like it came back to life after, or in fact, was never actually bad.
    Anyway, my experience suggests that 12v will get to the LMBs and keep them charged, and I'm assuming the ATL car is doing that now.
    Instead, I think the problem is related to the way the triangle doesn't go off (after clearing codes and restarting) until I put it in gear. I'll have to find the old thread here (or was it somewhere else online) that describes how to test whether a triangle (I think tied to the BATT symbol) is in the battery, inverter, or, I forget, somewhere else depending on when the triangle triggers. You start with the key on, wait 5 mins for a triangle trigger. If so, it's the hybrid battery, IIRC. If not, start the car but leave in Park, IIRC, and wait 5 mins again. Finally, put it in gear. At the time, that pinpointed a problem in another of my cars and I found a loose connector right where it suggested. It kinda sounds like this car could be similar - that the problem can be indicated by the triangle not appearing until it's in gear.
    But, I also wondered whether the OB being dead could, perhaps, prevent the car's ECU from seeing enough voltage, not seeing the LMB behind the OB. Never done it on my other car though.
    The answer is probably, knowing my luck, that the car has a major problem (bad inverter?). The previous owner could have learned of the problem and sabotaged the car for insurance fraud. I'm always suspicious of these cats being stolen since it's so hard to get to those manifold bolts and few thieves have the desire or come prepared to unbolt cats. This one also had the dent in the back that I thought was the reason it was at auction, but after seeing it up close, that dent is in the exact spot where it was dented, and bondo'd, once before - what are the chances of that?
    I know, I know, read the codes. Been catching up on other tasks since I got back.
    As for the CO car. not sure why you think it has blown head gaskets. I've driven it almost 2000 miles (Den-Hou-Corpus-Aus) and it's not overheated or smoked or anything I'd associate with gaskets. The radiator was full to the top when I checked it.
    It drives normal in every way, for hundreds of miles at a time, through multiple restarts, except twice. Days apart, Triangle at start up. Once when the LMB set up was accidentally disconnected. Cleared and doesn't come back for days. IDK, but checking the codes seems like the next step. I think it's just that 12v battery.
    Thanks for helping.
  6. rjparker
    11,097
    6,963
    Texas Hill Country
    When you ask for a guess, especially with no information, that is what you get. A guess is really worthless. Which was my point.
    Based on slightly increased data, you can't just parallel a dead battery with a lawnmower battery and expect good results. In fact a dead battery will tend to discharge your second battery very quickly. You would be better off disconnecting the ground terminal on the old battery and connecting the lawn mower battery to ground. Clearly if the car keeps running for hundreds of miles, it is not running on the battery. Like every car, the charging system runs the car after startup, or in Prius, after Ready is achieved.
    MrPete likes this.
  7. ronlewis
    1,059
    205
    texas
    2001 Prius
    Sure, RJ, sorry to frustrate you. Honestly, this was always a strange forum compared to others I participate on. For a car forum, it's always lacked the typical "mechanic" guys that are on most forums. Instead, it's always had more nerdy IT types. And you see it in the conversations. Mechanics love mystery problems. They talk about them for hours. IT techs? Not so much, until...
    I was a sw salesman for many years and had to deal with a lot of IT techs. It was always the same - my tech had to have the "who has the biggest stick" battle with their tech, and once that pecking order is established, me and the exec could go do the deal. I'll just concede and reside happily at the bottom of the PriusChat pecking order.
    I compare this forum to the Ford diesel forums I participate on. Those are mechanics, real dirt-under-the-fingernails types. Sure, you need to read codes on those trucks too, but they're gungho about just talking about problems if the OP doesn't have codes yet. Lots of guys just throw problems out for something to chat about. It's a real community.
    This forum used to be better. There were some mechanics here, and guys figuring stuff out. I guess there just aren't enough of these cars left. Yeah, there are a lot more of those trucks out there.
    So, anyway, all of y'all don't have to keep telling me to go get codes. I know that. And, I know that limits what you can tell me for sure. That's OK, I don't care. If you don't want to just talk about it, venture guesses, recall similar stories you may have or heard, that's fine too, it doesn't bother me. I'll get all these cars fixed either way. However, if anyone wants to waste their breath telling me that over and over, that's fine too. Whatever floats your boat. I'm easy. You can even call me stupid, and a waste of time. I've been called worse; it doesn't bother me.
    Anyway, my Techstream PC is dead and I don't feel like screwing with it. I used TorquePro but it's Toyota gauges start with Gen2, so there may be some differences. However, it showed me a P3077 code, which sure makes a lot of sense. Recall that driving back from ATL, this car flashed the turtle icon for a little while, which can mean the battery temp is too high.
    And, that would explain why it comes on as soon as I start the car, but never again. After I clear the codes, and start the car, I assume the code won't trigger until I drive for awhile and the battery warms up. But, I'm thinking that maybe it's a "soft" code, because the CEL never comes on, but the next time I start it, the ECU sees it and throws the triangle.
    Hell, IDK. Maybe that makes no sense either. But still, also recall that this car has a dent in the driver's real quarterpanel - right where that battery fan sits inside the trunk. And, sure enough, that metal is pushed against the fan when I pull out the trunk liner. And the switch connects in the back, right where the metal was pressed in against the fan. I had to remove the fan to disconnect it.
    But, I don't see anything broken. And the fan seems to run fine when I power it with 12v. So, my question is, if you know the answer or care to guess: is there a way to force the ECU to power the fan, so I can use my meter to see if voltage makes it to that connector?
    How about a wilder guess? Is there anything else that can trigger a 3077 except the fan not blowing?
  8. rjparker
    11,097
    6,963
    Texas Hill Country
    I have an IBM Thinkpad T42 with win7 I will make a killer deal on. You have to install Techstream.
    Yes Techstream and the Dr Prius app can operate the fan.
  9. ronlewis
    1,059
    205
    texas
    2001 Prius
    oops delete.
    #29 ronlewis, Aug 6, 2022
  10. ronlewis
    1,059
    205
    texas
    2001 Prius
    Thx, RJ. I have an old XP version of TS, on an old Dell laptop that quit. probably easier for me to upgrade TS - this laptop I'm using is Win7. If I recall, though, TS is a PITA to install. I think I'm going to let my son mess with it - I gave him one of these cars, so he's invested too, lol. He programs my VCR too.
    Or, are you saying that Dr. Prius by itself can do that? I'll check it out.
    Ya figger this could cause a 3077?
  11. ronlewis
    1,059
    205
    texas
    2001 Prius
    OK, I've recognize Dr. Prius now. I had it on an old phone. I don't see any function to start the fan, although there's a check box to "override battery temperature," whatever than means. Is this a good Prius code reader? I see those functions, one for Battery Errors and one for Engine Errors. I'll try it out tomorrow. All of these parts should work fine on my parts car, if I need any of them to fix this. I was able to push a lot of that dent out by hand.
  12. Jakob
    Jakob Junior Member
    69
    Wisconsin
    2003 Prius
    If this brake issue is still present, note that codes from the brake system should be readable using the blink diagnostic mode without a scan tool.
    ronlewis likes this.
  13. rjparker
    11,097
    6,963
    Texas Hill Country
    Keeping the battery temp slider low will run the fan faster as long as the app is running. The code reader is limited to engine and battery. Battery is the main focus of this app. There are many other codes outside the engine and battery.
  14. ronlewis
    1,059
    205
    texas
    2001 Prius
    Cool, so I should be able to Ready the car, slide the Temp low, and hear the fan kick on? If not immediately, then after driving for a bit to warm up the battery? Such that when I pull over and leave the car Ready, I could pop the trunk and hear the fan to confirm it operates? I'll check the fuse for it as well. Maybe the wreck popped the fuse.
    I'll try that today. Hmm, wonder what's next when/if I confirm it is operating? Fan works, wiring to it good, ECU capable of turning it on...why wouldn't it? because it's not sensing heat from the battery, or wiring between that sensor and the ECU/battery ECU. But, I'll cross that bridge when I get there.
    OK, doesn't sound like an overall code reader that could substitute for TechStream. I'm not going to worry about TS right now. This 3077 could logically be my only problem, except for the brakes, and I can get those through the car's display.
    Thx for helping.
  15. ronlewis
    1,059
    205
    texas
    2001 Prius
    OK, that was easy. It was the blower motor fuse, lol. I took the motor out first, haha, but that's OK, I needed all that out to work on the fender dent.
    I still got the brake issue. About to research that and go check display diag. The Brake and ABS lamps only go off when I'm braking and turning left at the same time. Just barely touch the wheel left, and the lamps go off for about 10 seconds. Braking straight or to the right, no lamp. At all times, the brakes seem to work just fine and the reservoir is OK. Let's see what the diag says.
  16. ronlewis
    1,059
    205
    texas
    2001 Prius
    OK, the dash display sequence was 14, 15, longer pause, then 14, 18, long pause, then repeats. I think the 15 relates to drivers rear speed sensor, and that's where the dent in the car is, and the ABS/Brake lamps only go off when I turn left. So, I crawled under and, sure enough, that connector is loose and possibly broken. I'll go back with a flashlight and see how far the wiring harness goes to the previous connector. If it's easy to remove, I'll just swap in one from my parts car. Doesn't appear to be unsafe until then.
    Oops, just recall that my son said there was a leak, something on his new garage floor, and he assumed it was brake fluid. I'll look for that too.
  17. Q*bertZ
    Q*bertZ Member
    167
    greenville south Carolina
    2002 Prius
    All my brake errors have always been triggered because my 12 volt battery was getting old/ discharged.
  18. MrPete
    MrPete Active Member
    507
    194
    Colorado, USA
    Ron,
    The problem you face is, to be perfectly frank and say this pretty nicely: you appear to have a fear of doing simple logical things, and using the proper diagnostic tools available to you.
    Excuses: too tired, too busy, can't be bothered. Yet you wrote up a big long story asking others to guess at answers. And when they suggested good diagnostic procedures, you were not interested.
    It feels like you are wasting your time, resisting basic good advice, hoping someone will take a guess... Even though you clearly have no idea what you are doing (yet have some seat of the pants experience.)
    Example: RJ pointed out that it is a bad idea to leave OB connected along with LMB. He is 100% right. I saw that way back in this thread and groaned.
    Good diagnostic procedure: use tools to get more info, and don't change a bunch of things hoping one will stick.
    You seem allergic to good diagnostic methods. Maybe you'll learn something from this adventure.. More than disappointment in the community. (There are a number of amazing car mechanics and more here )
    #38 MrPete, Aug 15, 2022
  19. ChapmanF
    19,019
    Looks like Ron hasn't been around in a week or so. Did post some codes though.
    Still, a couple things are weird:
    I don't think the ECU ever does that: blink one set of codes, then a different set on repeat. I would suspect instead that the blinks were miscounted one time or the other. If it really is blinking a changing set of codes, it wouldn't be bad to post a video, to allay very natural skepticism.
    For any generation except Gen 1, it would have been important to also say which lights blinked which codes. But on Gen 1, brake codes only get blinked on ABS, so as long as these cars are all Gen 1, I'll just assume the codes reported were on ABS.
    That leads to the next weird thing: for Gen 1 on the ABS light, 15 is the only one of those reported codes that is used. (In my 2001 book, anyway; maybe there's a 14 or an 18 in a 2002 or 2003 book.)
    15 as a Gen 1 brake code is the DTC C1215, which means one of these two things happened:
    • The ignition switch was ON and the voltage at terminal +BS of the brake ECU was 2.5 V or lower for half a second or more, or
    • The car was moving at 3 mph or more and the +BS terminal voltage was 9 V or less for ten seconds or more.
    (My book actually says "3 km/h (5 mph)" but I'm sure they swapped the units by mistake; the km/h figure should be the higher one.)
  20. Jakob
    Jakob Junior Member
    69
    Wisconsin
    2003 Prius
    same with my 2003 manual
