Any Navigation Receiver Install Issues If Replacing A Bluetooth Receiver Touchscreen Model?
Discussion in 'Gen 3 Prius Technical Discussion' started by James Analytic, Mar 11, 2024.
  1. James Analytic
    409
    63
    Michigan
    Does the 2012 model 3 MFD shown below (Navigation Radio Receiver System) work if installed in a 2013 model 2 without the nav, rear cam and extras? My model 2 is like a Bluetooth and typical Radio Receiver System.
    Anyone know of a reference detailing the two, ideally the wiring diagrams for both to see what matches and what does not? Maybe additional items to get from the donor car if worth removing.
    Was wondering if the majority of the radio receiver, speakers and Bluetooth capabilities does install and works properly enough, if it's worth the effort to snake through the rear view camera wire and install as well so to have that available? Didn't seem like a not rear view camera model had a wire run for the camera when I checked in the yard, though a lot was tore up on that one.
  2. James Analytic
    409
    63
    Michigan
    For a little more context, my current 2013 radio 6.1" screen has been having contrast issues for the last 100K miles like shown. Maybe there is a capacitor that needs replacing or a shoddy connection? Would be neat to have the newer features of the upgraded model radio however.
  3. James Analytic
    409
    63
    Michigan
    I found that the 2010 has a different design stereo and I'll post the info here as well. The model is in the image.
    2010_Stereo_With_Nav_JBL.jpg 2010_Stereo_With_Nav_JBL_front.jpg 2010_Stereo_With_Nav_JBL_rear.jpg
  4. James Analytic
    409
    63
    Michigan
    Here's a wiring diagram I found here: RADIO – Toyota Prius 2014 – SYSTEM WIRING DIAGRAMS – Wiring diagrams for cars
    Radio_2014_Toyota_Prius_System.jpg .
    Here's more images regarding the stereo I pulled from the reported 2012 Model 3, albeit not confirmed via a VIN check. Looks like I might have missed a jumper connectors that I literally had in my hand the second time I picked parts from. Will get next round there.
    20240329_162148.jpg 20240329_162216.jpg 20240329_162434.jpg 20240329_162514.jpg
    Another link with some relevant info: Prius C Radio Upgrade Parts List and Instructions | PriusChat
    "If I am wrong, someone please correct me.
    1. Reverse signal wire (I think... There is only one thin pink wire plugged in)
    2. Reverse camera (Nothing plugged in on mine so once again, I think)
    3. Jumper cable to 11
    4. XM Radio Antenna
    5. Power, Ground, Speaker output, (normal wiring on any install kit)
    6. Jumper cable to 11
    7. Steering wheel remote input, Aux 3.5mm input, Powered Mic Input (4 wires) and I am sure other things.
    8. Antenna AM/FM
    9. GPS Antenna
    10. USB Header
    11. Jumper Cable input from 3 and 6."
    Another link with relevant info and I'll copy the pdf and attach here as well:
    Wiring Diagram for Gen 3 amplifier | PriusChat
    183278_Navseperateamp.jpg 183279_radio_receiver.jpg 183287_zoomedamp.jpg 183288_navhu_to_extension_module.jpg
    Finally, another link with cam and shift position info:
    Need prius 2013 stereo wiring diagram or camera wiring diagram or pictures | PriusChat
    #4 James Analytic, Mar 29, 2024
