Any interest in adj illuminated s/w buttons??
Discussion in 'Gen 2 Prius Accessories & Modifications' started by BT Tech, Jan 14, 2006.
  1. BT Tech
    BT Tech New Member
    885
    South Florida
    No problem Doctor as I wanted to get responses from both camps.
    I personally do not like the fact that the illumination on the S/W buttons are so dim and non adjustable so this is the reason for the mod.
    Practically every car that I have ever driven that has buttons on the S/W had adjustable brightness that controls the illumination. Why the Prius doesn't have it I have no idea but I plan to change that.
    Although I agree that you can "feel" your way around I would like to be able to actually see them as well at night. Around here there is a lot of traffic with misadjusted headlights so when your night vision is not in full effect, looking at the buttons on the S/W is basically useless as they are nearly invisiable.
    Thanks for your response!!
  2. brasche
    brasche Member
    156
    Orlando, FL
    Any feedback or suggestions would be appreciated!!
    Thanks!!
    I'm in at $100.
  3. BMcGraw
    BMcGraw Member
    230
    Southern California
    Some of us wear driving gloves which hinders "bump recognition" to some extent...
    I'm in the other camp... "Light up my life!"
  4. BT Tech
    BT Tech New Member
    885
    South Florida
    Thanks guys for all of your feedback!! I am close to finishing things up. I have a bunch of connectors that are en-route to me now so I can start on a few "test" kits.
    I will keep everyone posted on my progress.
    Thanks!!
    Brian
    BT Tech
    305-652-3115
  5. darelldd
    6,059
    389
    Northern CA
    Figure out a way to stuff LEDs into the steering wheel, and you'll have a customer here! I'm an EV nut AND and LED nut.
  6. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    As far as I can tell the stock illuminators *are* LEDs. With a
    dropping resistor that's too high in resistance, so they don't
    get enough current. The simplest mod would be to change that
    resistor to something lower, but then it wouldn't be adjustable.
    BT, how do you plan on dealing with the fact that the steering
    wheel lights come right off ILL+ and return through the same common
    ground as everything else on the wheel? The brightness adjuster
    works by producing a PWMed *negative* side return to the things it
    does control, so if you're going to deal with the steering wheel
    you'd have to turn that into a PWMed high-side drive and send that
    up the wheel's ILL+ lead ... *and* change or bypass the resistor.
    Perhaps you should offer two kit options -- the cheap one in which
    the resistor is simply changed, and the high-end one that converts
    PWM ILL- into PWM ILL+ and sends that to the wheel...
    _H*
  7. akaab
    akaab Junior Member
    One for me, please! The lack of adjustable dimming on the wheel is one of my biggest peeves.
    AKAAB
    West Palm Beach
  8. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    oh is that what we are??
  9. Kathleen2
    Kathleen2 New Member
    77
    If it is easy to do and the instructions are simple to follow I'm interested.
    Kathleen
  10. DocToss
    DocToss Junior Member
    69
    Cordova, TN
    Agood place to put an adjustable control is in one of the little button places next to the dash dimmer.
  11. cmacal6364
    cmacal6364 New Member
    Any progress on this project...? I am definitely interested! THANKS
  12. MJ-Prius
    MJ-Prius New Member
    I would definitely be interested if the mod was easy and under $100.00.
  13. stevehj
    stevehj New Member
    28
    They are defintely dim and I'm defintely IN!
  14. BMcGraw
    BMcGraw Member
    230
    Southern California
    Any further progression involving the illuminated s/w buttons Brian? Still one of the many waiting for this modification I'm sure... :)
  15. aaf709
    3,862
    2022 Prius Prime
    To bad the dropping resistor can't be removed and those leads connected to the dimmer wheel itself.
  16. darwin100
    darwin100 New Member
    131
    It drives me crazy as well....keep me posted...
    darwin
    driftwood pearl
    oakland CA
  17. drmanny3
    drmanny3 Member
    124
    Orange County, CA
    Add me as interested. I drive several cars and don't always remember where the buttons are. They should be brighter. I transferred the BT chassis plate from my 05 to the 06. The car seems to handle better than the 05.
    Thanks,
    Manny
  18. cmwade77
    cmwade77 New Member
    116
    Add me to the interested list, as well as perhaps an illuminated cruise control stick, suggestions anyone?
  19. Rhody Jim
    Rhody Jim Junior Member
    Brian....Count me in for under $100.
  20. BellBoy
    BellBoy Member
    223
    REALLY INTERESTED!
    Let us know your current progress...don't go "coastal" on us! :lol:
