Any long distance commuters with a Prime?
Discussion in 'Prime Main Forum (2017-2022)' started by Prime_Time, May 24, 2018.
  1. Prime_Time
    Prime_Time Member
    110
    74
    Southern California
    I've been going back and forth whether or not I should get a prime. Main reason I'd get one is for Carpool access here in the LA area. But then I think about how many miles I'd be putting on my brand new shiny car and it kind of depresses me haha. I know a car is meant to be driven but I'd probably be putting 17k or so per year on it. The carpool wouldn't save me a ton of time, maybe 10 minutes each way.
    My commute would be about 70 miles round trip so I'd be using gas everyday no matter how much I charged.
    Does anyone else here put a lot of miles on their shiny new prime?
  2. Skapruisprime
    Skapruisprime Member
    122
    49
    MA
    My commute is 60 or so miles per day, 5 days a week and some weekend driving as well.
    I now only put a full tank of gas every 20 days (use to be every 5-6 days). And a fillup is $30 as of today gas prices are going up (use to be $40-$45 for a tank).
    I do wish the battery can last a little more but the hybrid makes up for it as it get avg 55mpg.
    Also I dont baby my drive, I drive like everyone else on the road going 75-80mph on the fast lane.
    Im saving hundreds of dollars compare to my previous car
  3. Bob Comer
    Bob Comer Active Member
    708
    460
    South Carolina low country
    My Commute is about 75 miles round trip, and only can charge once at home. I get up to 100MPG per day in summer, and in the 80sMPG in winter for my commute. (MPG is gas only and my electric is about half what gas costs.) How much you electric is probably makes a difference in you decision. Don't worry about the miles though, these are well built cars that go a lot of miles.
    heiwa likes this.
  4. Roy2001
    Roy2001 Active Member
    371
    158
    Sacramento, CA
    For carpool purpose, a Bolt/Model3 is better choices. They can remove plugin from the HOV list. But Prime is a very good hybrid car, reliable and gas sipping.
  5. Salamander_King
    Salamander_King Senior Member
    11,024
    8,978
    New England
    17k or so per year does not seem too much. Just a bit more than average. One thing to consider for carpool, Prime has only 4 seats. Then again, I don't think an adult can sit comfortably in a middle rear seat of regular Prius for a long commute.
  6. Tideland Prius
    16,675
    Yeah but at 70 miles, less than half of that will be in EV, that's still a decent amount of savings (and not polluting).
    Besides, that's 20 minutes a day or a little over 6.5 hours a month saved in travel time. The little things add up :).
    orenji and Raytheeagle like this.
  7. eustachio
    eustachio Member
    48
    44
    CA
    How?
  8. Bob Comer
    708
    460
    Using my EV at lower speeds and HV at higher. It's really not hard with a Prime. In pure HV mode it gets better than 50MPG.
    RJ Primw likes this.
  9. eustachio
    eustachio Member
    48
    44
    CA
    Ah ok, thanks for clarifying. I thought you meant 100 mpg in HV mode. Mpg vs mpge...
  10. triggerhappy007
    triggerhappy007 Active Member
    498
    334
    I have a 110 mile round trip commute with just charging at home. I bought my Prime on 5/5 and it has 3,183 miles already. 1740 of those miles were from my trip home from the dealer. I'm enjoying 800 miles per tank compared to 400 with my other car. Using only 11 gallons compared to 27 gallons with my other car to go 800 miles. Below is what the MPGs look like with a long commute.
  11. SteveMucc
    SteveMucc Active Member
    391
    268
    Kentucky
    I used to commute 102 miles per day round trip into NYC. I would save EV for local roads and when I hit Jersey City. I averaged about 80MPG or so on that commute with an exhausted battery on arrival at home. I did not have access to a recharge station in the city (well, I did, but it would require walking back to the garage and moving the car after it was charged, and the chargers were at the most distant point of the garage so it simply wasn't worth it).
  12. triggerhappy007
    498
    334
    That must have been a long commute. How long did it take?
  13. Prime_Time
    Prime_Time Member
    110
    74
    Southern California
    Yeah but I don't think I'd want to purchase an EV since the tech is advancing so quickly and you can't get a model 3 for years anyway. I'd pay out the you know what for a 20k mile per year lease.
  14. triggerhappy007
    498
    334
    Can you charge at work or your commute is less than 60 miles? If so, check out the Clarity EV lease. It's $1500 down and $200/mo for 20,000 miles per year. You may be eligible for a state rebate of $2500 too.
    jmarkd7 likes this.
  15. Shameless
    Shameless Member
    71
    38
    Western Massachusetts
    My commute is almost exactly 70 miles as well, with home charging only. It's 95% highway, and I don't drive like a grandma. I've been trying different combinations -- HV on the hilliest bit, EV other times, etc., etc. By far the best solution has been EV Auto mode -- set it and forget it. My commute is weird -- it's a very hilly ride. My ride home has a large drop in elevation, but there are a couple of killer hills that devour a very high number of EV miles in pure EV mode. All my supposedly clever combinations got me as high as 65 or 70 mpg for the entire round-trip commute. EV Auto regularly delivers 80-90 mpg. Guess it's more clever than I am at knowing when to use the ICE.
    The real bummer is that there is a charger at my workplace, sitting unused 99% of the time. The cost is roughly double that of gas. I'm currently lobbying for them to at least reduce the cost, because I'd use it 5 days a week, every week. As it is, I get about 900 miles per tank. With that, there's no telling how high it would go.
    #15 Shameless, May 25, 2018
    jmarkd7 and breakfast like this.
  16. breakfast
    breakfast Active Member
    266
    199
    I'm sure you mean MPG, not MPH :)
    What is the cost of your work charger? Are they charging by kWh (hopefully), or by hour (hopefully not!)?
  17. Shameless
    Shameless Member
    71
    38
    AH, right! Thanks. Edited properly. The work charger is $1.50/hr. So figure about 2 hours, and that's $3 for 25-30 miles. Compare to gas at whatever it is per gallon now ($2.70?), and it's very roughly $3 for 55-60 miles. I'm all in favor of EV whenever possible, but I can't justify that expense every day.
  18. breakfast
    266
    199
    At the very least, you should convince your company to convert their pricing from per-hour to per-kWh. At your current pricing, Teslas or Chevy Bolts would be paying $.19 per kWh, which is probably a little bit more than your company in Western MA pays for electricity.
    Here are the reasons - you can go to your company with this reasoning (charge $.19 per kWh) and make it to be a win-win for everybody.:
    1) Cars with faster chargers (like Nissan Leaf or Tesla) will use several times more electricity than our Prius Primes do. The Prius Prime uses only 3.3 kWh per hour of your company's electricity (similar to a Chevy Volt's 3.6), where all-electric vehicles use way more - like the Nissan Leaf (6.6 kWh per hour), the Chevy Bolt (7.2 kWh per hour), or Teslas (which will pull around 7.7 kWh from a standard work charger). See https://www.clippercreek.com/wp-content/uploads/2017/12/SMUD_Charge-Times-Chart-20171208_Final_Low-Res.pdf for an up to date, accurate list of charging rates per vehicle.
    2) At a price of .19 per kWh, Teslas or Bolts would be paying your company just about the same as they paid before, whereas at .19 per kWh, you would be paying around $1.15 for 25-30 miles, which would cut your costs in half!
    3) Your company would be able to more accurately ensure what their break-even point would be with kWh pricing :)
    Good luck!
    Witness and Shameless like this.
  19. Shameless
    Shameless Member
    71
    38
    Thanks! Your reasoning is quite solid, however, in addition to such factors, I have a couple of other things working in my favor. One is that I work in Vermont, not Massachusetts, and as far as I understand, electricity is cheaper. Cheaper yet when you consider our new solar installation on campus. Secondly, it's a small campus, well off the beaten path -- everybody knows everybody, for the most part, and no one is coming to campus just to charge up. I can plead my case on a very personal basis. There is only one other EV driver (with a new Bolt) on campus. I intend to tell them, numbers like yours in hand, "Look, people -- you've got a potential user base of 2. You've priced 100% of your users out of the market. Why not make it free, since we're all about green everything, and we now have solar?"
  20. breakfast
    266
    199
    I like your Shameless reasoning ;):D:coffee::ROFLMAO:
    Shameless likes this.
