Any issues with EV driving with the Low Fuel Light for a long period?
Discussion in 'Prime Main Forum (2017-2022)' started by noonm, Nov 4, 2019.
  1. Rob43
    Rob43 Senior Member
    1,373
    1,049
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    You probably still have over ~2 gallons in your tank because of the amount of Yellow still shown on your gauge.
    Rob43
  2. Salamander_King
    Salamander_King Senior Member
    11,019
    8,954
    New England
    Congrats!
    From the number presented
    4644.9 miles ÷ 504.6mpg=9.20511296 gal
    You have used only 9.2 gal of gas so far. Meaning you still have ~2 gal of gas left in your tank. You can easily go over 5K miles/tank at this rate.
  3. Zed Ruhlen
    Zed Ruhlen Active Member
    247
    138
    Hood River, OR
    2018 Prius Prime
    All of these systems are sealed. The tanks are sealed, the pump is sealed, the refinery is sealed, your car is sealed. Any exposure to moisture is both small in quantity and small in timeframe. Water is NOT an issue in car gas.
  4. Trollbait
    12,542
    Never claimed water was an issue. Those looking for negatives for ethanol do claim its hygroscopic property makes water an issue. I'm just pointing out that if water is an issue, it isn't because of ethanol.
    Zed Ruhlen likes this.
  5. noonm
    noonm Senior Member
    575
    595
    2018 Prius Prime
    Final Tally: 510 mpg
    Sadly, I had to fill up a few days ago. However, that's over 4700 miles on one "tank" and roughly 400 miles after the low fuel light turned on.
    jerrymildred likes this.
  6. Rob43
    Rob43 Senior Member
    1,373
    1,049
    2013 Prius v wagon
    Congrats !
    You get the unofficial "Genesee beer book of records" !!!!
    Rob43
    jerrymildred and noonm like this.
  7. jerrymildred
    jerrymildred Senior Member
    11,517
    14,152
    Tampa, FL
    Impressive. Sure wish the 2017 Primes would display over 199.9 mpg.
    noonm and Rob43 like this.
  8. Rob43
    Rob43 Senior Member
    1,373
    1,049
    2013 Prius v wagon
    I just drove a bit into the low fuel light...
    Rob43
    #48 Rob43, Dec 27, 2019
    noonm likes this.
  9. Rob43
    Rob43 Senior Member
    1,373
    1,049
    2013 Prius v wagon
    Another quick trip somewhere in the Prime, the picture was taken while filling up with E0 at the gas station when I got home.
    Rob43
    noonm likes this.
  10. Chazman62
    Chazman62 Member
    108
    66
    Long Beach, CA
    2020 Prius Prime
    Agree.
    Not only that, driving with the fuel level too low causes the fuel pump (dc motor) inside the fuel tank to overheat because the gasoline is the cooling & lubricating medium/liquid.
    Keep the fuel at least 1/8 full tank at minimum to avoid this kind of situation and prolong the fuel pump life.
  11. noonm
    noonm Senior Member
    575
    595
    2018 Prius Prime
    I understand the logic, but does it really apply if you aren't actually using the engine? I spent almost all of the time with my low fuel light on driving in EV mode. The only thing that was really heating up in the car was the heatpump to keep it warm in the winter.
    fuzzy1 and Trollbait like this.
