Any installs of 18w LED foglights?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by xliderider, Jan 10, 2014.
  1. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    Anyone install these 18w LED foglights?
    iJDMTOY 6000K Xenon White 18W High Power LED Fog Lights Foglights Assembly For Lexus IS GS LX HS RX Toyota RAV4 Camry Solara Avalon Matrix Prius Scion xA, etc : Amazon.com : Automotive
    Or the amber/orange version?
    Amazon.com: iJDMTOY 3000K JDM Amber Yellow 18W High Power LED Fog Lights Foglights Assembly For Lexus IS GS LX HS RX Toyota RAV4 Camry Solara Avalon Matrix Prius Scion xA, etc: Automotive
    They look pretty bright, but like the OEM foglights, they lack any real cutoff. Yet, I'm thinking the stray light, glare from these may not be as bad as the OEM foglights? At 18w of LED power per foglight, they should be brighter than the OEM H11 55w halogen bulb foglights.
    I really like these, because they appear to have a nice, sharp cutoff. However, the price is kinda turning me away. With shipping, they're almost twice the price of the previous foglights. Plus they're only available from an international seller ATM:
    http://pages.ebay.com/motors/link/?nav=item.view&id=151154809457
    SCH-I535
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Seen em before on ebay. Let us know how they rate. ;)
  3. xliderider
    7,869
    3,116
    Honolulu, HI
    I have a question pending to the Amazon seller. I noticed there is no DOT or E code markings on the foglight lenses visible in the pictures.
    If so, then they would be illegal for on road use for USDM applications.
    SCH-I535
  4. burstaneurysm
    burstaneurysm Active Member
    469
    144
    Chicago, IL
    In theory, yes. In reality, the odds of you being stopped for these and then to have an officer crouch down to verify the DOT marking on the lens is a huge long shot.
    As long as they're aimed well, they'd look OEM enough to pass.
    (unless you live in a state with strict inspections)
  5. kingnba6
    kingnba6 Active Member
    1,018
    242
    NY
    i just saw them on ebay. wondering how well they actually work
  6. xliderider
    7,869
    3,116
    Honolulu, HI
    OK, found this youtube video which highlights these foglights. Don't know about the halo feature though, as they aren't mentioned in the Amazon or eBay auction descriptions:
    These have the halo feature, but you'd need to fit some H11 connectors on these:
    iJDMTOY Xenon White 18W High Power 6-LED Replacement Fog Light Lamps w/ 2-LED Halo Rings For 2013-up Scion FR-S and Subaru BRZ : Amazon.com : Automotive
    Their website has a few positive reviews:
    18W High Power OEM-Style Fog Lights Assy For Lexus Toyota Scion
  7. xliderider
    7,869
    3,116
    Honolulu, HI
    I sent an inquiry to the Amazon seller of these LED foglights asking about the lens material and whether they are legal for use on US roads. Here is their reply:
    "The item you are inquiring about is legal for street use purposes. It is FAC coded, the lens is glass not plastic."
    I've never heard of the FAC certification they refer to though. :confused:
    SCH-I535
  8. D Unit
    D Unit Junior Member
    Bay Area, CA
    The amber versions just arrived in my mail today. Shipping was very fast and quality looks pretty good so far. I got the ambers because I thought the halos looked too cheesy. Since the fogs are LEDs, do I need a special harness with resistors, or can I use any h11 harness since the resistors are internal? I am assuming the latter but want to make sure.
  9. Au-Toe
    Au-Toe Matrixowner
    86
    Chino, CA
    2014 Prius Plug-in
    subscribing to see any pictures in the future, and a write up as to how to install.
  10. xliderider
    7,869
    3,116
    Honolulu, HI
    You can use any H11 harness. Resistors are only necessary for signal lights/bulbs due to hyper flashing from the low resistance of LEDs versus halogen bulbs.
    Please post pics, and your impressions. I'm interested mainly on if there is excessive glare/stray light from these LED foglights. Also, if they are brighter than a halogen foglight.
    SCH-I535
  11. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Yes yes, please a review.
  12. xliderider
    7,869
    3,116
    Honolulu, HI
    If you already have the OEM foglights installed on your Prius, these will simply be Plug and Play as a direct replacement for each foglight. You would use the wiring harness and dashboard switch that came with the OEM foglight kit.
    If you don't have the OEM foglights installed, then you would need the foglight shrouds for the 2010 - 11 Prius, or the lower grill with the foglight openings for the 2012+ Prius and a wiring harness and switch.
    If you need to install in a 2010-2011 Prius, then I'd suggest getting one of those inexpensive OEM style kits available on eBay for under $50.
    SCH-I535
  13. Jay J
    Jay J Active Member
    469
    253
    Torrance, CA
    I have them but its like flood lighting (theres no cutoff ) :(
  14. xliderider
    7,869
    3,116
    Honolulu, HI
    That's what I was afraid of. :(
    Thanks. (y)
    SCH-I535
  15. Au-Toe
    Au-Toe Matrixowner
    86
    Chino, CA
    2014 Prius Plug-in
    pictures???
  16. Jay J
    Jay J Active Member
    469
    253
    Torrance, CA
  17. xliderider
    7,869
    3,116
    Honolulu, HI
    Jay J, thanks for the pic. (y)
    Can you also take one straight on to the front end, preferably with the camera above the lowbeam cutoff so that any glare/excess light from the foglights are more apparent?
    SCH-I535
  18. aportades
    aportades Team Thrust Racing
    76
    177
    San Diego, Ca.
    Looks like it's compatible with the 2011 year might look into these.
  19. xliderider
    7,869
    3,116
    Honolulu, HI
    It is if you already have foglights installed.
    These are just the bare foglight housings with H11 connectors. No shrouds, no wiring harness/relay, and no dashboard switch.
    SCH-I535
  20. aportades
    76
    177
    San Diego, Ca.
    Thanks for the info buddy
