Any idea what this is
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Ben Schneider, Mar 4, 2019.
  1. Ben Schneider
    Ben Schneider Junior Member
    central florida
    While taking out the back seat to clean hybrid battery fan, found this (my car is previously owned)
  2. RightOnTime
    RightOnTime Senior Member
    791
    1,660
    183
    Kidnapped in OC, CA
    12volt battery vent? If replacing with aftermarket 12volt there are no provisions for it.
    iPhone ?
    Raytheeagle likes this.
  3. Pluggo
    Pluggo Senior Member
    608
    534
    Folsom, Pennsylvania
    You DO have a vent line connected to your battery, don't you? There's a good reason why hydrogen should not build up inside the car.
    52,692
    there are provisions for a vent if you purchase the correct aftermarket battery
    Mendel Leisk and RightOnTime like this.
  5. RightOnTime
    791
    1,660
    183
    Kidnapped in OC, CA
    Correct
    iPhone ?
  6. RightOnTime
    791
    1,660
    183
    Kidnapped in OC, CA
    No need for a vent line if replacing with Optima Yellow Top Battery
    iPhone ?
  7. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    There are very good reasons why you want to vent any battery in the passenger compartment, but they all have to do with the safety of humans, not with the performance of the battery.
    RightOnTime likes this.
  8. RightOnTime
    791
    1,660
    183
    Kidnapped in OC, CA
    Oh Jimbo Do your homework on Optima Batteries.
    Knowledge is the key for success. Wake up the future is here
    iPhone ?
  9. OptimaJim
    OptimaJim Member
    74
    Wisconsin
    While the chances of a battery being so severely overcharged, that it vents toxic & flammable fumes, is remote, it is still possible. For that reason, we recommend any battery installed in an enclosed area (including trunks and interiors) be properly-vented to the outside atmosphere. The Optima DS46B24R YellowTop does have a vent port for hose attachment.
    Jim McIlvaine
    eCare Manager, OPTIMA Batteries
  10. Mendel Leisk
    42,183
    I've got an Optima Yellow Top, and it's got the vent port.
    RightOnTime and Robert Holt like this.
  11. Ben Schneider
    central florida
    that sounds important... will look into it
    appreciated everyone.
  12. RightOnTime
    791
    1,660
    183
    Kidnapped in OC, CA
    Guess I need to do my Homework. Will pass this along.
    iPhone ?
  13. Grit
    Grit Senior Member
    6,577
    4,230
    Wilkes Land
    Was hoping it be a picture of the car manual, no one reads it :D
